Question about RCA HD52W59 HDTV Projection Television
Conversation all the # are feb 06 hd52w59 go65cgobs itc222a I think I need the tv code to put the conversation option back on the cable guy hocked up the hd box did something when the cable was turned off the conversation option was gone
  • bsammy Mar 27, 2008
    how do i fix the power bd because the convergence option is not there any more
Thank u i will try that u have been very helpful
Posted on Mar 30, 2008
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
The service # is hd52w59 and then something like yx1 or etc..... On the model # tag, this is written in very small writing. There is no way to remove the convergence option. Go to menu the set up and there you should find convergence. Choose convergence and run auto converge. If this does not work then there is a failure on the convergence power supply, convergence amp, or the deflection/power bd.
Posted on Mar 27, 2008
  • Les Price Mar 29, 2008
    First check all of the cp (circuit protect fuses) on the power board. I have seen open cps cause this problem. Most likely you will need to replace either the convergence power supply bd or the deflection/power bd.
WERE CAN I BUY AND HOW MUCH IS A FL231 FUSE FOR RCA HD52W59
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 26.00. Its listed under the RCA repair kits as the ITC222 & ITC222A convergence option missing repair kit. Its available at www.tvrepairworld.com
Dec 29, 2011 | RCA HD52W59 HDTV Projection Television
The tv is blue anr red looks like its in 3d
the ITC222 and ITC222A convergence option missing repair kit from www.tvrepairworld.com should solve that issue. The kit contains the parts and the CD with instructions
Aug 09, 2010 | RCA HD52W59 HDTV Projection Television
I have a RCA HD52w59 model an it needs conversion adjustment the picture has red,blue,anyellow around it tryed using menu button but no luck
the repair kit called the ITC222 and ITC222A convergence misssing repair kit should solve hat issue. The kit also contains instructions and is available from www.tvrepairworld.com
Apr 28, 2010 | RCA R52WM24 52" HDTV Projection Television
RCA HD52W59 TV Convergence problem
it is not to bad if Convergence are not moveing by the flyback
you see 3 fuse look like litte box in a row hit
tham, if the led in front of tv blink more then one your fly back is bad to,as you look at the board look at the cap.s on your board you see a cap,it a bout to blow. hope this help you out.
Aug 25, 2009 | RCA HD52W59 HDTV Projection Television
Television will not powwer on
Hello al1895,
This model of TV uses the ITC222A chassis. This is a common problem in this unit. The problem is usually centered around 4 capacitors (CP140, CP150, CP110, and CP114) They usually vent (becom bloated or puffy) and develop an internal short which causes the TV to shut down. This is usually caused by power surges (even when connected to a surge protector). The repair for this problem does not cost much, and I would suggest that you have a TV repair technician examine this TV due to the other problems that can happen with this chassis (ITC222A).
I hope this helps,
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Jul 27, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 Distorted colors and bowed pic.
in customer menu under setup do you have the convergence option. If you do not it probally be that fuse. this fuse is located on the main defection to the right of what know as flyback.. which is a large black component with two large red wires coming from it.
Nov 07, 2008 | RCA HD52W59 HDTV Projection Television
Blinks three times and turn off, with remote or manual
RCA > HD52W66
itc222a chassis
Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec.
http://home.austin.rr.com/doctorjoe/ITC222align.pdf
http://www.riddledtv.com/repair/RCA.html
Sep 30, 2008 | RCA HD52W59 HDTV Projection Television
I need a replacement tv screen for a rca hd52w59 itc222a
I have the 52" set of screens as well, if you still need them, email me @ Doin12volt@yahoo.com or just reply here.
Feb 13, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
180 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
