Question about Kenwood KDC-MP205 CD Player
Protect on the Display
On the display screen it keep say protect and it wont let me do anything else
  • 6 more comments
  • khova5 Mar 19, 2008
    the model number is mp205
  • Anonymous Mar 21, 2008
    Mine says PROTECT and won't do anything else?????
  • glorydays84 Mar 23, 2008
    mp205
  • jaycee210 May 21, 2008
    my KDC-MP205 model has the same problem, the sound start to fade out and the display flashes PROTECT. I'm pretty confused. I need a solution, please!
  • Anonymous Jul 16, 2008
    I have the same problem and it is so annoying. It happened out of nowhere! I don't have my manual anymore.
  • Anonymous Jul 17, 2008
    kenwood kdmp295
  • djelav8 Jan 13, 2009
    i have a kdc-mp438u doing the same thing please help!
  • mmafia Mar 05, 2009
    I have a Kenwood KDC-W3537A and keep getting the flashing 'PROTECT' msg. I have tried looking to see if any wires are showing, insulating them, reset button, disconnecting and reconnecting battery and fuse, and plugged it in without the speaker dock bit connected but still get the PROTECT msg appearing. I bought it second hand and the wires the person sent with it seem a little worn in places but I have covered them etc, and was told it worked fine but would this have anything to do with it, or if the PROTECT msg is coming up when the speakers aren't connected does this mean there is a fault with the actual player itself? I hope you can help.
Hello all I had that same problem & I went to www.kenwoodusa.com & downloaded the owners manual for our model type & problem solved...there's a reset button to the left of the number buttons & the auto button on the face....u'll have to use a pin or something to press it but it fixed my problem!! I can play cd's again!!!!! ^_^
Posted on Sep 15, 2008
If the reset button doesnt work you can pull out the entire stereo and locate the fuse on the back, simply pull it out and put it back in.. that resets it also but it's what i have to do everytime i get the protect on the screen
Posted on Sep 18, 2008
I had this problem with the set I bought and tried the resets etc. The protect would flash up later and sometimes would not reset (intermitant fault) as I had been told the problem was with the out put for the speakers we disconnected the wires and protect went off (after reset) it was then trial and error connecting the speakers one by one (had to bypass the block for this) until we found the speaker that was causing the protect display. we then chased a wire through the car to replace the original. PROBLEM SOLVED. I believe a wire had frayed somewhere and was earthing on the bodywork, hope this helps.
Posted on Jun 14, 2009
  • 4,234 Answers
The protect message means that a problem was detected and that the output speaker connections have been disabled. Please verify the exact model number and I should be able to provide more details on the likely defective parts.
Dan
Posted on Mar 19, 2008
2 Suggested Answers
SOURCE:
zzedly
  • 300 Answers
SOURCE: display read protected and wont do anything
Usually, protect mode is enabled when the speaker output wiring has shorted together or is touching ground/+12V. I would verify that none of the speaker wiring has come loose.
My Sony home theater DZ290K had a push power protection on the display screen how can I fix it?
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Aug 26, 2015 | Sony Audio Players & Recorders
My techwood Str84 will turn on but only say protect
if it is in protect mode you have short parts that need to be replace.
Nov 10, 2012 | Televison & Video
My JVC car stereo display " Protect " on display
FIRST PRESS THE RESET BUTTON BEHIND THE FACE IF DONT WORK CHECK ALL SPEAKER WIRES SOMETHING MIGHT BE TOUCHING
Jul 24, 2011 | JVC AM FM CD DET FACE CAR STEREO
What do "write protect" mean
1. Switch to playback mode using the mode
dial. Use the Left/Right buttons to locate
and display the photo or movie that you
want to protect.
2. Select the Protect setting from the
Playback menu as described previously.
3. Use the Up/Down navigation buttons to
select One to protect this picture/video,
or select All to protect all pictures/videos in
the internal memory or memory card. Then
press the Right navigation button.
4. Use the function button to select Yes to lock
the displayed picture/video or Unlock
to unlock it, and use the Up/Down
navigation buttons to select Back to
return to the Playback menu.
5. A key icon will appear on the top of
the screen to indicate that the picture/
video is protected.
6. Select reset to cancel protection for all
files that have been placed in the protected
mode.
Also keep in mind the card it self has a write protect on it if you hold the sd in front of you label side up its on the left hand side its just a little slide tab.
Jun 21, 2011 | Cameras
"protected"
First, disconnect all speaker wires from the unit and power it back up. If it does not go into protect. post a comment and I can walk you thru troubleshooting. If it goes into protect, it needs to be serviced.
Jun 24, 2009 | Sony STR-DE835 Receiver
Protect apears in display of my carradio Kenwood KDC 3034
I did not resolve my problem and I defenitly am not going to pay anything to you to resolve it. So if you have the resolution to my problem tell me or do not bother to write to my email adres anymore. Thanks for your answer.
Jun 22, 2009 | Kenwood Car Audio & Video
"protect" display when volume is high and volume cuts in and out.
you should have it repaired.the audio circuit is malfunctioning because of the sudden burst/surge of current.
May 15, 2009 | Onkyo TX-SR502 Receiver
Display says protect
check your low voltage fuses, the protect light up when a overload comes....
Jan 28, 2009 | Audio Players & Recorders
Protect push power
hi, everytime i switch on my sony hi fi it the display screen says protect push power. It won't let me do anything not even put cd's in. If you could help that would be very much appreciated.
Jun 12, 2008 | Sony LBT-XGR6 CD Shelf System
Display read protected and wont do anything
Mar 19, 2008 | Kenwood KDC-MP5032 - Car Audio CD MP3...
Kenwood KDC-MP205 CD Player Logo
1,105 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
