Question about Sony Playstation 3 (PS3) Console
The Back plug of my 60 GB
I'm not sure if its the cable wire, but when i plug in the cable wire with the ps3 to the T.V, It makes a buzz noise from the T.V when i'm on the Ps3 channel. When I unplug the wire, the T.V stops making the noise. And i try plug it back out and in again. Still the same buzzing sound. I'm not sure if its the Wires or the the back plug is stupid! AND ALSO!! PS3 Freezes sometimes.. RAWR!!!
  • 32 Answers
Have you tried updating to version 2.2? It came out last night. Furthermore, can you try this on a different TV so that you can eliminate that as a variable?
Posted on Mar 25, 2008
SOURCE:
NS-LDVD32Q-10A buzzing noise
Try another input and another source such as a DVD player. If you still get the buzzing sound, you could have a faulty power supply output or a fault in the audio circuit of the main board.
Jan 27, 2013 | Insignia NS-LDVD32Q-10A LCD TV
My nad 3020 is making a buzzing noise when i connect to peakers even when nothing else is connected to it. any solutions ?
you may have a bad Earth power 110 V AC cable connection which makes such hum / buzz even nothing connected..
Check the connections between components and make sure they are secure before proceeding to the next Step. Sometimes, loose connections can cause a hum.
  • Separate the audio cables from the power cables; electromagnetic interference from the power cables can cause stereo hum. Use cable ties to secure the audio cables away from the power cables.
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • 5 Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
  • Read more: How to Fix a Hum on a Stereo Receiver ' eHow.com http://www.ehow.com/how_5183193_fix-hum-stereo-receiver.html#ixzz1PpFHs1Mv
    Take care and please remember to rate "AS THUMBS UP" Thanks
    Jun 20, 2011 | NAD Audio Players & Recorders
    BUZZING noise,when i plug in av cables!tried new cables,same buzzing,just not as loud,
    there are series of problem in ps3 which can be solved without much technical knowledge ........ your problem belong to that so dont worry i will give you the link to download the ps3 repair guide that will help you a lot....
    click here to download repair guide
    Dec 26, 2010 | Sony Playstation 3 (PS3) Console
    The phone has a buzz on it and it is not the line it's the phone att945
    Buzz may be from many different sources.
    First, is there DSL on this line? Make sure you have a filter on the line going to the phone or plug your phone into the jack coming out of the DSL modem.
    Next, remove any other device from the line and check the buzz. Sometimes a fax machine, computer or credit card machine will create noise on the line.
    Then check the connections in the wall, any splitter and in the phone. Make sure the wires are straight before you plug in the phone cord.
    If that does not help, take a regular phone and plug each wire into that phone and listen for the buzz, it may be a pinched wire.
    Or, you may have a wire running past something that has a large electrical current. Try moving the wires away from a television, florescent light, etc.
    Lastly, these phones have a cable length maximum. If you have too much cable in the office they will act as an antenna and this will add buzz to the line.
    Feb 10, 2010 | AT&T ATT-945 Corded Phone
    My vizio 37 is buzzing from the back. not from
    try to unplug some cables from the T.V like PS3/PS2/Xbox ect, or check your VCRs or DVD players cables by taking them off to see if the noise goes away. My crappy t.v makes a buzzing noise when i connect external speaker or VCRs or my PS3
    Aug 25, 2009 | Vizio L37 Television
    My ps3 will power up but with no display or audio. i checked my hdmi cable by using it on my cable bow and it woorked just fine so it is the ps3 itself. any solutions?
    try getting it checked ay a shop or you might have to get a new PS3 but make sure you get a quote from the shop they might cost more than the new PS3 which i dont get at all but hey they need to make money some how
    May 19, 2009 | Sony PlayStation® 3 (60 GB) Console
    NOT GETTING INTERNET TO WORK ON MY PS3
    If you have wireless make sure your modem is working if not wireless then make sure your wire is plugged in all the way
    May 11, 2009 | Sony PlayStation® 3 (60 GB) Console
    Stuck on hdmi
    Just plug the AV cable in as normal. The PS3 auto-detects the AV cable. Turn your PS3 on first, then your TV. Change the channel on your TV to your AV channel (YPBPR) and it should come on fine.
    Feb 21, 2009 | Sony PlayStation® 3 (60 GB) Console
    Ps3 setup
    make sure you have the video cable in the video in slot instead of the video out
    May 19, 2008 | Sony Playstation 3 (PS3) Console
    Noise coming from cable
    have you tried a new coax it could be shorted some you might want some heavy duty cable and good connectors
    Feb 08, 2008 | Televison & Video
    Sony Playstation 3 (PS3) Console Logo
    75 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Ekse
    shevantha perera
    Damen Wong
    Damen Wong
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
