Question about Encore ENP832-TX-PCSU PCMCIA Network Adapter
Encore modem how do we configure our encore endsl-4 2+R It worked before and since we got turned off at&t for deleting our phone line and only having the dsl line we can not get back online. At&T is telling us we have a signal but the modem is not comunicating with the computer. All lights are solid except the data line. Can not find the right product on the product line
    Problem Solver:
  • 6 Answers
As far as I've seen, the data line light on the modem should indicate whether the data signal is coming through from AT&T or not, so I'd suspect that there is a problem with the signal from AT&T rather than between your modem and computer.
It is possible that the data signal lapsed for a while and your modem thinks it's still not there without actually looking. You can try unplugging your modem from it's power for about a minute (at least 30 seconds) and then replugging it in afterwards. That sometimes allows it to see the new data signal if it lapsed previously for any reason. After all lights light up (especially the data one), then try to go online again. If that doesn't work, try restarting the computer and if that doesn't work I'd try to talk to someone higher up in the AT&T support and explain about the data signal not showing on the modem so you can get them to fix it.
Hope that helps! :)
-Aloha!
Posted on Apr 11, 2008
Got new modem and cant get router ti work
What exactly is the issue?
Do you want to connect it to laptop via wire cable or Wireless.
For wired it maynot need any configuration but for Wireless it will surely need one.
Mar 12, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
I want Encore ( Model : ENDSL-A2+R2 ) Driver For USB For x64 ( Windows XP and Windows 7 )
This is an Ethernet based modem. As a result, no drivers are required, since you are connecting to it via Ethernet connection.
Please follow the directions in the user manual to set up your computer to connect to this modem. The user manual is available here:
(click here)
Thanks for using FixYz
Feb 13, 2011 | Computers & Internet
I was sold an Encore V.92/56K USB modem for my MacBook Pro -- will this work? And what do I do? Willard Jenkins
Is this modem?
http://www.encore-usa.com/mr/sites/default/files/product_file_datasheet/ENF656-USB-MOTO_spec.pdf
According to the official web page of Encore (http://www.encore-usa.com), that modem only has support for Windows systems. You will need another kind of compatible device to use dial-up on your MacBook Pro. You should consider something like the AirPort M8799LL/A which has an integrated "phone" modem.
Jan 10, 2011 | Computers & Internet
How do i configure my Encore ENHWI-G2 router?
a user manual is here http://www.encore-usa.com/download/manual/ENHWI-G2_Manual.pdf Power everything off connect the modem to the WAN port on the router - switch on the modem - allow lights to settle switch on the router - allow lights to settle
you can loginto the router and setup according to your ISP instructions you should be able to log onto the ISP website and see what settings are required Often the default settings in a router and connected to a modem will work
Mar 14, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
Inter Tel Encore will not roll over
That is not a function of the phone system. You need to call your telephone company and have them configure your lines to hunt
Dec 15, 2008 | Inter-Tel Encore Phone
Internet connection speed of the Encore ENHWI-G2
if you're router is in the B+G setting, try setting it to the B setting, this is because the wireless adapter in the i-phone/i-touch uses only the B setting, sucks for most part.. but that got my i-phone working like a charm.. hope this helps
Jul 16, 2008 | Encore 802.11G WIRELESS LAN ROUTER...
Encore 802.11
What's the brand of your router?? did you already configure the router to work with your modem and ISP?
May 08, 2008 | Encore 802.11G WIRELESS LAN ROUTER...
Need your help
can you get online directly to your modem? Is that a new router or working before? If it's a new router you need to configure it first to work with your isp if its working before better check first if you have internet from your modem..
Apr 22, 2008 | Encore 802.11G WIRELESS LAN ROUTER...
This is samer
go to the link below and the site will forward them for you http://www.portforward.com/english/routers/port_forwarding/Encore/ENDSL-AR4/ENDSL-AR4index.htm
Sep 11, 2007 | Computers & Internet
Error code 680 when I try to connect to my server
The error 680 means There is no dial tone. The modem is not detecting a dial tone There are many possible causes of a No Dial Tone Error. 1.Check cable is correctly inserted into back of modem and phone socket 2.Check properties of connection, make sure correct modem is being used 3.Disable "wait for dialtone before dialing" in My Computer > Dial Up Networking > Properties of Connectoid > Configure > Connection > remove checkmark under call preferences 4.Try removing fax machines or other devices connected to the line 5.Make sure no one is using the telephone when trying to connect
Jul 07, 2007 | Actiontec (GT701) Modem
Encore ENP832-TX-PCSU PCMCIA Network Adapter Logo
50 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
