Confirm your motherboard's compatibility with the Intel CPU you want to install. Motherboards typically only support one type of CPU slot, so purchase an Intel processor that is compatible with that slot.
Ensuring your processor and motherboard are compatible is vital when choosing parts to build your own computer system. If they are both the same socket type, they will most likely work together.
Brands There are a plethora of motherboard manufacturers, but only two main processor manufacturers: AMD and Intel. Every motherboard, regardless of manufacturer, has a socket that will accept a processor.
Intel Common Intel socket types include LGA775, LGA1156 and LGA1366. Older models include PGA370, PGA423 and Socket 479.
Your motherboard and processor will be generally compatible if their socket types match. ... Intel Core 2 Quad Q9650 Processor Compatible Motherboards
Hope this will help you and please don't forget to rate me. Thanks for using FixYa
If you mean that your processor pins does not fit in your motherboard, then they are not compatible. The processor pins must be exactly fit the motherboard. Besides, the processor type must be supported by the motherboard (If the motherboard is supporting P4, Core Dou, Quad, Celeron, Athlon, etc). You have to install the right processor for a particular motherboard. You have to know what particular processor is supported by your motherboard.. In your case, I believe it supports Pentium 4, but I cannot give you the exact speed in Ghz, as well as the clock speed. You can ask the dealer about it.
hi check your processor number is thie in the list if it is not there then your new mother board does not support your new processor so it will not work...else replace your new processor, your processor is the problem
Motherboards designed for AMD processors have radical differences in design from those designed for Intel processors. The most obvious of those differences is the socket which accommodates the processor, which is totally different in both case. This means that you cannot use an Intel processor on a motherboard designed for an AMD processor, & vice versa. You have to replace the motherboard with one designed for the Intel processor you plan to use.
have u check ur memory?... ur videocard and powersupply...thats the main problem of pc if it has no display....just try it one by one...hope it can help u
