Question about Carrier BCA101R Air Conditioner
I need a remote for a carrier bca-101r wall unit. Or a compatible remote.
    Champion:
  • 210 Answers
Get model number and call place of purchase or carrier customers service.
Posted on Mar 23, 2008
SOURCE:
I purchased a Universal Wall Mount Control to operate a current wireless controlled fan with a hand held remote. Why is the wall mount control not operating fan with fans original receiver?
Depending on the age and brand of the fan it could have dip switches on the receiver, the part of the remote control unit that is either up in the canopy of the fan or it may be built into the fan, and the wall control ie transmitter may not be compatible with it. When replacing a remote control unit it is advisable to replace both since it could be either the receiver or transmitter.
Jan 03, 2017 | Dryers
We have a carriers air con that is about 4 yrs old it has a remote control and digital readings on the unit it is in the wall we can not get it to heat but it does cool we didnt put this in it was here...
Normally all air-cons carry an identifying label on the compressor unit. It has to by law state the gas used. On a split system this would normally be on the outside unit. Sometimes an additional label will be on one of the ends of the inside unit. Some units only do cooling - you need to check once you've found information. Check your remote control 'Mode' setting is correct - it should show a small 'sun' to indicate heating. A small 'icicle' looks similar, but means cooling. Then check temp setting is high enough to cause heating.
Jun 12, 2011 | Carrier Heating & Cooling
Problem with remote will not switch unit on or off
May be transmission problem. Replace new battery in remote and check. If not,check with camera phone focusing on transmission signal of your remote. Press any button in remote. If ultra light flashes, your remote is o.k. Other wise repair PCB where receiving sensor problem.
Dec 29, 2010 | Carrier (52PE315) Thru-Wall/Window Air...
I have a carrier wall heater with a remote, and I don't have the directions for the remote. I can't turn the heater on! I press the power symbol, but nothing happens.
Hi, Sally378, I may need to get any model numbers you may have for the remote or the unit to solve this. If this remote has batteries you may want to change them to see if this takes care of it. If not, send me the model numbers from both the remote and unit itself.
Sincerely,
Shastalaker7
Jan 30, 2010 | Carrier XHD183D Air Conditioner
Air conditionder
you can replace the blades but they come as a set. you cant get a single blade. As for the shutter you just have to get it replaced.. I can help you find the spares online if you like..
Jun 16, 2008 | Carrier BCA101R Air Conditioner
Incorrect Wiring for Thermostat
Do it right. Have the wiring changed so it works as it is supposed to. The remote control would make controlling the heat a manual operation. I don't think you want this.
May 01, 2008 | Carrier 52CQ315 Air Conditioner
Carrier BCA101R Air Conditioner Logo
130 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
