Printer Problem Our HP Laser Jet 4200 is showing the error: "49.0665 service error". I need to know how I can fix it.
    Genius:
  • 1,027 Answers
Error occurred
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off, and then turn the printer on.
3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.)
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer.
5. Turn the printer off.
6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.)
7. Remove all EIO devices from the printer.
8. Turn the printer on.
9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device.
10. Replace a DIMM or EIO device if you determine that it causes the error.
11. Remember to reconnect all cables that connect the printer to the network or computer.
12. If the error persists, replace the firmware DIMM.
13. Replace the formatter.
Posted on Mar 19, 2008
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
HP 4200 Laser Jet Printer Error Code 82.0180 EIO 2 Error
The error message "83.0180" shows that an EIO error has occured.
Perform the following workaround and see whether the issue still persist.
1. Ensure that the printer is connected directly to the wall outlet.
2. Turn off the printer and then power on and see whether the issue persist.
3. Reseat the Jetdirect card and see whether the issue still persist.
4. Reseat the jetdirect card on a different slot and see whether the issue still persist.
5. Remove all the accessories from the printer and then power on the printer. See whether the issue still persist. If the issue does not persist, add on the accessories onee by one.
6. Power on the printer and check whether the issue persist, each time an accessories are added.
7. Swap the Jet direct card with a known good jet direct card and see whether the issue still persist.
8. Perform a cold reset and see whether the issue still persist.
To do a Cold Reset:
1. Remove all cables.
2. Press & hold the Test button while applying power & continue to hold it for 10 seconds, then release it for 10 seconds, then unplug it again.
3. Connect all cables & power it back up.
4. Wait 2 minutes for discovery & DHCP. If desired, change the DHCP & address settings.
May 07, 2010 | HP LaserJet 4200 Printer
HP Laser Jet 3055 printer-52 scanner error?
Remove the top cover. The laser / unit is a black box.
Try www.partsurfer.hp.com
to purchase one.
Jan 15, 2010 | Office Equipment & Supplies
SCANNER ERROR 12
in my laser jet M1005 printer showing the scanner error 12. kindly help me how i can solve the problem.
E-mail : jkmeher@yahoo.com
Jul 13, 2009 | HP LaserJet M1005 Printer
My hp 2420 printer show me an error 49.2FD9
power on your printer, after you see processing data the second time, press cancel.
Everytime I have seen this error is because the user tries to print a PDF file that is corrupt.
This has worked for me in the past.
and look here:
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1245403811282+28353475&threadId=74920
Jun 19, 2009 | HP LaserJet 2420 Printer
Install fuser
please reference the service manual from page 89 shows how to remove and reinstall the fuser unit, download from:
http://www.google.ca/search?hl=zh-CN&q=HP+2420+laser+jet+service+manual&btnG=Google+%E6%90%9C%E7%B4%A2&aq=f&oq=
choose second one PDF file and download for a while. then go to page 89.
hope help you to fix it , and please take a rating let me know how much helped you thanks!
May 16, 2009 | HP LaserJet 2420 Printer
Install jet direct in hp 4200
Hi , I need to know why do you require Jet direct . if its for admin then you can use jetadmin.
Apr 02, 2009 | HP JetDirect 4200 (j4117aaba) Print Server
Computers & Internet Logo
2,139 people viewed this question
David Payne
David Payne
