Technika MP3 player model MP407 2 GB
When in the settings mode I have selected random and shuffle all but it continues to play in Normal mode even tho' it is showing R and S on the LCD...any ideas for random play setting???
I don't know about the problem with the repeat setting but can suggest a software download (If there is one) but, i do know that the headphone problem is an wiring fault with in the jack port for the head phone. The only way to repair is to open the MP3 player and solder the componants back together. i am havin the problem of all the file have become corrupt and the player will not load properly or slowly or not at all. It has also deleted some of files and i was wondering if anyone knew how this problem can be resolved?
Posted on May 02, 2008
I bought a mp4 player 2 months ago through net when i brought theplayer it was working fine but now it has totally changed its keys arenot working properly and earphone socket also not working properly .When I [put my earphonesinto my mp4 u have 2 fiddle alote to get them in right so I can here...and also the earphones are working fine with other mp3 and mp4 playerso i don't think there is any problem in earphones
Posted on Mar 19, 2008
How to put it on shuffle
Menu Settings >> select Play Mode to select different playback options while in music mode >> Select random to play random tracks within a selected folder or among audio track outside a folder
Jan 06, 2012 | Eclipse CLD2 MP3 Player
Is there a way to put the device on shuffle mode?
  • There is a random setting rather than a shuffle mode. Same thing just a different name.
  • While in the play mode menu press "PREV/NEXT" to select the desired repeat mode ie.
  • Normal, Repeat One, Repeat All, Random, Random All, Preview.
  • You want to choose "Random" or Random All" depending on
  • Random - All music is played randomly until all songs have been heard.
  • Random All - All music will play randomly until you turn the MP3 player off.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 13, 2011 | Curtis MPS2015 MP3 Player
How do I turn the shuffle off?? I go to settings, choose music options, choose shuffle and highlight "on" and nothing I hit makes it change to "off". Help!!
For the Sansa Fuze, the selection Shuffle Mode is correct, just like you told:
In Main Menu > Music > Submenu > Music Options > Shuffle Mode:
1. Select Shuffle.
2. Use thumbwheel to choose Shuffle on or Shuffle off.
(to play songs in random order, set Shuffle to ON).
3. Press Select to change the Shuffle mode.
See page 9 (=page 6) of the manual in pdf format for the Sansa Fuze:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Thumbwheel: 5
Select button: 9
Jan 07, 2010 | SanDisk Sansa Fuse MP3 Player
How can I set it up to play random tracks, or one album only?
There is indeed a RANDOM option for this MP3 player. To access it play a song, while the song is playing press the button on the side of the player (the MODE button) Your screen will change. Select the option PLAY MODE. Then scroll down and select RANDOM.
Dec 26, 2009 | GPX ML648B MP3 Player
Can a gpx ML658B play continuously, folder by folder, or do you have to shuffle to hear all songs?
This is determined by the play mode. When playing a song press the MODE button on the side of the player. Then select PLAY MODE. Then choose which option best suits you. Repeat All will play through all of your folders and sub folders and Random will play anything randomly as far as I've been able to tell.
Nov 07, 2009 | GPX ML648B MP3 Player
Normal Play
Hello!!
If u have reset pin on the player .. try resetting it ...
Cheers!!
Aug 05, 2009 | SanDisk Sansa m240 MP3 Player
Cannot stop shuffling
You need to go into your Play Mode ssettings and select "Repeat All" to turn off this feature:
Play mode
You can set your player to play music tracks randomly (Shuffle All ) or repeatedly (Repeat One or
Repeat All ).
1. From the main menu, select Settings > Play mode.
2. Use the VERTICAL TOUCH STRIP to scroll up or down the options.
3. Press § to select an option.
4. Press § again to deselect an option.
Mar 14, 2009 | Philips GoGear HDD1830 MP3 Player
Music plays random selections
most of the time its either on random mode or on shuffle.....idk how your mp3 works but normally you can take it off by going to the menu and searching for shuffle or random....
Jan 29, 2009 | Jwin MP3 Player
GPX ML638B won't play random
When a song is playing, press the Menu button - select Play Mode - and take it off of Repeat
Jan 24, 2009 | GPX ML648B MP3 Player
Matsui MAT 140 MR mp3 player
If your Matsui is working suggest you leave well alone -- I've been looking for utilities (new firmware, reflash utility and firmware extractor) and it's all very confusing.
Apart from the ghastly menu system the only problem I've had with mine £8 ($16 used from a flea market) is that Win XP's data write-behind feature means that XP merrily suggests that file transfers are complete when the player is still digesting the files. If you interrupt this by mistake XP stops responding or complains that data has been lost.
Aug 29, 2008 | iLO (2 GB) MP3 Player
419 people viewed this question
 Grubhead
Grubhead
Steve Allison
Steve Allison
