1997 Volvo 850 Logo
Posted on Apr 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water loss from cooling system - 1997 Volvo 850
Mitchell Fleming
Level 3:
  • Master 427 Answers
  • Posted on Apr 13, 2010
Mitchell Fleming
Master
Level 3:
Answers
427
Questions
0
Helped
89981
Points
1018
You have to get collant testing pump it clips on radiator cap and you pump up to 20 lbs of pressure if yoy can hear or see leak fix it if yoy cant its probably a head gasket
Water loosing cooling system
If your Hyundai H1 2018 model is losing water from the radiator at an alarming rate, even with a new radiator that is not leaking, there are a few potential causes for this issue:
  1. Coolant leak: While you mentioned that the radiator is not leaking, there could still be a coolant leak elsewhere in the cooling system. Check for any visible signs of coolant leakage, such as puddles under the vehicle or wet spots on hoses, connections, or the engine. Coolant leaks can occur at various points, including hoses, water pump, heater core, or even the engine block itself. If you cannot identify any external leaks, it is possible that the leak is internal, such as a blown head gasket or a cracked engine block.
  2. Faulty radiator cap: The radiator cap plays a crucial role in maintaining the proper pressure and preventing coolant loss. A faulty radiator cap can cause coolant to escape from the system. Inspect the radiator cap for any signs of damage, such as a worn-out gasket or a cracked cap. If necessary, replace the radiator cap with a new one and see if it resolves the issue.
  3. Internal engine issue: Internal engine problems, such as a blown head gasket or a cracked engine block, can cause coolant to mix with the combustion chamber or leak into the oil system. This can result in rapid coolant loss without any visible external leaks. Look for symptoms such as white exhaust smoke, coolant in the oil (appearing as a milky substance on the oil dipstick), or an overheating engine. If you suspect an internal engine issue, it is recommended to have the vehicle inspected by a qualified mechanic to diagnose and address the problem.
  4. Improper coolant filling or air pockets: If the coolant was not properly filled or if there are air pockets in the cooling system, it can cause coolant loss. Air pockets can prevent the proper circulation of coolant and result in overheating and coolant loss. In such cases, bleeding the cooling system to remove air pockets and ensuring the coolant level is at the correct level may resolve the issue.
Given the significance of the coolant loss and the potential complexity of the underlying problem, it is advisable to have your Hyundai H1 2018 model inspected and diagnosed by a qualified mechanic or Hyundai service center. They will have the expertise and necessary diagnostic equipment to identify the specific cause of the coolant loss and provide the appropriate repairs or solutions.
1999 Cadillac Eldorado ,overheating changed thermostat , overflow cap ,no white smoke coming from exhaust.hot blowing from heater
Are the cooling fans coming on ? Go under the hood in the engine compartment , with the vehicle running have some one turn on the A/C , do you see and or hear the cooling fans come on ? Could be the coolant temperature gauge is bad ! How many miles on the vehicle ? Ever have water pump replaced ?
Check for a loss of system pressure.
Is there a loss of system pressure?
Go to Step 2 yes
Go to Step 3 no
Inspect and repair any faulty hose connections.
Does the engine still overheat?
Go to Step 3 yes
System OK
Check for low coolant protection (-37?°C/-34?°F).
Is there low coolant protection (-37?°C/-34?°F)?
Go to Step 4 yes
Go to Step 5 no
Test solution. Replace the coolant if necessary.
Go to Step 5 yes
System OK
5
Check the water pump belt for low tension.
Is the water pump belt tension too low?
Go to Step 6 yes
Go to Step 7 no
6
Replace the water pump belt tensioner.
Go to Step 7 yes
System OK
7
Check for an inoperative thermostat bypass.
Is the thermostat bypass inoperative?
Go to Step 8 yes
Go to Step 9 no
8
Replace the bypass.
Go to Step 9 yes
System OK
9
Check the water pump.
Is the water pump inoperative?
Go to Step 10 yes
Go to Step 11 no
10
Replace the water pump.
Go to Step 11 yes
System OK
11
Check the radiator fins for obstruction.
Are the radiator fins obstructed?
Go to Step 12 yes
Go to Step 13 no
12
Inspect and clean the radiator fans.
Go to Step 13 yes
System OK
13
Check the cooling system passage for obstruction.
Is the cooling system passage blocked?
