Question about Clarion VRX630 6.5 in. Flat Panel LCD Monitor
Monitor will not flip up
I installed the VRX630 in a 1999 Tahoe and the screen does come out horizontally, but it does not flip up. Not sure if there are two motors and one is not working or if it is simple enough where if I would hook up a video cable to a dvd player it would then flip up and the screen would go on. It was a floor model at a dealer, and I am pretty sure it is not ruined. Please help.
Horizontal screen size is too large all drivers are installed on winxp
This is Monitor Problem.you need an monitor service engineer.the problem is in Horizontal Deflection yoke/Horizontal output transistor section.
Nov 14, 2010 | LG Studioworks 563N 15" CRT Monitor
Monitor viewing position
what model of monitor do you have..?
May 18, 2008 | Philips Brilliance 107B 17" CRT Monitor
My monitor is verticle, won't flip back to
Try to use Cntl+Alt+Arrow keys to rotate the screen. Also go to display settings and change the monitor DPI setting will also resolve your problem.
Thank you for using Fixya.
Apr 02, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
KEYBOARD CHANGED MONITOR VIEW TO HORIZONTAL... NEED FIX
Try hitting "CTRL + ALT + An arrow key"
That should flip you right back!
Oct 03, 2008 | Logitech 967437-0403 Keyboard
Monitor display image
press control+alt+down(arrow key)
May 14, 2008 | AOC A15X221 15 in. LCD Television
ACER AL 1716
There are two types of lines.
Lines caused by a bad LCD screen and lines caused by poor sync.
A bad LCD will cause perfectly straight vertical and horizontal lines that don't move at all. This is because the row and column addressing ICs have gone bad, so you will end up with rows or columns of bad pixels.
Poor sync looks more like what you are describing. The picture will flip vertically and horizontally.
Poor or missing sync can be caused by a bad video cable, or a bad IC on the main board.
If the monitor has a removable video cable, borrow another one from a friend to test if the monitor is working. If it works, head to your local computer store and buy a new cable.
If the monitor still doesn't work with a different cable, you may have a bad main board. The only way to repair the monitor will be to replace the board.
If you open the monitor, be sure to check for bad capacitors. They can cause all sorts of strange faults. Look elsewhere on this site for how-tos on inspecting capacitors.
If your video cable is not removable, there's not much you can do. You will need a way to test that each pin on the cable connector on the main board conducts to a corresponding pin on the other end of the cable. You can do this if you have a multimeter, or a continuity tester.
Mar 28, 2008 | Acer AL1716 17" LCD Monitor
No picture in horizontal mode
make sure u have enough light while taking your pic in horizontal mode because the camera is in a different form then usual.
Nov 04, 2007 | Samsung SCH-u740 Cellular Phone
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
Monitor goes black with a white horizontal line across the middle of the screen
Check to see that the monitor cable is correctly installed. Also, make sure you have the most up-to-date drivers installed for your graphics adaptor card(both ATI and Nvidia carry catch-all driver programs to keep you up to date.) Tighten the cable screws of course, to make sure the monitor cable isnt just wiggling in its seating.
Jun 05, 2007 | LG Studioworks 900B 19" CRT Monitor
JWIN DVD player horizontal control
I had this problem and pressed all the keys until I hit the SYSTEM button on the remote control. All was fixed.
May 20, 2007 | Jwin JD-VD135 DVD Player
Clarion VRX630 6.5 in. Flat Panel LCD Monitor Logo
27 people viewed this question
Top Clarion Computers & Internet Experts
David Payne
David Payne
Are you a Clarion Computer and Internet Expert? Answer questions, earn points and help others
