Question about Brother MFC 420CN All-In-One InkJet Printer
My Printer works fine... except it won't feed business cards or card stock
I have had my printer for a few years and it is starting to show signs of wear... Like the scanner taking forever and sounding really bad when it scans.... but My heres what I really need to know:
Lately I can not feed my business cards or card stock through it. It prints fine with regular office paper.
What would I need to do to fix this?
  • monkeyfaces Mar 19, 2008
    hmm. I have never had any trouble before. I must have gotten lucky then. Good thing to know because I was about to buy a newer brother. Glad I found this out first. Thank you.
  • 832 Answers
You cant fix this because brother printers are limited to paper:
paper that weights more than 200g wont run through the paper feeder.
Posted on Mar 19, 2008
Uneven wear on printer feed roller
Are they printing heavy card stock or envelopes? It seems they might be using a specialty paper or there may be hair wrapped around the other rollers somewhere too.
One possible solution is to get the next model year rollers and see if they fit If the manufacturer noted the problem they may have fixed it but are unwilling to acknowledge it publically on the newer models.
Nov 07, 2013 | HP LaserJet Office Equipment & Supplies
Business cards get stuck in HP 4650
The card stock is most likely too heavy for the 4600. If you check the owners manual, you will most likely find this is "Out of media specifications".
Other color HP laser printers like the 2500 cannot move card stock well either.
HP will tell you that 'if the printer moves paper perfectly' it's not broken.
Mar 12, 2009 | HP LaserJet 4650 Color Printer
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    Epson RX500, Paper Jam - printing couldn't start
    Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button, applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
    Jan 06, 2009 | Epson Stylus RX500 All-In-One InkJet...
    Paper Jam Photosmart C3180
    Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
    Worth a try, as I have fixed a number of printers this way, saving costly repairs.
    Hope this helps. Bud
    Jan 02, 2009 | HP Photosmart C3180 All-In-One InkJet...
    HP C4280 incorrect paper feed
    Check your printer's capability.
    Buy the card stock they recommend.
    If all else fails, print on plain and take card stock to a copy shop and have them do it for you.
    Walking there beats going nuts over stupid software or hardware problems
    Dec 16, 2008 | HP PhotoSmart C4280 Laser Printer
    Blinking yellow light
    I m not sure what the specification of the paper type you are using however if you are using card stock than you should use manual feed Tray and in the printer driver properties you should select paper type as Card-Stock to make sure there is no print quality issue.
    Nov 30, 2008 | HP Color LaserJet 2550n printer + HP Color...
    Brother MFC 420CN All-In-One InkJet Printer Logo
    361 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
