Question about Candy CPCA240FFK Bottom Freezer Refrigerator
Candy CPC240FF The fridge freezes everything whatever the dial is 1,2,3 or 4
Try to unplug the fridge
Posted on Mar 19, 2008
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
Hi ;vejust bought a candy fridge freezer model n0 turned dial to super lights were on constant but now the orange light is flashing what does this mean also some of my meat isnt freezing
What's the model number of your fridge and what type of meats are you putting in and how much at once and what's the temperature of the meat +-, I'll explain everything and give you the best solution.
Regards
Jun 07, 2016 | Candy Refrigerators
Ho wdo I get my small fridge (Frigidaire model no frc05l5db1) to stop freezing everything.
Sounds like the thermostat is not shutting the unit down and needs to be replaced to restore to proper operation.
Aug 21, 2015 | Refrigerators
Fridge is freezing everything
Check the top of the inside of the fridge. There is usually a flap door mechanism that sometimes falls off or sticks. This regulates the temp in the fridge.
Jan 29, 2014 | Amana ABB2524DE Bottom Freezer...
Refrigerator freezes everything in the refrigerator
Usually, there is a control knob/dial somewhere in the fridge. Did you try turning it to less power?
Nov 18, 2013 | Dometic RM2652 Refrigerator
Candy fridge ka lasse , fridge is freezing food inside
lower the temp in the fridge. a dial with numbers or range
don't touch the interior walls with the food
Apr 21, 2012 | Refrigerators
Refrigerator freezing food
Fridge thermostat dials are often problematical due to the ones that are numbered 1 to 10, is 1 the warmest or the coldest as the number is lower? Some companies put 'warmer' and 'colder' which avoids confusion. My advice, put it in the middle '5', and leave overnight, check the temperature in the morning with a fridge thermometer. Then change the thermostat dial to 8, and check it the next morning with a thermometer. The next day put it on 1, and leave overnight, check the temperature in the morning. If the thermostat has gone, all three morning temperatures will be the same.
You mention 'or as your website suggests', you know we are not Frigidaire or anything to do with the retailer? We are Fixya, people just like you, helping others. I am a caterer, and just happen to know about fridges. I get them repaired professionally, but always ask for a full explanation of what went wrong. We recently had a sandwich storage fridge that was freezing food, and it was the thermostat that needed replacing.
The things you did, cleaning the coils, will actually make the fridge run colder. The Defrost Thermostat is unlikely to be the problem, as when they don't work, the evaporator, the part that is where the chilled air comes from turns into a block of ice. When that happens, air can't pass through it and the fridge warms considerably.
Due to the damage this freezing is causing with your water and filter, I would suggest you call a service engineer and get it fixed professionally as you will be swapping out parts that are fine. Correct diagnosis is the key, and they will also check the gas pressure at the same time. Consumers can't work with refrigerant gas, it is *******.
Mar 14, 2017 | Frigidaire Refrigerators
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
231 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
