Maytag, admiral mod avv7000aww makes gringing noise underneath agitator. Agitator not engaging.
It's not an imbalanced load as it will do the same thing when there is no chothes, water at smallest load size. Makes noise in wash, rinse and spin cycles
SOURCE: maytag washing machine mod # LA882 top loader
HI. thanks for the question. well, not good news for you. the transmission has failed. has broken a gear inside. very costly .suggest buying new. A roper washer. good price. good washer. thanks the appliance doc. please rate my answer thanks.
SOURCE: How do I remove Kitchenaid Washing machine agitator?
with the palm orhte heel of yuor hand smack the top of agitaor, hte fabric softener cup will release.it doenst seperate to clen any furthetr though reccommnd soaking in hot water to clean out. reach down and pull up the opaque cover from the center of agitatr and there you will fond a 7/16 bolt holding the agitator to the tranny shaft. remove bolt adn PULL up
SOURCE: I own a Maytag Performa
sounds like you have a tub seal problem, which took out the bearings, I take it one buzy mom does lots of laundry! Maybe time for a new washer.
SOURCE: cant seperate the 2 pieces of my whirlpool ultimate care 2 agitator mod. lsq9544kocq
The following link should help you with removing the agitator to replace the dogs:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
Whirlpool models generally only have two methods of removing the agitator. One type uses a hex bolt, and the other uses a recessed square nut. The removal procedures are explained in the link provided. I hope this helps you. Please let me know if still have questions.
SOURCE: how to remove agitator
hi
The washing machine tub, or basket, generally doesn't cause problems. However, at times it may cause damage to the laundry, make a lot of noise, vibrate, or stop completely.
If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work -- or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
The agitator -- the finned part that fits on the tub shaft -- can also tear laundry if the fins are cracked or broken. You may be able to solve the problem temporarily by pinching off the splinters with pliers and lightly filing the plastic smooth, but this is just a stopgap measure; the agitator should be replaced. Replace a damaged agitator with a new one of the same type. To do this, unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator into place and replace the agitator cap.
Damage to the snubber, a padlike device sometimes located under the agitator cap, can cause the machine to vibrate excessively. The snubber may have a suspension spring in it. Lift off the agitator cap and examine the snubber. If the spring is broken, or if the pad is visibly worn, replace the entire snubber. Snubbers might also be found at the splash guard at the top of the tub, under the transmission, or as part of the water pump housing. Look around until you see it.
If the machine doesn't have a snubber, listen for noise at the suspension unit between the tub and the machine cabinet. The suspension unit has fins or pads that may need replacement. In some cases, the entire unit may have to be replaced. Another noise point is the basket support nut. Tighten the nut or, if you can't tighten it, replace it.
