GPS Logo
Posted on Mar 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GARWIN NUVI GPS
We have a Garwin Nuvi GPS that keeps asking for a pin number to unlock the system. We have not entered a pin number. How can we unlock it without the pin number?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
506
Points
How do i get to the home page on my gps
A
Anonymous
Type 1111 then enter
SHARCNET-USA
Level 3:
  • GPS Master 2,130 Answers
  • Posted on Mar 19, 2008
SHARCNET-USA
GPS Master
Level 3:
Answers
2130
Questions
Helped
782180
Points
4950
The only way to do it is to go to the location you set as "home" in the GPS. When you are at that location, the GPS will not ask you for a PIN and you can then go in and change the PIN.
If you don't know what the home location is, you'll need to contact Garmin http://www.garmin.com
There are so many of these being stolen from vehicles, the PIN is designed to make the unit useless to thieves.
- Jim
Garmin nui 350 Tried everything. My brother-in-law past away recently and dont no his pin # . is it possiable to reset and use garwin ?
Going back to the security location will unlock the unit but in order to reset the pin code, the original pin code must be input.
To unlock the unit, it must be sent back to Garmin.
My garwin 1300 keeps going to another state, I have done the reset of turning it off and holding the right lower corner and then resetting, I have driven the car out to a parking lot and kept it plugged in...
Try to find your own home address (which you'll want to label as "Home").
From the main screen, select Where to>Address.
Change the State, if necessary. This will make your state the default for future searches.
Touch "Spell City" and enter your city name or zip code.
Enter your house number, and touch Done.
Enter the street name, and touch Done.
Select the correct street on the list, if necessary.
Select it. You'll have the opportunity to Save your address as "Home".
Good luck.
I WOULD LIKE TO REGISTER MY GARWIN NUVI 14901 T GPS
  1. Connect your satnav to your computer
  2. Go to www.garmin.com
  3. Select your country from the drop-down list
  4. Click on the myGarmin tab at the top of the page
  5. Click on "Register your garmin product"
  6. Follow the prompts
You'll be asked to create a username and password. Keep them safe as you'll need them to update your maps.
Dec 09, 2010 • GPS
I have moved to a new state and cannot get my garwin nuvi to recognize it.
Go to Where To...... Address.....on bottom of screen you will see Change State / Province
Oct 29, 2010 • Garmin GPS
How to unlock gurmin
this is the tips for you to unlock
follow this instruction:
  • Step 1 Lock the screen by touching the "Lock" button. To unlock the screen, press the "Power" button.
  • Step 2 Lock the device by pressing the wrench icon, then "System" and "Garmin Lock."
  • Step 3 Press "OK." Then enter a four-digit PIN when prompted. Select "OK."
  • Step 4 Drive to a security location then press the "Set" button. Now each time you turn on the Nuvi, it will ask for the PIN. Enter it when prompted or drive to your security location.
  • Step 5 Send the Nuvi to Garmin to get it unlocked if you forgot both the PIN and the security location.
  • 1helpful
    Owners manuel for garwin novi 885 T
    this should cover your model for the
    nuvi 885T
    Aug 16, 2009 • GPS
    How i can unlock my gps garmin nuvi 205 w
    Enter your PIN number, or take the unit back to the "Security Location" and it will unlock by itself. You can then enter a new PIN unlock code.
    1helpful
    The touch screen on our Garwin Nuvi 360 do not function.
    Unfortunatly there is a fine wire Grid below the surface of the glass, the grid detects where you are touching on the screen, with the glass being broken, the grid is broken, which will cause dead spots or regions on the touch screen. You will have to replace the Touch screen or the unit which ever is most cost effective.
    Hope this is of some help.
    Ed
    No TEXAS
    Turns out the nuvi 200 comes with only Canada and bordering US States (Alaska, Washington, Illinois etc.).  It needs a map upgrades for $99.
    Jul 03, 2008 • GPS
    Top GPS Experts
    ZJ Limited
    ZJ Limited
    ADMIN Andrew
    ADMIN Andrew
    Are you a GPS Expert? Answer questions, earn points and help others
