Hard drive jumpers?
Can some one tell me what to put jumpers on if i already have 2 hdds in one as master and one as slave and this HDD shows on it a pic with 4 pins one pic having jumper on the 2 on the right which says "Limit to 1.5 Gb/s operation" and the other without any jumper says "3 Gb/s operation" and it came with the jumper on the right? any help would be great thanks.
  • Matt Marley Mar 19, 2008
    Also its Sata drive
  • 85 Answers
Well, I am guessing that you are adding an HDD? Anyway, I would try it on 3gb/s operation, and if you computer starts crashing, then put in on 1.5.
Posted on Mar 19, 2008
I have a extra hitachi hdd 30 gb ..i want it to be a external hard drive.. i reformat it already and the hitachi hdd 30gb is now in the external enclosure.. the problem now is that my computer didnt...
1. Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
2. To change the designation of a new drive to be a slave drive, skip to step 4.
3. To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
4. Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
5. Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
6. Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
Say "Thanks" by clicking the thumb icon in the post that helped you. Please click "YES" in solution that solves your problem as "was this helpful?"
Apr 18, 2011 | Hitachi TravelStar DK23EA Series DK23EA-30...
I have 2 HDDs installed on my pc,one is on ATA and it's used as Primary and one is on SATA (WD800JD) and i want to use it as Slave but doesnt appear on My Computer. I have tried with Add Hardware but it...
There should be jumpers on the back of both hard drives. You need to set the primary hard drive jumper to MASTER and the secondary hard drive jumper to SLAVE. Here is a picture of the jumper settings.
I hope this helps you.
Jan 17, 2011 | Western Digital Caviar SE WD800JD SATA...
How can i make my Samsung sp0802 hard drive become the master instead of the slave... thank you very much
Hi Good day!!! follow this
7. Install (or reinstall) the hard drive in the computer. (See "How to Install a Second Hard Drive.")
Don't forget to vote thanks!!!
Nov 02, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
What happen if i dont put jumper in a hard a hard drive?
If you don't put jumper in harddrive is detects it as cable select means if you connect your harddrive to middle socket of ide cable and then it detects it as slave but if you connect it at the end of ide cable it detects as slave.But make sure that otehr device is not set as master only 1 device is set as master or slave .
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Getting three beeps with my asus m4a785t-m motherboard initializi
Okay, not much else is mentioned about the system so I would assume you have one CD/DVD drive and now two HDDs and your new HDD is still set to factory default of "Cable Select" or CD, if not and the new hard drive is a replacement for a damaged OS (Operating System) drive, then you need to insert the Windows OS Installation disk prior to booting and set the system to check your CD-ROM before checking Hard disks, for the OS.
First off if IDE, you have a ribbon that resembles this [====[========[ the furthest to the right would be what plugs into you motherboard, being the one with the furthest distance between itself and the next plug/connector.The one on the other end is for the Master drive and teh middle one is for Slave.
If only one HDD, then the jumper for the new drive needs to be set to Master and the CD/DVD-ROM needs to be set to Slave.
  • If two HDDs & one CD/DVD Rom, On the primary IDE Controller, set the OS HDD to Master, the CD/DVD-Rom to Slave & put the second HDD on the secondary IDE Controller as Master.
  • If two HDDs & 2 CD/DVD-Roms they must be set up on totally different IDE controllers to cancel out the chance of cross-communication. This happens on some systems because of having two CD/DVD Roms and/or two IDEs. So, we set the OS HDD to Master on the Primary IDE Controller & we set the CD/DVD-Rom to Master on the second IDE controller and the
I would normally say that three beeps from the motherboard itself would be either graphics card or memory problems, normally solved by simply pulling either or both and reseating them. Wear Nitrile gloves (the blue ones) to keep oils and static charge from damaging the components, ground yourself &/or touch the case before and while pulling the components. Check this site for "Post Codes" if the beeps are coming from the MoBo... if you have Award BIOS (should show what BIOS brand when booting up the system)
Award BIOS Post Codes
If three beeps from the system itself, then that would say it can't find the OS... and you might possibly also find an error on the monitor, stating something similar to "no power to monitor".
If you don't have an illustration on your drive telling you what pins are for what when it comes to the jumper, then search google for the drive brand and the word "jumper" or words "jumper configuration" or "jumper placement"
example: Maxtor Jumper configuration
If the system is SATA only (I believe it to have at least one IDE controller unless the board's controllers are all blue & black, to which I see a controller, but can't tell if it is FDE or IDE), then you'll most likely have to enable the SATA controllers in BIOS and set the boot preference/sequence/order as mentioned above, to check the correct disk for the OS, after removable devices & CD-ROM. Should be that order anyway, with floppy seek disabled to save wear on the head.
Hope that was not too much and that it helps!
Apr 15, 2010 | Frigidaire FEQ1442ES Electric Dryer
How to set master, slave settings in sata hdd
In first HDD put the jumper in first vertical pair of pins from power socket side, it will become master and second HDD put jumper in second vertical pair of pins from power socket side it will become slave.
Regards
Ashly
Feb 02, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
I want to put another hdd in my older computer
Yes, you can use your other IDE plug.
Look at the jumper settings on the hard drives--one must be set to master and one to slave.
Or--you can set both to cable select, but that means your original hard drive has to be at the end of the cable (assuming you want it to still be the main drive).
There you go!
Apr 21, 2009 | Computers & Internet
Jumper Settings
If you leave it at cable select the cable will set the drive to either master or slave depending on where it is on the cable, the first or second connector. Just make sure any other drive hooked up is set to cable select.
Your best option is to actually set each drive to master and slave. Each drive should show you where to put the jumper. Make sure you only have one master and slave though.
Which jumper to use? The one thats already on the HD...?
:D
Check out this page for more information on Cable Select:
http://www.pcguide.com/ref/hdd/if/ide/confCS-c.html
Aug 22, 2008 | Maxtor Hard Drive
Computers & Internet Logo
746 people viewed this question
David Payne
David Payne
