Internet runs slow or freezes on my wired desktop when I use the internet on my wireless laptop.
Why does my internet run soo slow on my wired desktop when someone in my house uses the internet on my wireless laptop? I have a D-Link WBR-1310 Router. I just bought it when I got my e laptop. The wireless laptop internet runs good when someone is on the desktopgood but the desktop thats wired runs slow. Can anyone give me a suggestion or a fix?
    Scholar:
  • 74 Answers
Hi tech_newbie.... Need a little more info... how is your wireless connected.. ethernet /Usb... or true wireless... and vice versa for desktop. where is your wireless router situated... what times are you experiencing the slow connection!
In addition.. first try running a good Spyware/ adaware programme such as Spybot.. and alongside side another programme called... a-square.. and with AVG.. all of which are free... see links below..
http://www.safer-networking.org/en/download/index.html
http://free.grisoft.com/doc/2/
http://www.emsisoft.com/en/software/free/
Try this first.. they are all pretty good programmes when used in conjunction with each other, you;ll be surorised at what you find.... Get back to me if this does not eliminate your problem
Regards Faggly
Posted on Mar 19, 2008
SOURCE:
Why is my computer so slow to connect to internet web sites
I would try to connect using a wired connection instead of a wireless connection to see if the speed increases. Also go to Speakeasy Speed Test and run a test to see what speed your internet is really running at.
Sep 24, 2014 | Acer Aspire Desktop Computer - Intel Core...
I am running hughes net satelite internet on a hughes HN 9000 modem and trying to setup and configure my linksys E3000 wireless router for two hp laptops on direct ethernet connection to our desktop,...
Are you trying to connect the laptops via wireless? Is that where you are seeing 75 mbps? I am assuming you are, and 75 mbps is really not how fast your internet connection is. Rather, that is how fast you are transferring data from your laptop to the wireless router and back. Generally speaking, this should be a way faster connection than your internet is running at. Chances are your internet connection speed is 10 to 20 mbps, which is good and fast.
It is easy to get the two confused, but basically a wireless connection of 75 mbps is an uber fast connection to your wireless router, and only if your actual internet connection was faster than that 75 mbps would you see any slowness due to that.
Wireless N routers are capable of delivering up to 100 mbps connection speeds, but again that is only from your device to the router. The router then goes to your modem and out through the internet. Chances are that connection is not 100 mbps because of interference, which can be walls, other wireless devices, etc.
One way to test your actual internet connection speed is to go to www.speedtest.net and click on one of the links on the map. This will tell you how many mbps you get to the internet.
Mar 17, 2011 | Linksys E3000 Wireless Router
My netbook runs slow and freezes
There are many reasons for slowness and freezing. Computer specs (ram, processor speed, connection speed)) could be not enough for today's internet.
Internet cache, temporary internet files, temporary files should be cleared.
Try defragmenting the hard drive.
And try downloading a program like CCleaner from Piriform.
Apr 10, 2010 | Computers & Internet
Wireless computers work fine, wired desktop extremely slow
On your old desktop, go to Control Panel > Internet Options > Connections > LAN Settings make sure no check on boxes there. Click OK and Apply. Click on General tab, click on Delete File (delete all offline content), Clear History and Delete Cookies. Click Apply and OK.
Jun 29, 2009 | Linksys Wireless-G WRT54G Router
Connect Laptop to PC desktop which has cable connection.
YOU WILL NEED TO GET A WIRELESS ROUTER TO BE ABLE TO USE THE LAPTOP WIRELESS, iT IS A VERY EASY SET UP AND CONNECT THE DESKTOP WIRED AND THE LAPTOP WIRELESS TO A WIRELESS ROUTER.
May 06, 2009 | Arris SURFboard SB5120 Modem
Wireless issues with my Dell XPS/Dimension One desktop
Even if it's a new Dell, you may need to update either the drivers for the wireless card or the BIOS.
Also, verify which protocol your Dell is set to use (i.e. 802.11g, 802.11b, auto-select, etc.). Dell may have fixed to to a slower protocol for compatibility.
May 02, 2009 | Dell XPS One Desktop
I installed New OS but no Internet?
go to
start>run>services.msc
in this list you will see windows wireless service, see if its running, if not you have to start it.
let me know how it goes.
Apr 15, 2009 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
Blinking lights on Belkin F5D7632-4
Check out with ISP Service provider and speed of your internet
Dec 17, 2008 | Belkin (F5D7230-4) Router (587009)
Painfully slow desktop internet use
I would start with running network setup wizard again on my desktop. also run a full system test at pcpitstop.com and see what all it tells you. If you are running a 2-Wire..GIVE IT BACK. spend a couple of bucks and get a linksys.
James Mac
Aug 31, 2008 | 2wire (1000-400108-001) Router
Pc connection problems
Sounds like you are setup to use Internet Connection Sharing. don't do this. Have each computer connect to the internet via the router. If the router is wireless connect all computers wirelessly to the router that are wireless capable and any computers that are not wireless capable, connect them to the router via a cat5 cable to the cat5 ports on the router. This will solve your problem. BPCS
Dec 30, 2007 | Belkin (F5D5231-4) Router
Computers & Internet Logo
607 people viewed this question
Ekse
Alun Cox
