Question about Icom M302 VHF Radio
Handheld Marine Radio
Model ICOM IC-M32 that is 4 plus years old. It will not power on even if in the charger. Do you think it is the battery? It has never been replaced.
This applies to all battery powered radios. Take out the battery and measure the voltage to see if it is indeed charged. If it's not, then the fault is the charger or the battery or both. If the battery voltage shows that it is fully charged, then clean the terminals on the battery and on the radio with a pencil eraser to remove any corrosion. If still no joy, then look up in your user's manual on how to do a reset. If you don't have a manual, get on the ICOM website and download one.
Good luck.
Posted on Nov 16, 2008
Why my icom 2200h is getting hot even if i did not used it and when the power is off?
Check your wiring , you may have reversed the power suply with the stan by wires. They are both same polarity, hoever the power goes to fuse and control panel and the standby gos to baterie.
Sep 17, 2014 | Icom Ic 2200h Vhf Mobile Two Way Radio...
Icom ic-m35, no transmitting
Contact the Icom service center. Their main web-page is www.icom.com. From there you can select your geographic area and service (commercial, marine, amateur, etc).
Aug 17, 2013 | Icom IC-M36 VHF Marine Radio
IC-M504 with a rear panel microphone jack-- what is the pinout?
ICOM or even HRO may be able to provide you with a schematic for that pinout.
Jun 04, 2012 | Icom IC - M504 Black Submersible PLUS...
Need manual for rival soft serve ice cream maker model 8150
Rival doesn't have the model 8150 listed, but here's the model 8151 manual. Maybe it will be close enough to help.
Aug 07, 2011 | Rival Soft Serve 1.5 Quart Ice Cream Maker
I have an icom marine radio m505 (nearest model) which I bought over two years ago. The channels were very quiet including channel 16 so I tested it with local coast guard. I can transmit but cannot...
First of all check if your antenna cable is in good shape.
Check if there are no shorts in the connectors between the center lead and the screen tress.
Also check if the center lead is soldered into his connector pin on each connector on the cable.
Set squelsh just out of the noise zone.
Aug 06, 2017 | Icom IC M504 Black Submersible PLUS Marine...
I have a icom ic-r5 scanner that will not start
Check the battery contacts. Sometimes there may be corrosion on them from old batteries. You can also check the contacts that connect the logic board to the battery contacts. There are two small Philips screws in the battery compartment. Remove them and the back cover comes off. You can check the contacts on the inside of the back cover and see where they make contact with the logic board. Make sure all contacts are free of corrosion. If it still will not power up. try a CPU reset. While holding down [FUNC] and [V/M], turn the power ON to reset the CPU.
Nov 02, 2010 | Icom IC-R5 Handheld Scanner
If you where going to Buy one radio which one would you Buy?
I am a marine electronics technician with 28 years experience. I have also been a licensed amateur radio operator for the past 12 years. Based on my professional experience with both brands (Icom and Yaesu), I have to advise you to go with one of the Icom units. The Yaesu is a good radio, but Icom's customer support is far superior. I have had no problems dealing with their service department over the years, something I can't say about Yaesu.
Hope this helps.
Feb 21, 2009 | Icom IC-R5 Handheld Scanner
Battery`s dont last
Warp the batteries in few plastic bags.
Place them in the freezer for 48 hours.
After 48 hrs,it them air out for another 48 hrs,
The expand and contraction may help breaking the salt bridge.
Mar 15, 2008 | Icom IC-R10 Handheld Scanner
Icom M302 VHF Radio Logo
232 people viewed this question
Top Icom Boating Experts
Steve
Steve
Tony
Lawrence Oravetz
Are you an Icom Boating Expert? Answer questions, earn points and help others