Go to Step 14 yes
Go to Step 15 no
14
Inspect and flush the system. Reroute or replace the hose if necessary.
Go to Step 15 yes
System OK
15
Check the water pump belt for damage.
Is the water pump belt damaged?
Go to Step 16 yes
Go to Step 17 no
16
Replace the water pump belt.
Go to step 17 yes
System OK
17
Check the cooling fans.
Are the cooling fans inoperative?
Go to Step 18 yes
Go to Step 19 no
18
  1. Inspect the electrical connector. Replace if necessary.
  2. Does the engine still overheat?
Go to Step 19 yes
System OK
19
Check the throttle body circuit flow.
Is the throttle body circuit flow restricted?
Go to Step 20
Go to Step 21
20
  1. Inspect the orifice and associated hose. Replace if necessary.
Go to Step 21
System OK
21
Check for a stuck thermostat.
Is the thermostat stuck in the closed position?
Go to Step 22
22
Replace the thermostat.
System OK
How can i bleed the existing air on engine system so the right amount of water goes through the system? It a 2005 VW Polo 1.6 Hatchback.
one way to bleed out of a cooling system is to
open the heater control
ensure that the engine is cool,
loosen off the highest coolant hose ( normally a heater hose
run the engine so that coolant is circulated
when all air is out tighten the hose clamp
keep water loss to a minimum by only having the loose hose drip
My car is slow in starting making white smoke when fires up smells a bit fuel y.it is also low in power when driving under 2500 revs.any ideas to this problem not believe to be maf or air sensor
White smoke is usually a sign that there is a problem with the cooling system. Blue smoke is fuel related.
Have the cooling system checked at a guess I would say this is water leaking into the cylinders which indicates a cylinder head gasket fault. A faulty cylinder head gasket would also cause slight loss of compression which could explain the loss of power. remove the oil filler cap on the engine if there is a sign of a light brown (cream) coloured substance (water contaminated oil) on the cap or in the cover then the head gasket needs replacing also check the dipstick.
Hope this helps.
Water loss
If you mean coolant loss, then you need to pressure test the cooling system to see where it's leaking from.
Car is over heating what could it be
I assume you have checked the cooling system to ensure that first, that it is completely full of coolant (not just the overflow tank) with no air locks and second that there are no leaks and the radiator cap is in good condition. The heater hoses and those pesky little bypass hoses in the cooling system tend to go hard and split if they are over 10 years old, allowing coolant loss. Those spring type hose clamps tend to be less effective in clamping as the hoses become hard. Worm drive ones are the best to use.
If there are no leaks or air locks, the over heating could also be caused by a clogged radiator (more than 15% restriction in the radiator flow capacity will cause overheating problems), a faulty water pump or a faulty thermostat.
If there are no leaks but undetected loss of coolant, then it could indicate a problem with the head gasket (Usually caused by allowing engine to become excessively overheated when cooling system has run dry) allowing high pressure combustion gases into the engine water jacket, which super heats the coolant which then boils off, and is released via the cap.
If unsure take vehicle to cooling system specialist and have them do a pressure test and more thorough diagnosis.
The car is overheating i do not know where the thermostat is
I assume you have checked the cooling system to ensure that first that it is full of coolant and second that there are no leaks and the radiator cap is in good condition. The heater hoses and those pesky little bypass hoses in the cooling system tend to go hard and split if they are over 10 years old, allowing coolant loss. If there are no leaks or air locks, the over heating could also be caused by a clogged radiator (more than 15% restriction in the radiator flow capacity will cause overheating problems), a faulty water pump or as you suspect, a faulty thermostat.
1helpful
Power steering loss, overheating, dash board power
It sounds to me like the serpetine belt broke, DO NOT continue to drive it. The water pump (for engine cooling), the power steering pump, and the alternator (electrical system) are no longer operating. Have it towed to a shop or have someone put a new belt on it.
Hi i have a 4afc i have repalaced the water pump removed thermostat flushed radiator and block with garden hose and it is still over heating what could be left to do
possible blown head gasket and head repairs is in order.
combustion is leaking into cooling system
can do a few checks
T.K. head check
remove spark plugs when engine is warm with cooling system under pressure (radiator pressure tester)
leave for 10-20 minutes inspect for pressure loss
if so pressurise system and crank over with plugs removed and check for water (mist) commong out of cylinders
Top Volvo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Volvo Expert? Answer questions, earn points and help others
