Question about Nintendo DS Lite Console
Ds screen just flickers
Just fitted a new ribbon cable to my ds and i still have the same problem.
screen flickers for a split second and then it turns off.
do i need a new screen?
thanks
dee
    Sergeant:
    Champion:
  • 250 Answers
Check all the ribbon cables and make sure they are all the way in. The flickering screen tells you it's probably one of the cables not on that screen. These cables go in a lot further than you might think.
Posted on Mar 29, 2008
There is green light but no display when ribbon cable is pressured
Hi
I suspect the screen ribbon cable has a small split in it and would need replacing
Apr 02, 2014 | Nintendo DS Lite Console
WHEN I TURN ON MY DS, THE SCREEN FLICKERS AND THE NOTHING! Mickey D
Well,
I had my ds do that before, I had to get a new one 2 gamestop but see if u can get it replaced, hope this helped!!
Jan 11, 2011 | Nintendo DS Console
Cannot power up the DS Nintendo. The light will come on for a split second and than go off again.
I bet you have replaced a screen or opened the DS. The ribbon cables for the screens have to be securely located and ALL THE WAY into the holders otherwise the DS lights to show an error. the ribbon cable error looks like this when you power on--- Dim green for a second then bright pulse green then off.
If this is happening its a cable error RE-SEAT even if you think they are. If you get that error it is deffinately cable.
Jun 21, 2010 | Nintendo DS Lite Console
Hinge on right side is cracked. When it is
The right hand side hinge has the ribbon cable for the top screen inside and the 2 wires for ths mic and wireless, chances are the ribbon cable has become damaged, therefore the top screen will proberly need replacing.
Jan 18, 2010 | Nintendo DS Lite Console
Bottom screen on ds lite flickers
check the cable first it might not be in the ribbon connecter properly, if everything looks ok chances are youll need to replace the screen.
Jan 17, 2010 | Nintendo DS Lite Console
My ds lite images on the top screen flickering.
Open up the DS and then unseat and reseat the ribbon cable that goes to the screen.
Once you do that, turn on the DS and if the screen is still flickering then the screen will need to be replaced.
Here is a tutorial on how to open up the DS and what the ribbon cable looks like:
http://www.instructables.com/id/Replace-the-top-screen-of-a-Nintendo-DS-without-o/
Sep 02, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Flickering screen
hey i think i got a solution, read the link i gave below credits to votahuan, its for adjusting screen flickers in both top and lower screen of ndsl, however i need you to do me a favor in return, hope you do not mind posting up the pics for me at renginez@yahoo.com once you found the two hidden screw at ndsl, im just having hard time finding it in fat nds, so i need a rough i dea of where it mite be located. Heere's the link anyways :-
LCD FLICKER SOLUTION
Jun 15, 2008 | Nintendo DS Lite Console
DS Lite's top screen has horizontal black lines
i found a REALLY easy solution! the most likley problem is that there is dust in the GBA/DS game card slot! it corrupts the connectors (i dont want 2 explain how it gets into the system) so step one: wrap a small peice of tissue around the stylus(make sure DS is turned ON)
step two: LIGHTLY go inside the GBA/DS slot with the tissue wrapped stylus.
step three: shut down DS system and turn on again
problem solved! hope this helps.
Apr 12, 2008 | Nintendo DS Console
DS Powering On
Hi, if the bottom screen briefly comes on with a white screen. There is a issue with the top screen, it is either the top screen itself or if there is damage to the hinge it will more than likely be the cheaper option the ribbon cable that threads though the hinge to the top screens PCB board.
Mar 16, 2008 | Nintendo DS Console
DS power problem
Hi Nerts,
These cables or ribbon cable and wire connects directly inside the upper LCD monitor. it is not feasible to replace these wires only.  I suggest you see about getting a replacement upper LCD screen which will give you the wires you need and a new screen to boot. Another porblem is the case itself is very hard to disassemble.  You will come near destroying the case to ge to the lcd.  You must disassemble the unit fully and put the correct curl in the ribbon cable to get it to fit right. In short, the price being what it is for a replacement LCD, and the trouble you have to go though to get this problem fixed, It may not be totally worth repairing. If you dont care and wish to do a repair, then my wishes for luck are with you.
Oct 18, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
520 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
