I recently purchased a Lexmarrl X5400 printer.I can make a copy using ADF feed, but when I try to scan , I get a message that says, "Cannot retrieve applications" Please tell me how to rectify this problem, Thanks, Don
    Genius:
  • 1,027 Answers
I believe you must select a different application to use for the Scan.
Click the cancel
From the ALL-IN-ONE center scanning and copying tab, choose a different application from the "SEND SCANNED IMAGE TO" menu.
Posted on Mar 19, 2008
Copy off glass copy is good. copy from ADF copy is blurry
The problem is either dirty glass for the ADF which you can clean, or the ADF cannot feed the paper you are trying to scan through accurately. Most smaller all in one printers use the same scanner element for both the ADF and flat glass scanning so the fact that glass scanning is fine points to the two problems listed above.
Mar 29, 2011 | Office Equipment & Supplies
HP OfficeJet 8500 ADF detects load, but does not detect feed. I have a brand new HP OfficeJet 8500. The ADF detects a document is loaded when I stick a piece of paper in it to be copied/scanned/faxed, but...
Remember that if you start to fiddle you void your guarantee, I know its a pain, but if I were you repack and either contact customer services and obtain a return invoice number if purchased over the internet and return to sellers. If purchased from a shop, return with your prove of purchase.
Mar 19, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I am not able to feed several documents into my Cannon MF6500 printer to be scanned. I can only scan one document at a time. How do I correct this so I can feed documents in to be scanned
Do you have problem with multiple copies or just wit puling scans?
Try to say that the original is feed from adf, clean rollers if you have trouble with copie too.
May 18, 2010 | Office Equipment & Supplies
Fax feed jams, accepts single copies only
Check for pieces of paper that could be stuck in the ADF unit. If that doesn't work your ADF rollers are smooth and you should try replacing them.
Jan 15, 2009 | HP Officejet J5780 All-In-One InkJet...
Hello, I have an HP OfficeJet 7310 all-in-one print/scanner/fax etc. I purchased about two years ago but don't use very often. Yesterday while I was trying to send a fax I received a loud winding-up...
I have same problem! The copy/scan function would feed the orginal from the ADF halfway and instead of making a normal loud feeding noise it made a horriable alarming sound and displayed an error message. To fix it: I waited a day or two and bang the top of the feeder cover with normal force while the original is feeding. It appeared the problem is resolved. I have no idea what the problem is, however I think if this work for few months at a time is fine by me.
Apr 12, 2008 | Office Equipment & Supplies
ADF jam
Turn off printer and unplug it from power supply.
Check ADF if it appears to be damaged ( open the top portion so that you can check the mechanisms ) unplug the ADF cable from back of scanner and replug it, replug power cable, turn it on and try scanning using adf again.
Feb 29, 2008 | Epson ACULASER CX11NF All-In-One Printer
Will not copy
If the paper isn't feeding in the ADF (automatic document feeder - upper paper feeder) then the ADF roller assembly will need to be replaced. Try a copy on the flat glass area. If it work, then it's the ADF, If not then the upper scanner assembly with have to be replaced.
Apr 28, 2007 | Canon imageCLASS D880 All-In-One Laser...
Computers & Internet Logo
David Payne
David Payne
