Question about HP LaserJet 2420n Printer
2420n I recently tried to install a maint kit for a Laserjet 2420n. This however came with no instructions. When it came to replacing the Tray 1 Separation Pad & Pickup Roller, it came as a complete part, including the bar that the Pickup roller is attached to. Without the instructions I stupidly tried to change the whole thing and broke one of the white plastic pieces that are attached to the bar. this white plastic piece, I believe, detects how much paper is in the tray. I cannot seem to get this bar out to change the broken piece. Anyone got any instructions on how to do this?
  • 43 Answers
DRIVERS
Posted on Apr 04, 2008
Hp laserjet 4250 feeds multiple pages through the manual feed tray
It sounds like the paper pickup roller and separation pad for tray 1 is worn and will need to be replaced. These two parts pickup the paper and weed the pages into the printer. When they get worn down they can grab more than one page at a time. The parts are user replaceable, no need to pay a big repair bill for something like this. The parts come in a kit with rollers and pads for tray 1 and tray 2 along with the instructions and it is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=302
Here is a picture of the roller and separation pad from the service manual.
I hope this helps you out.
Apr 11, 2013 | HP LaserJet 4250dtn Printer
HP 2420n printer
When you put paper, does it recognize that paper is inserted?
Mar 19, 2008 | HP LaserJet 2420n Printer
Laserjet 4100 taking in extra paper
Picking up more than one sheet of paper indicates the pickup rollers and separation pad is worn and they will need to be replaced. These parts work together to pickup and separate the paper from the paper tray and when they get slick the rollers allow more than one sheet to enter the printer which causes a paper jam and misfeed errors. The rollers and separation pad come in a kit and is user installable, no need to pay big money for a repair shop to do it for you. The kit RK-4100 is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=259
Mar 28, 2013 | HP LaserJet 4100n Printer
What does the HP LaserJet 2100 Series Maintenance Kit includes?
HP LaserJet 2100 120-volt maintenance kit, includes fuser roller assembly, transfer roller assembly, tray 1 & 2 pickup rollers and tray 1 & 2 separation pads.
Aug 12, 2010 | Canon Office Equipment & Supplies
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
From the printer indicator,the printer is requesting for transfer fuser kit. the percentage is low,down to 0%. What is transfer fuser kit?
GENUINE HP COLOR LASERJET 2600 MAINTENANCE KIT - Kit Includes: 120V(220v) Fuser Unit, Tray 2 Paper Pickup Roller (D-Shaped Roller), Tray 2 Separation Pad Assembly - Includes The Spring Loaded Separation Pad In Holder Assembly - Genuine HP Part
Oct 21, 2009 | HP Color LaserJet 2600n Printer
Separation pad for HP LaserJet 4050
Open tray 1
remove the pick up roller
pad is located under the roller
in the front center of the pad is a small notch
inset a small screwdriver or key something small and flat.
give it a twist and the pad should pop out.
install the new pad by aligning with the holes and push down should sort of snap into place.
Reinstall pick up roller
Hope this helps
Mar 25, 2009 | HP LaserJet 4050 Printer
HP 2420n
Hey there. here is a link with the service manual.
If U can't find how, ask me.
http://www.qhaclaims.com/ftp/TEMP/LaserJet%202410%202420%20and%202430%20SM.pdf
HP 2420 Tray 2 Open or Empty
Needs feed roller replaced, you can see it when you remove cassette and look up, they wear and tray one uses a diiferent feed roller hence it still works. Cleaning the roller (rag with a little metho) sometimes helps but it should be replaced otherwise it will return.
Nov 08, 2007 | HP LaserJet 2420 Printer
Proper Manual cleaning
Hi Gidget,
I typically use "Chux" wipes and a shop-vac to start with. The wipes wipe up and REALLY HOLD the toner & paper particles, holds 'em tighter than a Hobo does a ham sandwich...
(I'll concede to the 'by-the-book' crowd that a specific (read EXPEN$IVE) type of vacuum cleaner is recommended by HP & most other service org's. I've used my shop-vac for 12+ years and have serviced thousands of HP LJ's, CLJ's, AiO's, MFM's, DJ's, OJ's, etc. I have never lost a single printer because I didn't use the 'right' type of vacuum...)
The Chux wipes are available from PartsNow, LLC; www.partsnow.com/.
They also carry maint kits for almost every HP printer made as well as Lexmark, Canon, Xerox, etc.
I use Cooper's Platen Cleaner (PartsNow) to clean the rollers using 2" x 2" gauze squares and nitrile gloves. Fedron works well too. HP's website mentions isopropyl alcohol and water as their recommended solvents. Use waht works best for you.
Having some 6-inch long cotton tipped applicators (wooden handled single ended Q-Tips...) helps tremendously.
In conjunction with the correct service manual, (in your case,  Combined Service Manual for HP LaserJet 4L / ML & 4P / MPHP Publication Number C2005-90988, August 1993), a thorough cleaning is very easy for almost anyone to perform.
PartsNow and several other websites have HP Svc Man's online for free, Google around.
A legacy utility from HP that I've not yet tried can print and cycle cleaning sheets to clean mainly the fuser, but also claims to clean rollers as well. HP printer specialists will recognize 'cleaning sheets' from HP's newer models, built in to the menu structure. The utility will allow you to do the same for older (LJ 4, 5, & 6) printers. Find it at:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=25484&prodTypeId=18972&prodSeriesId=25484&objectID=bpl03846
Another Combined Svc Man is available as well that covers:
HP LaserJet 4 / 4M
(C2001A / C2021A)
HP LaserJet 4 Plus / 4M Plus
(C2037A / C2039A)
HP LaserJet 5 / 5M / 5N
(C3916A / C3917A / C3952A)
HP Publication Number C3916-90984 (March 1996).
As far as Scheduled cleaning, the cleverly formatted (LOL) table below lists HP's recommended service intervals. Over the years, I've found that adhering to the schedule has reduced unplanned downtime by almost 80%!!
DESCRIPTION / QTY / EST. LIFE (pages) / REMARKS
1.  Toner Cartridge / 1 / 6800 (note 1) / When print becomes faint, shake cartridge to distribute remaining toner.
2.  MP (Tray 1) Pickup Roller Assembly / 1 / 200,000 / Replace roller and separation pad together.
3.  PC (Tray 2) Pickup Roller / 1 / 200,000 / Look for glazing and cracks.
4.  Separation Pad / 1 / 200,000 / Look for glazing and grooves. Replace together with Pickup Rollers.
5.  Transfer Charging Roller / 1 / 200,000 / May affect print quality and/or paper jams.
6.  Fuser Assembly (115 V, 50/60 Hz) / 1 / 200,000 / May affect print quality and/or paper jams. Look for marks on rollers.
6a. Fuser Assembly (220 V, 50 Hz) / 1 / 200,000
7.  LC (Tray 3) Pickup Roller / 1 / 200,000 / Look for glazing and grooves. Replace the Separation Pad.
8.  Exhaust Fan / 1 / 25,000 hrs. (I've only had to replace one in 12 yrs...)
Note 1: The estimated Toner Cartridge life is based on A4 or letter size prints with an average of 5% toner coverage, and with the density setting at 3.
Best of luck,
Foxfur
Oct 16, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 2420n Printer Logo
256 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
