Question about Canon imagePROGRAF W8200 InkJet Printer
Error code on canon w8200
Hi i have replaced carridge belt on w8200 now it is giving an error of e02e01 can anyone help
  • johnnymcq Nov 27, 2008
    geting error code eo2eo1 anyone knowwhat to do tks john in brainstorm
  • johnnymcq Nov 28, 2008
    showing my tech skills here
    is that the white tape and clean with spirits ?
    Problem Solver:
  • 8 Answers
Clean the round rod that the print head moves along and also the metal work above where the carrage rollers run.
I wipe mine with a drop of oil after cleaning as error is indicating that the carrige is sticking and not moving at the correct speed.
Chris
Posted on Aug 27, 2010
  • 117 Answers
Error Code E02D02 = Clean de coding tape behind the rubber belt.
Error Code E02E05 = Problem with de ink cartridge door.
these are problem for the your error code also. so just clean your encoder stip
Posted on Mar 19, 2008
Didi you manage with the code E 02e01 ? Because I have got the same problem Could you help me now ?
Posted on Jun 04, 2010
I have a Canon W8200 and i get the error code"
Try this:
1) As an error (E02802 or E02805 to E02809) is shown on the display, install the correct
combination of printhead and ink tanks according to the error.
2) Perform ink filling*3 following the installation sequence. After filling ink, when "Load Roll
Media" is shown on the display, turn off the power.
3) Turn on the printer while holding down the ONLINE button, ENTER button, CANCEL button,
and PAPER SOURCE button.
4) Check that "Canon W8200" is shown on the display, and then release the buttons. When
printer enters Reset mode for the dye/pigment model setting, all the LEDs on the operation
panel turn on.
5) "TYPE RESET" is shown on the display.
6) Select "YES", and then reset the dye/pigment model setting in the printer.
When reset is selected, the ink drain sequence is executed. It takes approximately 4
minutes for the process to be completed.
7) Check that "Turn Power Off!!" is shown on the display, and then turn off the power.
8) Unplug the power cord from the outlet.
9) Move the carriage, and then takeout the printhead.
10) Replace the following parts
• Ink tube unit : See "Part 5: 5.2.6 Ink tube unit".
• Purge unit : See "Part 5: 5.2.9 Purge unit".
• Ink tank unit : See "Part 5: 5.2.10 Ink tank unit".
11) Turn on the printer, and then continue with the installation operation (from installation of the
printhead). At this time, replace the printhead with a new one*4.
For service manual, You can write me on emma.servis@gmail.com
Hope that helps!
Jul 29, 2011 | Canon W8200PG InkJet Printer
ERROR CODE E02E05
Error Code E02E05 = Problem with Ink Cartridge door. you must unplug the printer. Turning on the on/off button is not enough. Then the printer ask you to remove the empty cartridge and open the
door, canceling the E02E05 error.
Nov 08, 2010 | Canon imagePROGRAF W8200 InkJet Printer
I was about to start printing when the printhead gave a strange loud voice and got th E02E01 error code. Can you help me? thanks, Rita
E02D0B Cap sensor cannot detect rotation flag
E02E01 Cannot move carriage
E02E05 Carriage movement timeout
E02E06 Printer error (Carriage motor hardware
Sounds like something is blocking the carriage.
Jun 06, 2010 | Canon imagePROGRAF W8400 InkJet Printer
I have an error on my w8200, on the screen
i have an error on my w8200, on the screen written ERROR E20D01,
what is the code mean?
Jun 04, 2010 | Canon W8200PG InkJet Printer
Canon W8200 error message "Print Head Error" "turn off printer"
There was no response to the question, so we called in a Canon service person who has ordered a replacement print head.
Nov 24, 2009 | Canon imagePROGRAF W8200 InkJet Printer
CANON IMAGE PRO W6400
This error code is a Carriage motor error. Below is the outline for what to check and what to repair/replace. Good luck.
Cause
This is displayed when a jam or other physical problem puts an excessive load on the carriage motor so that the carriage could not operate.
This is displayed when the carriage motor could not reach the prescribed speed within the prescribed time.
Probable problem locations
Foreign object in carriage movement path, carriage rail, carriage belt, linear scale, linear encoder, carriage motor, engine controller, system controller
Remedy
1. Carriage movement path check
Remove any foreign objects (jammed sheet) in the carriage movement path.
2. Carriage rail
Use rail cleaner to clean the carriage rails if a visual check reveals that they are dirty.
3. Carriage belt
If a visual check reveals slack in the carriage belt, remount the belt.
4. Replace the linear scale.
5. Replace the linear encoder.
6. Replace the carriage motor.
7. Cable connection check
Replace the cable between the carriage motor and engine controller if the connection is not functioning normally.
8. Replace the engine controller.
9. Replace the system controller.
Feb 12, 2008 | Office Equipment & Supplies
Canon imagePROGRAF W8200 InkJet Printer Problem Printhead Error! Turn Power Off!
you need to enter a service mode before the error message pops up. hold down paper source button + online.
that should override the message before it pops up.
go to replace print head selection. or do a clean. it may still be working. let me know if this doesn't work....but at least you can still get past the message now! marty
Oct 27, 2007 | Canon imagePROGRAF W8200 InkJet Printer
Error code E02B05
Error Code E02B05 = Problem with de ink cartridge door.
Oct 23, 2007 | Canon imagePROGRAF W8200 InkJet Printer
Canon imagePROGRAF W8200 InkJet Printer Logo
1,103 people viewed this question
old marine
old marine
