Question about Samsung ML 2010 Laser Printer
Black dot in left margin.
I just replace my cartridge, and now I get a black dot printed every one and one half inches the length of the paper. They are a half inch in from the left edge.
    Brigadier General:
  • 6,966 Answers
If the black dots were not present with the old cartridge, then one can only suspect the new cartridge at fault. This rarely happens but it do happen. Chances are that there is a defect on the drum inside the new cartridge. You can visually check for this imperfection by removing the cartridge and sliding the protective cover to partially expose the drum (not in direct sunlight as they are light sensitive). There is a white gear at the side that you can manually rotate ( a bit stiff) to check for the possible fault. you can approximate the possible location by aligning a printed paper with the series of dots against the drum to give you an idea where to concentrate on.
Should this be the case, it is possible for you to return the new cartridge for a replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 19, 2008
2 Suggested Answers
SOURCE:
boyrevel
  • 71 Answers
SOURCE: 3 dots along the left margin of paper, after replacing the drum
Open the MP tray and place a new sheet of A4 paper on it.
Press and Hold the Clear/Back button and also press and hold the Left Arrow. The display should change to 'Drum Cleaning'
Press the OK button and it should clean the drum and print a sheet with smudges where your dots used to be.
You may need to repeat the procedure a few times.
Posted on Nov 01, 2010
Canon ImageClass D660
printhead needs to be cleaned and so does the black roller that the paper is printed onto.
Jul 24, 2008 | Canon imageCLASS D660 All-In-One Laser...
Apr 24, 2010 | Brother MFC-9440CN Laser Printer
The printer prints with a smudged black line the length of the left margin of the page.
We recommend replacing the cartridge as a first step. If that does not correct the problem, we look for toner dust inside the printer. DO NOT VACUUM this dust as it is very fine and will go through your vac bag and create dust everywhere. Finally we look for finger prints and pieces of paper.
If the toner is able to be rubbed off the paper, it is a fuser issue. Replacement of the fuser will be needed.
Sep 10, 2009 | HP LaserJet 1020 Printer
11 blue dots print out down the left hand side of documents
It's probably the toner cartridge again. See if you can spot defects at the cyan drum unit that matches the marks on your printout.
Apr 14, 2009 | HP LaserJet 4600dn Color Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Black bullets down left side of paper
inspect the pc drum, if there is no dots, then its ok, also inspect fusing unit rollers and transfer belt for dots and clean laser glass.
Apr 24, 2008 | Konica Minolta magicolor 2300DL Laser...
Landscape print gives dots or lines in the upper margin
unplog your printer.clean your printhead of the printer by a tissue paper.
Feb 03, 2008 | HP PSC 1510 All-In-One InkJet Printer
Brother laser printer printout
You need to clean your drum unit:
see http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001044&Sympt=The+print+jobs+have+black+spots+or+black+dots.+How+can+I+improve+the+print+quality%3f&Model=3&ProductGroup=1&Keyword=dot&ProductID=HL2040
Worked for me!!
Dec 19, 2007 | Office Equipment & Supplies
Black Streaks on Edges of Paper
This can be one of two
Print cartridge (you can do it, replace toner cartridge)
or Fuser (needs to go to doctors)
stop a print half way threw to confirm that it is print cartridge, good chance it is.
Links to my previous post on this problem below
HERE and HERE
Nov 17, 2007 | HP LaserJet 4L Printer
Samsung ML 2010 Laser Printer Logo
88 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
