Question about Panasonic CT-27SX11 27" TV
Top half of picture blanked off. Bottom half does not indicate any deflection problems.
    Problem Solver:
  • 16 Answers
The problem is in your deflection coil, the other half had been shorted probably.
Posted on Apr 25, 2008
SOURCE:
Tv 27" has only half screen picture horizional I
Possible failure of the VERTICAL SECTION of the deflection circuit. It is possible that the areas related to the vertical circuit is checked , check for weak capacitors near the output vertical drive. Also a faulty vertical coil- deflection coil- can result in half picture.
A vertical signal test can confirm.
Oct 16, 2011 | GE Televison & Video
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
I HAVE A HALF SCREEN. BOTTOM HALF LOOKS GOOD TOP HALF HAS WHITE LINES WITH A BIGGER WHITE LINE SEPARATING THE TWO. IS THE PICTURE TUBE GONE OR IS THERE AN ADJUSTMENT I CAN MAKE? TV IS A RCA F25645
This is commonly known as a vertical deflection problem. It cannot be fixed with an adjustment, but requires changing some electronic components. Namely the vertical output IC (integrated circuit) and in addition usually in this model a resistor which may appear to be burned.
Jun 15, 2011 | RCA F25645 25" TV
Turn on tv and get full screen but after 5 minutes half the screen starts to scramble then goes blank leaving me with half ascreen
I would suspect your power supply deflection board is failing. Normally these tvs have a problem with the hyper board in which the image is scrambled and then clears up. Your problem is just the opposite and indicates a part is heating up on the power board. A good visual look at the board will be your best starting point. Look for burn marks, a capacitor that is rounded on top or leaking. Also look carefully to ensure your CRT bulbs have not leaked fluid onto one of the boards.
It's a starting point.
Feb 24, 2011 | Toshiba 57H81 57" Rear Projection...
The top half of my screen is black, the bottom half shows the "top half" of the picutre.
Hi there.
It sounds like a vertical problem. And by the description you`ve given it might be caused by bad capacitors in the vertical deflection circuit.
Hope this help Merry Christmas
Dec 19, 2009 | Televison & Video
Problem in my HITACHI CMT2153 TV
hi, the problem is in the vertical ossilation if only u can trace the bad component.. let me know
Jan 10, 2008 | Televison & Video
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Half a picture in black
Witch part of the screen you loose?if is the bottom or the top it could be a problem in the vertical IC circuit if is the left side or the right side is a problem on the horizontal deflection circuit(very rare),try taping on the set when it does it and see if the pix reacts ,if it does one way or the other you have loose conections and some resoldering need to be done.If you are familiar with tv circuitry you will have no problem.If you are not be safe and call for help.
Sep 19, 2006 | Mitsubishi (WB2000)
Panasonic CT-27SX11 27" TV Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
