Dim Illumination on Blaupunkt RPD 435 Detachable Face Car Radio
I have an older Blaupunkt RPD 435 Detachable face CD/Radio that came in the audi I bought used. I have had car 3 years. The power button was always an issues, now it doesnt work at all, I pushed on ait and held down which used to work now it doesnt, just a week ago the Green Illumintaion went dim, almost not visible. Suggestions?
SOURCE:
  • 148 Answers
SOURCE: cd player
First of all, you aren't going to like this solution because it's the truth. If you rate me poorly, it's because you don't understand the truth. The optical pickup is bad and needs to be replaced. Anything made by Xtreme sound is poorly built. Yes, you're lucky to have even gotten four months use out of it. I've seen some that only last for two months and they die. Fortunately, that's why you didn't pay that much for it. I would suggest getting a Pioneer in the future.
Posted on Jul 16, 2006
Buschchris1
  • 474 Answers
SOURCE: My detachable face won't turn
try cleaning the contacts on the back and on the unit.
Make sure you are getting power to the unit, check any fuses that may have been blown.
Posted on Mar 31, 2008
  • 4234 Answers
SOURCE: My TEAC A550RX stereo cassette
If the unit ends up in the middle of a cycle, the front panel will appear to be unusable. With a unit that has been idle for a long time, the belts and motors may be a little sluggish. This unit needs a general overhaul and the belts replaced. This should not be a major expense. Figure about $10 in belts and your ocal labor charge for the repair. If I remember correctly, this unit uses both a flat and square belt.
Dan
Posted on Apr 01, 2008
issy2
  • 462 Answers
SOURCE: I have an older Aiwa
try to open up the stereo and release the power button... and also see to it if the display is intact or requires allignment...
Posted on Sep 13, 2008
SOURCE: CDX-S2000 Volume, Source, and Mode buttons not working????
Hey jshaff, try taking off the detachable front, and you will see a reset button, press and hold in for 10 secs, this should solve your problem. if it doesn't work first time keep trying. you must have power to the head unit for this to work. you will hear the cd make a noise and that should be that, try and let me know.
Posted on Oct 04, 2008
My radio turns on and plays the CD that's in the player but none of the buttons work when I press them. How do I fix this?
If it's a detachable face try cleaning the contracts on the back side.. also on the radio it self with alcohol swab with the key off.
If it's not a detachable face pull the fuse out or take the battery cable off for a few mins then try it.
Sep 11, 2015 | Car Audio & Video
Volume down button doesn't work
hi, make sure the face pins are clean; try resetting the unit; check to see if the feel of the down switch is the same as the up switch....if not then your down switch is faulty and needs to be replaced. confirm the volume down operation by using the remote control (if available), if it works then your problem lies with the switch or a broken connection between the switch pins and the face control circuit. cheers.
Jun 21, 2012 | Blaupunkt RPD-545 CD Player
I have power to the radio, cd, and tape player but the display light indicating what station i have on the radio will not light up therefore i do not what station i am listening to. Would you please tell...
If it is a detachable face radio, you can try cleaning the contacts between the headunit and the face. IF this does not fix the problem, you will need to purchase another face for the unit or have it serviced. Hope this helped.
20 year car audio/video installer
Bay manager
Apr 06, 2011 | Sanyo EXCD-1000 CD / Cassette Player
No power at all to blaulplunkt rpd 555 faceplate model
If the face was disconnected and that was the only problem, you should be able to just reattach the face. If not, contact blauplunkt customer service and they should be able to tell you how to bypass any lock code it may have.
Jul 21, 2008 | Blaupunkt RPD-555 CD Player
PIONEER DEH-P7700MP/P770MP CD/MP3 Faceplate
do you want the detachable face or the case to hold the detachable face?
Here is the detachable face at the Pioneer site:
http://parts.pioneerelectronics.com/part.asp?productNum=XXA7322
Here is the case for the detachable face:
http://parts.pioneerelectronics.com/part.asp?productNum=CXB3520
You might find the face, or even the whole radio with face cheaper on ebay.
Jun 20, 2008 | Car Audio & Video
Jensen Phase Linear car radio
Take off the face plate and it is located in the lower left corner
Mar 17, 2008 | Phase Linear 160W AM/FM/CD Receiver W/...
302 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
