Question about Pitco Frialator 35CD Deep Fryer
Thermopile Is the Thermopile for the 35CD, 35CS, PIT40SN and the SG185 standard to each? If so what would the part no. be for ordering a replacement?
    Champion:
  • 254 Answers
The thermopile for the 35cd,35cs,pit40sn,sg185 are the same thermopile the part number is P5047541. The only other thermopile in use for pitco products is the one for the solstice series it is part number 60125501
Posted on Jun 04, 2008
SOURCE:
Pilot light will not stay lit once pilot button is not depressed. Replaced thermopile already. Any suggestions? Also don't have milivolt detector. Thanks
Hi there.
Check the wiring, loose wiring terminals can disrupt the current going to gas valve.
Try also to connect jumper wire across the hi limit terminals, if this do the trick, replace the hi limit device before operating the fryer.
Lastly, the gas valve may be defective.
Regards.
Nov 26, 2013 | Pitco Frialator 35CS Deep Fryer
Pilot lights but will not light burners when range selector dial is turned on
Hi there.
Check and clean the thermopile, it must be free of soot or any form of dirt so that it can properly sense heat from the pilot flame and generate millivolt to open main valve to fire up main burners.
Regards.
Sep 22, 2011 | Pitco Frialator 35CS Deep Fryer
13 year old pitco frialator fryer pilot wont stay on. changed gas valve and thermopile.... pilot light wont stay lite
Hi there.
Check and tighten all wiring connections.
Check the hi limit for continuity across the terminals using an ohm meter, if it has no continuity, you have to replace the hi limit.
Regards.
Aug 21, 2011 | Pitco Frialator 35CS Deep Fryer
Pilot light does not stay on
Hi there.
Try cleaning the thermopile, it must be free of soot or any form of dirt. Ensure that the gas pressure is sufficient, all wiring connections are tight and the hi limit is good.
If all of these are okay and the pilot still wont stay lit, try replacing the thermopile.
For Owner's manual download that will help you in minor fryer troubleshooting and reference, visit http://www.pitco.com
Regards.
Jun 27, 2011 | Pitco Frialator 35CS Deep Fryer
I have a pitco 35c fryer the pilot light will light but the flame is very low it goes out when i release the controll the pilot light adjustment has no effect on flame i have the right amount of fuel...
Check and clean the thermopile, it is the cylindrical piece of metal standing behind the pilot assembly.Try also to tighten its wiring connections to the gas valve and high limit.If it does not correct the problem, replace the thermopile.
Apr 06, 2011 | Pitco Frialator 35CS Deep Fryer
We changed the thermostat in our unit and now the pilot lite won't stay lit!
You have to check the following:
1. Does the pilot flame has the ability to heat up the thermopile? Themopile must be properly heated in order to generate voltage to open the pilot valve as well as main valve.
2. When the thermolpile is heated, does it generates 500 millivolts? If not, your thermopile needs replacement. If it does and still the pilot flame wont stay lit, your gas valve needs replacement.
3. Does the hi limit device has continuity on its terminals? If there is no continuity on hi limit terminals, you have to replace it. One of the thermopile wire passes on this hi limit terminal to cut the voltage supply on pilot valve in case the oil temperature reaches 450F.
4. Check and tighten all wiring connections, millivolts generated by thermopile will not pass on loosely terminated wiring.
Jan 12, 2011 | Pitco Frialator 35CS Deep Fryer
Hello I have a Pitco Frialator 35CD Deep Fryer and as of one day ago, when I turn the wheel to turn the fire on (the wheel with the various temperatures) nothing happens? How do I fix it?
Assuming that the pilot is lit, when you turn the thermostat from off to the operating temperature, you should hear a click at some point. If you do not, the thermostat is defective. You can also double check this by detaching one of the two wires going to the thermostat and measuring for continuity between the two terminals. At off it should show no continuity. At 200F or above it should show continuity. This is the most common problem.
If the pilot will not stay lit or if it goes out when you increase the thermostat setting, it is usually a defective or weak thermopile (or thermocouple), or a defective gas valve. If replacing the gas valve, I recommend replacing the thermocouple or thermopile at the same time.
Restate your problem if the pilot won't stay lit or if it goes out when you turn the thermostat up.
Feb 11, 2010 | Pitco Frialator 35CD Deep Fryer
Hi, i am having a problem with a deep fryer. Pitco Frialator 35CS. The pilot is liting, but the burner will not lite. Solve this for me. thanks
Make sure that the gas pressure is standard (as rated on nameplate), thermopile must be clean (no dirt or soot) and the thermostat is good.
Jan 19, 2010 | Pitco Frialator 35CS Deep Fryer
Pitco fryer pilot out
if you changed the thermopile and still have the same problem make sure that the sensing bulb is directly over the flame. If it is and the thermopile is installed correctly the next thing would be the gas valve.
Hope this helps
Jun 19, 2008 | Pitco Frialator 35CD Deep Fryer
Pitco Frialator 35CD Deep Fryer Logo
271 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Paul Carew
Treefrog15
Treefrog15
Joe Palazola
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
