Question about Avanquest MyDeluxeInvoices & Estimates for PC
File is locked up can not retrieve it or even open it
Tried to back up file on disk and locked up my current year invoices,
screen says:
EasyInv.exe has generated errors and will be closed restart program
an error log is being created
is there any help for this problem?
thanks Bob
  • Avanquest Master
  • 1,625 Answers
Do you have an earlier copy that can be restored, with just a few more entries needed? Also look in the EasyInv folder for a file starting with ~ to see if you can salvage a working version of the file.
Posted on Jan 28, 2018
4 Suggested Answers
SOURCE:
Kawika-56
  • 233 Answers
SOURCE: excel software not started
MS Office repair:
Go to the "Add and Remove Programs" in your Control panel. Click the "Change" and do the 'repair program' utility.
That should fix it, good as new.
Be sure to have your INSTALL disk handy (for all Microsoft products).
Posted on Oct 25, 2007
SOURCE: EasyInv.exe missed
I TOOK THE FILE FROM ANOTHER COMPUTER THAT HAD THE SAME PROGRAM IN IT, JUST MAKING COPY-PASTE TO THE RIGHT FILE LOCATION WITH A FLASH MEMORY.
Posted on Nov 13, 2008
  • 5 Answers
SOURCE: Invoice & Order Minimize Data Entry - Especially Name and Address
Do you have Microsoft Access? If so, you could use that to create a database and an invoice form. You could also use Access to "dump" the info into Excel to track and record.
Otherwise, try searching for "Import Data" in the Excel help. It would be very difficult to walk you through the whole process, but if you have specific questions about certain steps, that would be more manageable.
Posted on Jan 06, 2009
Invoices and estimates pro for window 8.1 64 bit
Unfortunately windows installs are a total jailbreak sometimes. the problem might be with the windows install, not the apps. Try repairing winndows. Put the windows disk in the drive and boot the system. There should be a repair option. Also, try the system file checker, sfc.exe:
Start a cmd prompt as administrator and type in:
sfc /scannow<enter>
You'll need the install disk in the drive for this. If that doesn't work, you'll probably need to reinstall windows from scratch. That sucks, but windows sucks, so you're stuck. After the install, run windows update until it says you're up to date and then install the problematic software first.
May 28, 2014 | Nova Development Invoices & Estimates Pro...
How do i do a factory reset on my toshiba satellite a100 laptop?? I havent used it in over a year and have forgotten my password and simply want to reset it. But the forums i read everywhere have not...
Unfortunately you need to have an installer of the windows. If you do not have a recovery dish I suggest you download the ISO of windows 7 from here: http://www.w7forums.com/threads/official-windows-7-sp1-iso-image-downloads.12325/ and then burn it on a DVD to make an installer disk. Then insert this disk in the computer you need to reset Follow through until you get to the option to open the Command Prompt, which you'll want to select.
First you'll want to type in the following command to backup the original sticky keys file:
copy c:\windows\system32\sethc.exe c:\
Then you'll copy the command prompt executable (cmd.exe) over top of the sticky keys executable:
copy c:\windows\system32\cmd.exe c:\windows\system32\sethc.exe
Once you get to the login screen, hit the Shift key 5 times, and you'll see an administrator mode command prompt.
Now to reset the password-just type the following command, replacing the username and password with the combination you want:
net user geek MyNewPassword.
hat's all there is to it. Now you can login.
Of course, you'll probably want to put the original sethc.exe file back, which you can do by rebooting into the installation CD, opening the command prompt, and copying the c:\sethc.exe file back to c:\windows\system32\sethc.exe.
Regards
David
Sep 18, 2013 | Computers & Internet
When I turn my netbook on it starts loading then prompts for "Current password", After typing the incorrect password in screen dispays "system will now HALT"
Seems you have forgotten your password you need to rest it. Unfortunately you need to have an installer of the windows if you do not have a recovry disk. If you do not have a recovery dish I suggest you download the ISO of windows 7 from here: http://www.w7forums.com/threads/official-windows-7-sp1-iso-image-downloads.12325/ and then burn it on a DVD to make an installer disk. Then insert this disk in the computer you need to reset Follow through until you get to the option to open the Command Prompt, which you'll want to select.
I'm trying to settle and its telling me that there are still open invoice and there is nothing currently on hold. Any suggestions??
Sounds like you have a corrupt invoice in your database. If you have a service contract with PCAmerica, contact them for a fix. If not, I can take a look.
[email protected]
Please return and give me a favorable rating if this helps or is of value to you.
Feel free to email me with more details if need be.
Aug 15, 2012 | Pc America Restaurant Pro Express
How to break xp admin password with limited account.. what ever i try to do it says access denied.. when i go to safe mood it says type Admin password. plz help me...
Did you try blank password when you are prompted to enter the admin password on the Safe Mode logon screen? If not please try it, most pcs admin password is blank (empty). Good luck. Thanks for using FixYa.
Jun 12, 2010 | Computers & Internet
In the process of installation of the disk #1 the following message appears: cannot open input source current file: DSSAGENT.EXE Thank you for your prompt help
As this could be spyware, try to run the http://live.sysinternals.com/ and run the procexp.exe to see a more detailed task manager...
dssagent.exe is a virus, trojan, spyware, adware which you can remove, or a file belonging to a Windows system or an application you can trust.
ssagent.exe is located in a subfolder of C:\Windows. Known file sizes on Windows XP are 546,304 bytes (72% of all occurrence), 590,336 bytes, 69,162 bytes, 510,976 bytes.
File dssagent.exe is not a Windows core file. Program starts when Windows starts (see Registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run). The program has no visible window. It is located in the Windows folder, but it is not a Windows core file.
Mar 28, 2010 | The Learning Company Learn to Speak...
How do i retrieve my back up disk after a complete crash and restore, I have lost all my files and microsoft office which holds all my contact and invoice info. The disk created at the time will not boot...
Will the computer start and boot up at all? You said you did a restore.
If it will, you may be able to insert your backup disk after the computer boots and use Windows Explorer to view and copy your files back on to the hard drive.
If the computer won't boot, you can reinstall Windows and after it boots then try to use Windows Explorer to see if you can retrieve the files.
Mar 06, 2010 | Computers & Internet
I want to create an excel template that can automatically update the invoice number once i save it. say i have the excel template open with the curent invoice numbe as 5. once i save this file and i open...
Is it in a single-user environment? You can save the current invoice number to a text file then ope that and +1 (which is the way that the demonstartion Invoice in Excel 97 / 2000 used to do it ).
Feb 26, 2009 | Microsoft Excel 2000 Step by Step...
Can't run 1701 Ad with Windows XP SP3
Use restore point and go back to before SP3. Wait a couple of weeks and download it again. They should have the bugs out by then.
Dec 22, 2008 | Aspyr 1701 A.D. for Windows, Mac
EasyInv.exe missed
Nov 13, 2008 | Avanquest MyDeluxeInvoices & Estimates for...
Avanquest MyDeluxeInvoices & Estimates for PC Logo
Top Avanquest Computers & Internet Experts
Alun Cox
Ekse
Peter Dragonetti
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
