Question about Sony CRX320EE-88B CD-RW/DVD-ROM Combo Drive
Code 39 My computer suffers from code 39 problem, the problem is my drive E or the CD-ROM doesn't detected or seen in my computer. Please help with my problem, tell me how to fix it. You can send a mail in my e-mail address; aj_abdukahil24@yahoo.com
    Champion:
  • 208 Answers
Get the filtercheck 4.6 and remove all filters .. restart.. done
www.cdr-zone.com/forum/about4719.html&highlight=filtercheck
Posted on Mar 23, 2008
My ACER Aspire 4736Z cd-rom drive is not working. It doesn't read/write, it's not even showing on My Computer. On the device manager there's an exclamation mark (!) and a Code 10. Please h
The driver for that cd Rom is not loaded or is corrupt. You need to install a correct device driver. If it still doesn't work try reloading the os.
Dec 26, 2012 | Computers & Internet
Hi everyone, I was installing windows xp sp3 on my compaq desktop computer through my hard drive because my computer doesn't recognise cd roms, So I can't install through cd drives. It installed to...
Hi
Have you tried to go into your cmos settings and enable the settings to detect your cd rom
You should be able to use a external cd rom connected through your USB port to load and re-install windows and your drivers if you have the motherboard cd.
The problem is your limited in your options to work from the hard drive but a disk also gives you the option to repair the filing system and replace missing files.
The problem with installing windows on one pc and it not working on another pc is the motherboards are not compatible, and the configuration has to be similar or the same so the hard drive can boot up and communicate between the hardware and software.
Your options are use a CD rom, change your MB or google your problem and hope someone else was able to resolve this issue.
Cheers
Nov 26, 2012 | Computers & Internet
Optical media emulation
Uninstall while in safe mode. Go to your bios and make sure your CD Rom is detected. If it is then reinstall. If not then it isn't compatible with your computer
May 26, 2017 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Monitor to other cpu and it works fine. Tried recovery tools and rcovery disc but receive errors, boot from cd rom no emulation, and no hard drive found. Help!!!!
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jan 19, 2012 | HP Compaq Presario S5300NX (DM174A#ABA) PC...
Fix DVD/CD ROM to work Acer M1610, Computer not detecting DVD/CD ROM. No drive is seen how to fix this, what are my options. OS is Vista
Hi rossclark3,
Try to check the jumper settings of your DVD/CD ROM if it is properly assigned as Master or Slave.
Afterwards, also check the cable connecting the DVD/CD ROM to the motherboard.
Finally, restart your PC and check the BIOS Setup if it can already detect your DVD/CD ROM.
Hope this helps you a lot.
Thank you for using FixYa!
Oct 29, 2011 | Computers & Internet
MY , CD/DVD LAPTOP DRIVER DOESN'T WORK. IT CAN
goto run and type "compmgmt.msc"(without quotes) and select disc management if the dvd drive is showing below the hard disks means your dvd drive is working fine only thing you have to do is to right click on the CD-Rom 0 and change drive letter and paths to it
.if the CD ROM option is not seen in disk management then you have to go to the device manager option under computer management and expand cd/dvd -rom drives and you will find your dvd drive model if not that means that your dvd drive has got hardware problem
Aug 06, 2011 | Dell Computers & Internet
CD ROM DOESN'T READ DISCS. I NEED TO RE-INSTALL SOME DRIVERS ON MY OTHER COMPUTER, BUT I CAN'T. I WENT TO DEVICE MANAGER-CD-ROM DRIVE PROPERTIES. UNDER OPTIONS DISCONNECT WAS CHECKED. COULD YOU...
Either spend $40 to buy a new CD/DVD reader/writer,
or take the CD-ROM with the files to another computer.
Spend $10 to buy a 4Gbyte USB memory-stick.
On the other computer, copy all the files from the CD-ROM disk to the memory-stick.
Move the memory-stick to your computer, and install from the files now on the memory-stick.
Jul 28, 2011 | LG Computers & Internet
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
When i put a disc in the drive it trys to spin up but then fails and then winds down and it does that a whole bunch of times untill it just gives up. but when i go under my computer and click on the disc...
Nothing to do with the rest of the pc, it's the reading head inside the drive that is faulty: it's no longer capable of detecting the disk because it's covered in dust. Try to blow away the dust with a can of compressed air and then wipe the lens with a q-tip. If this doesn't help then the dust has been baked on the surface of the plastic lens and this is terminal - you will have to replace the drive.
Apr 19, 2011 | Samsung SN 124 (SN-124) Internal 24x...
MY COMPUTER DOES NOT SEE THE CD-ROM
my cd and dvd not detect of my computer how cd and dvd detect tell me a solution
Dec 25, 2008 | Computers & Internet
Sony CRX320EE-88B CD-RW/DVD-ROM Combo Drive Logo
97 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
