Question about Medion MD-1704 PC Desktop
ADDED NEW RAM NOW MEDION WON'T BOOT UP
I tried putting the 2 x 1gb sticks of ram in the same slots the original 256 mbs were in but the pc just locks up & doesn't even start windows. I can get a refund from the seller but have read various articles about having to put so many sticks in certain banks etc. So maybe it's just a matter of getting the right combination but i'm scared of hashing up my pc again. Its a Medion MD MT6 (8383xl) any suggestions or do u think the ram is faulty?
Anthea
  • Anthea Gilkinson
    Anthea Gilkinson Mar 19, 2008
    Erchamon92
    ram is this one
    2GB PC3200 DDR 400 RAM 400Mhz 2x 1GB 2 GB G DIMM MEMORY (230230563367)
    he will give me a refund no probs didn't work in his pc either, wrong specs.
    Tried all sorts of combinations, it did try to start with all 4 in but windows wouldn't load.
    motherboard number printed between the video and pci expansion slots? MS 7091 VERS 10
  • Steve Carpenter May 11, 2010
    Hello Anthea.
    What is the spec of the memory you bought? (DDR400, PC-3200 etc)
    Have you tried the modules in your pc one at a time?
    Where did you buy the new memory modules from? What did they say when you asked for a refund?
    Could you give me the motherboard number printed between the video and pci expansion slots? I can then find out exactly what your motherboard will support.
    erch.
  • 88 Answers
I would guess that it's high density memory. Ebay is flooded with it. Read the following article, it's claims are a bit bolder than they ought to be regarding the number of boards that will accept high density memory modules, but the rest is fact.
eBay Guides - Myth Low Density vs High Density memory modules
You'd be better getting your memory from places like microdirect or ebuyer.
Hope that helps. Please remember to rate this solution if you found it useful. Thanks for using FixYa,
erch.
Posted on Mar 19, 2008
  • 117 Answers
Hi
i needs to the rams are in same speed. if it not you put a rams in same speed
next you need to study your motherboard manual it supports the ram speed.if ever this is ok. then your ram will be faulty
    Problem Solver:
  • 16 Answers
You know that there is a limit of amount of ram on your motherboard, try check google for it.
Posted on May 31, 2009
  • 41 Answers
My guess is that the RAM isn't as fast as the original memory. Turn down any overclocking, also in the BIOS set the CAS latency to match the new RAM. I had exact same issue, and found that the RAM I purchased was CAS2.5 where my previous RAM was CAS2.0 The system was set for 2.0, and the slower 2.5 memory just made my PC lock up. I changed the BIOS CAS LAtency, and it works fine (But kinda bummed that the ram is a touch slower)
To Fix, go into BIOS Setup (Usually Del, or a function key while booting)
Find CAS Latency, should be under advanced settings or something like this.
Change to a higher number (Higher number = slower)
Good Luck!
Installed RAM and now monitor has no display. I
The splash screen with the LG Flatron logo is the monitor's splash screen not the PCs.
The machine is NOT booting up the splash screen is the monitor coming on.
Remove the 1Gb stick an see if the machine performs normally.
If it does then power it off, remove the power cord and CAREFULLY reinstall the new stick.
If it fails to boot you may have a defective memory module.
If the machine fails to boot with the new stick removed make sure you have the original memory seated properly and all cables securely attached
Jan 03, 2011 | EliteGroup Computers & Internet
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times,...
hello
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
i hope this helps --
Dec 09, 2010 | Dell Dimension 4600 PC Desktop
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
Can i mix my RAM?
You can surely use one stick of 512 and other of 256. Just make sure you are not mixing a DDR with DDR 2.
Please get back for any further clarification
Thank you for choosing Fixya
Mar 28, 2010 | Computers & Internet
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
I currently have just 256mps of memory ram on my dell dimension 2400. i want to upgrade. my manual says the maxium is 1024 mbs. can i install 1gb of ram or should i get 512 mbs? i have windows xp os. thank...
1024 is 1 gig of ram. Some older motherboards require you to put in ram in pairs but I don't think your system is one of those but if you have manual or can download manual you should check to be sure. If you don't need a pair then yes you can remove the 256 meg stick and add a 1 gig stick or you can put in 2 512 meg sticks. Should run a lot better as windows recommends at least 512 megs of ram.
Nov 20, 2009 | Computers & Internet
Laptop doesn't recognize new ram
I would guess that you need PC 133. Some manufactures that were using SDram at the time required PC133 while others would require but allow you to use PC100.
This is the requirement for your laptop from www.crucial.com
Each memory slot can hold SDRAM, PC133 with a maximum of 256MB per slot.*
Hope this helps
Apr 09, 2009 | Gateway Computers & Internet
Dell 6000 Inspirion wont boot after trying to replace RAM
use ac power
try the 1 gig in each slot make sure it's secure.
If system still won't boot
then restart and try to get into bios setup
then set to default settings restart
if still not successful then replace the old ram make sure it's secure in the slots and restart
Then i would suggest taking new ram back and if you give them your make and model they can suggest ram for you
Feb 15, 2009 | Dell INSPIRON 6000 CENTRINO...
Memory upgrade
There is many things that can happen with RAM that end up with this issue.
First I'd try removing the 256 and just place the 512mb stick into the first slot and see if that works. If it doesn't there's one of three problems occuring.
Incompatible RAM (which may fit and lock in place but still not meet the requirements systems BIOS, so it will not function)
Oversized RAM Stick (some models will only use single sided sticks of ram, where most of the newer sticks are double sided. This can actually cause problems like this and even sometimes work but only show half of the ram on that stick)
Dead Ram (It's possible and I've had it happen a few times, that you could have a dead stick of RAM. If the 512 stick works alone without the 256 in there; the the problem lies elsewhere.)
Each manufacturer has different specifications on their systems and the ram that they can use. Believe it or not, one laptop I had would only work if you had two matching sticks of RAM in the slots. So, I could use the two 256mb sticks together; but I couldn't use a 512 and a 256. I couldn't run the 1gb stick and a 256 or a 512 stick. It had to be two matching sizes. So, make absolutely sure you have a compatible stick of ram for the laptop (I suggest calling HP/Compaq and asking them if it is the correct chip as you can never be too sure). If it still will not work, then either the laptop won't support all of the 768mb, or you have a dead stick.
Try these things and see what happens. If you still have a problem, by all means, ask away. :)
Sep 10, 2008 | HP Compaq Evo Notebook N410c
IBM a20m ram issues
If they are compatible but your machine isn't happy with them, it sounds like they're faulty. Return both sticks to the retailer and ask them to replace both, just in case they replace the good one and give you the faulty one back.
May 26, 2008 | IBM ThinkPad A20M Notebook
Medion MD-1704 PC Desktop Logo
1,122 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
