Question about Krups ProAroma 453-71 Coffee Maker
Coffe does not stay hot in carafe
Krups type 453, brews fine and it seems hot when it brews but does not stay hot in the carafe. I have programmed the coffee maker to stay on for 4 hours, have tried all temp settings from 1-6, and there seems to be no change. There is a button that shows three wavy lines and I don't understand what it is, but when this is selected to the "on" position, the maker doesn't seem to brew when programmed.
Thanks,
David
The wavy lines indicate the carafe pre-heat function. When it is ON the red light blinks for several minutes and the goes on solid. It doesn't start brewing until the light is solid red.
Mine also doesn't seem to keep hot also.
Posted on Apr 07, 2009
The Krups coffee maker brewed as usual, it was a little hot so I did a few other things went back to the coffee maker it had shut off by it's self and now wont come back on???
unplug the coffee maker. Let the unit cool down for say a half hour. Try another pot of coffee and see if it comes on after plugging it back in of course
Oct 31, 2010 | Krups ProAroma 453-71 Coffee Maker
As coffee brews it spills out everywhere. At first if I made minor adjustments to where the pot positioned under the filter it would help, but it seems to be getting worse. I can't make a pot of coffee...
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 16, 2009 | Cuisinart DCC-1200 Coffee Maker
It wont brew drip coffee
What are the simptoms? Once you pour the water and add the coffee it should start when you press the coffee button.
Jun 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups Coffee pot stopped brewing after programming
OH Yeah!
That is the number one failure in these machines. (owned four of them)
The problem is one or both of the "twin" thermal fuses or the thermostat for water
heating and hotplate,( one in the same) has gone open. I have tried for a long time to locate correct replacement parts to no avail. I would STRONGLY not recommend trying to bypass as these are not only controls but a safety feature as well. I was lucky a wile back and found one without a carafe at a garage sale. used it for parts, now those have failed also. Really miss them. If I ever find a source for parts I will post it here with replacement procedure.
EfACTOR
Feb 22, 2009 | Krups Crystal Arome Plus Time 467 Coffee...
Coffee Not Hot Enough
probably need to descale the machine scale stay on the heater and doesnt heat as much use descaler not vinegar thanks pierre
Jan 11, 2009 | Krups Small Appliances Espresso Machine
Flashing red light
Just found the answer!
The type 453 coffee maker offers a carafe ‘pre-warm’ function.
This feature will heat the carafe for 5-10 minutes before the brewing process begins and is indicated by a flashing red light.
To toggle this feature, push the top-right button in the control panel until the display reads "off".
Aug 08, 2008 | Krups ProAroma 453-71 Coffee Maker
I just received my cuisinart coffe maker DCC1200 and I wanted to brew a pot of coffe but I am unable to open the glass carafe to obtain my coffe filters. Is there a specific way to open this? Your...
Hmm. Better late than never. Just got home with ours. Same problem. Called Cuisinart 800 number. Catch is on top of handle. There is a slight lip on each side there. Pop it up with pressure on both sides simultaneously. To replace, line up lid carefully with top of carafe and press firmly until it pops back on.
Jun 23, 2008 | Cuisinart DCC-1200 Coffee Maker
My Krups won't brew
The culprit is probably the thermal fuse. It's under the bottom cover, and you have to have Torx security bits (the ones with the holes in the middle) to remove the three screws holding it in place. Sadly, the thermal fuse is not resettable. Once it's tripped, it's dead. If you have this problem, forget about getting Krups or their lame service agent, smallappliance.com, to repair it. Both contacts I had with Krups were unsatisfactory. The factory/customer service folks say that there are no parts available and to buy a new coffee pot. Great solution. You can damn well believe it won't be a Krups. Or is it ****? An otherwise perfectly functioning unit gets sent to the landfill because the folks at Krups can't be troubled to find the part number. Idiots. For your info, there are thermal interrupters made by several manufacturers. The trip temperature on the breaker is 318 degrees, C. Something in the neighborhood of 200 degrees C would probably work, but would have to be soldered in. If you are comfortable with doing that, it's a solution.
Mar 28, 2008 | Krups ProAroma 453-71 Coffee Maker
Krups 453 coffee maker - won't to brew/heat
I just had the same failure, but fortunately, had already bought a used 10-cup unit a few months back as a spare.
The component in question is a thermal circuit breaker, of the sort which does not reset. Once activated, it is destroyed,
I have been unsuccessful locating the same component on the internet, but it seems to be a very high temperature unit, with the nomenclature "Tf 318 C" which because of the lower case "f", leads me to conclude that it's designed to trip at 318 degrees, C, or a very healthy 604 degrees, F.
Similar fuses in other appliances range around 230 degrees C (446 degrees F),  which is in the ballpark.
The failure is easy to verify.  If blown, there will be powdery white residue on the inside of the bottom plastic cover near the part.  Also, an ohmeter will show an open circuit across the contacts.  (Unplug the unit before measuring!)
Screws to remove the bottom cover are three tamper resistant torx screws.
If I am unable to find an exact replacement, I will use a thermal fuse in the same power and temperature range (10 Amps, 300 degrees C trip).
Because my unit unequivocably did not experience over temperature conditions, I suspect this is a component aging issue and that there is no other problem with the coffee maker.
Supporting this is the fact that the unit works fine after I moved the good part from my spare coffeemaker to the dead one.
Feb 27, 2008 | Krups ProAroma 453-42 Coffee Maker
Hamilton beach coffee maker Model 49464
Leave the carafe off the hot plate and place the basket in holder with the lip under hinged flange so it sits flat. Then replace the carafe and the basket should not move up when the Pause and Serve button opens. I just bought this pot too and
love it but except for the basket placement problem.
Feb 18, 2008 | Coffee Makers & Espresso Machines
Krups ProAroma 453-71 Coffee Maker Logo
345 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
