Question about Microsoft Xbox 360 Console
Error 0110 hi, perviously I was getting error 0102, solved it with the x clamps. However immediatly an error 0110 keeps on displaying... any ideas?
  • Anonymous Mar 03, 2009
    I have 3 Red Rings -- Error 0110, I have had some success with reheating the chips with a hot air gun, however, the xbox continually freezes after approximately an hour of play. for all of you that have this error, there is no permanent fix, only lucky ones. i continue to re-heat my chips once a week or so. My Xbox does have the X-Clamps Replaced because i repair xbox and i have been playing on this one for about 6 months. My solder broke because it was too cold in my room after playing it and heating it up hot, and then cooling it too fast. so for all of you that have this problem, there is no fix that is permanent. only temporary ones.
  • 3,037 Answers
0110 Memory Error / Memory Overheating - see solution for error 0102
* though it's most likely GPU related literally means the console does not know what is wrong. possibly a short or cold solder joint somewhere. So far there is 1 major theory for what causes most of these errors is that the Ram, CPU, or GPU are not soldered properly to the mother board due either to poor manufacturing or excessive heat up and cool down cycles that stress, weaken and eventually break the soldered connection.
There are two theories to fixing this one deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call MS to have it replaced. I have also heard of limited success by simply switching the AV cable from "HDTV" mode to "TV" mode.
Posted on Mar 19, 2008
SOURCE:
C-0102
The 1xx code refer to main body papre tray lift motor error.Check the paper jam in rear side to open the trays.To reset press the Utility key and hold on and turn ON the copier,wait will appaire Trouble reest on the display,release the Utility key,touch the screen and turn OFF the machine.Wait 2 minutes and turn ON.
Mar 05, 2013 | Konica Minolta bizhub Office Equipment &...
How to fix a xbox 360
RRoD is like a BSoD on Windows. It's a fatal error and a primary code. It doesn't tell you anything at this stage and the code is so generic, if can be anything from the PSU being faulty/not being connected to a specific component fault. You therefore need the Secondary Error Code (google it). If you get anything like 0102, 0020, 0110 then it's extremely possible the problem is with the GPU. Ignore any videos regarding heatguns, towel tricks or clamping / bolting. you'll just make it worse. The solder balls which attach the GPU to the main board need replacing. This is done by special equipment and is a proper fix, unlike the methods mentioned above. In extreme cases, the actual GPU needs to be replaced.
Aug 21, 2012 | Microsoft Xbox 360 Console
0102 error after xclamp fix
0102 Error in the "Digital Backbone" (CPU/GPU/RAM) is usually caused by a cold solder joint between the GPU and the mainboard.
There are two theories to fixing this. One deals with the "X" clamps that hold down the chips. The other involves re-Heating the chips. DO NOT attempt either of these if your console is still under warranty. If your console is still under warranty return it to the store where it was purchased or call Microsoft to have it replaced.
Thank you!
Jun 20, 2010 | Microsoft Xbox 360 Console
0102
Thank you!
May 11, 2010 | Microsoft Xbox 360 Console
My xbox 360 has 0110 secondary error, pls help me to repair it. ty
0110 error is related to the rrod error here is how you could solve this problem:
e74 or rrod error means that there is an hardware issue.
What you need to do is a very simple and cheap repair.
look on ebay for x clamp repair kits, these are just a few bucks and most sellers include a good guide in how to do the mod/fix.
what causes the rrod or e74 error is the X shape clamp on the underside or the mother board bending and mis-shaping causing the ball soldering on the gpu/cpu slightly melting and forming hairline cracks in the solder.
The x-clamp kit will apply more pressure to the gpu/cpu and a little trick of disconnecting the fans and turning on the xbox and allowing it to overheat will re melt the solder ball joints to fill the hairline cracks.
Depending on which chip is the issue you may also need a 2000 watt heat gun instead of using the over heating method (the gpu chip).
Replacing the heat pads on the heat sink with thermal paste which comes with the kit will keep the gpu/cpu cooler and you wont have this issue again.
Please make sure you buy the kit which comes with heat treated nylon washers as the steel spring washes fail!.
The repair takes around 1-2 hours
I hope this helps in fixing you xbox.
Nov 01, 2009 | Microsoft Xbox 360 Console
Xbox 360 had 3ROD W/error code 0102 now its 0020
error code 0020 is a overheating error.You need to do the X-clamp fix.That should solve your problem.Did you use the Acrylic silver thermal paste?
Aug 31, 2009 | Microsoft Xbox 360 Console
Xbox 360 display
This is the common "no video" error which usually comes before you get an e74 or 3rrod like 0102. Try the x-clamp fix and stop by our xbox 360 repair forum if you need more help. Good Luck!
Mar 07, 2009 | Microsoft Xbox 360 Console
Red ring of light 0102
Hi!
For detailed information on how to replace the X-clamp, follow this link:
http://forums.xbox-scene.com/index.php?showtopic=595746
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Jan 10, 2009 | Microsoft Xbox 360 Console
Error code 0102
If you're comfortable enough opening your 360, you can try this tutorial, which has worked for many people.
Jan 07, 2008 | Microsoft Xbox 360 Console
Lens Error
Firmware doesn't solve lens errors. that can only be solved by sending into repairs. Give them a call at 800-706-2534 and then keep choosing option 1.
Jan 02, 2007 | Casio QV-R3 Digital Camera
Microsoft Xbox 360 Console Logo
4,153 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
