Question about GE Profile JT952 Electric Double Oven
Ge Profile Dual fuel range J2S968SEKSS
My corned beef boiled over and sent water down the front of the range top. Some of it leaked into the oven door. I assume the water entered through the vents at the top of the door. Now there is a small pool of water between the glass panes and streaks down the glass on the inside. How do I clean up the water and the streaks?
Barbara
SOURCE:
  • 87 Answers
SOURCE: Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Posted on Jun 08, 2007
  • 833 Answers
SOURCE: Broken inside glass of oven door
Most units use Torx screws to hold the door together from the inside. Open the door, use tape to restrain the inside of the door or get help. Remove the 4 screws and the then remove the panel. Should be easy from there.
Posted on Dec 07, 2007
SOURCE: replacing glass top on stove
I also have a ge spectra with a broken glass.
Posted on Jun 26, 2008
  • 3 Answers
SOURCE: ge profile oven loc
hey - I figured it out! hold down the 9 and 0 at the same time for 3 seconds! or it might be another combination depending on your oven - it is probably the 2 keys that the messge is under
Yay!
Island2
Posted on Oct 03, 2008
  • 106 Answers
SOURCE: GE True Temp Profile Oven, Locked Door Light stuck on
there should be some type of button that the door hits to turn it on and off
Posted on Mar 24, 2009
Where to purchase
http://www.consumerreports.org/cro/kitchen-ranges.htm
Freestanding electric smoothtop ranges are the big sellers, but you have more choices than ever. Our Ratings include smoothtop ranges, of course, but you'll also find induction and coil-top ranges in the electric category, along with gas, dual-fuel (gas cooktop, electric oven) and pro-style ranges. Choose a single oven or double-oven range, freestanding or slide-in. We test all of these. Consumer Reports offers you buying advice that you can trust. We provide unbiased Ratings and range reviews to help you choose the best range for your needs and budget, and use our buying guide to learn more about range types and features that matter most.
Ratings & recommended kitchen ranges
Electric smoothtop ranges (62)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More
Recommended electric smoothtop ranges
Electric smoothtop range Ratings
Electric induction ranges (9)
Recommended electric induction ranges
Electric induction range Ratings
Electric coil ranges (10)
Recommended electric coil ranges
Electric coil range Ratings
Gas ranges (43)
Do you love cooking with gas? Our Recommended gas and dual-fuel ranges (which pair a gas cooktop and electric oven) are top scoring and, based on our survey of thousands of readers, do not have brand reliability issues. They have large cooktop burner... More
Recommended gas ranges
Gas range Ratings
Pro-style ranges (34)
Pro-style ranges are stylish, stunning, and make a statement. But despite their high price, they aren't the best ranges we've tested. So before you swipe your credit card check our Ratings. You'll see the top brands, including Viking, Wolf, Thermador... More
Recommended pro-style ranges
Pro-style range Ratings
Jul 19, 2015 | Ovens
I have a GE Profile Gas Range model 317B6034. The top / range works fine, but the actual oven will not turn on at all. I don't smell gas nor is there any sound when I turn the oven on. Basically,...
It sounds like you have a bad ignitor in the oven. Hope this helps get you going in the right direction.When you turn on the oven the ignitor should glo.
May 16, 2011 | Ovens
My GE profile electric range (model PS905SPSS) has a power boil burner with dual burner elements (one inner circle and one large outer circle). The outer circle one is glowing and heating but the inner...
Disconnect power to range. If you have an ohm meter, you can check the burner coils for continuity from the wires at the switch. If not, open oven door, remove screws holding top. Lift up top and remove screws holding the set of burners in question and visually inspect the inner coil for a break in the burner coil.
Nov 27, 2010 | GE Ovens
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
F7 Code on my GE Profile Oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
Water leaking on cooktop when using oven.
is there a fan for venting with this unit, if there is you will need to turn it on while cooking, it helps dissipate any steam or oil particles that move into the air, hopefully this will solve your problem, if you do have a fan and it is running, you may want to check the screen and clean it,as build up will cause the fan feature to not work as intended, thanks for your question,
mr.grzz
Jan 23, 2009 | Ovens
Only one ring of the double ring element works
You have faulty regulator, or the element is faulty., not sure how you access the inside.
Hope this helps.
Dec 05, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile JT952 Electric Double Oven Logo
87 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a GE Oven Expert? Answer questions, earn points and help others
