Question about Microsoft Windows XP Professional
Folder hide i cant see some folder in my harddisk but if i tried in dos using dir/a command then its ok. but i cant change its attribute also (only for those in which i have space)
  • Microsoft Master
  • 19,396 Answers
Open tools menu, on top bar of your folder, and chose option 'folder options'. Alternatively open 'folder options' from control panel.
In 'folder options' box use view files option. In view files chose display hidden files and display system file.
Here is the way to do this in detail
To change attributes click right button of mouse on folder, chose properies, at the bottom of properties box you have the attributes.
regards
Posted on Mar 19, 2008
How
Are you talking about... ADMINISTRATOR'S PASSWORD, WORK GROUP PASSWORD to Server Database Login???
If you are talking about WINDOWS LOGIN at boot... try F5 or F8 to choose... DOS PROMPT(command prompt; safe mode command prompt is Ok as well)
Use the "CD" command to "change directory"... to change to the C:\WINDOWS directory---i.e...C:\Users\USER> cd C:\WINDOWS
Then use the command line... C:\WINDOWS dir /p/w
Now.... LOOK CLOSELY-- for "any files" with the extention of----
.pwd (this is the extention for "password files")
Simply......(example command line)---- del C:\WINDOWS\*.pwd
Type the word.... "exit" after first available Command Line to EXIT DOS... use CTRL-ALT-DEL to REBOOT
Jun 29, 2013 | Computers & Internet
Tip
How to hide files using the Attrib command
Attrib is a DOS command that sets or displays various file attributes. One of those attributes is the Hidden attribute, which determines whether or not a file can be viewed in a directory under normal circumstances. With the Attrib command, you are able to hide or show any non-system file, as well as view any file's current attributes.
To use Attrib, you must be at the DOS command prompt. In Windows XP, Vista, and 7, you can open a command prompt window by either typing "cmd" into the Run bar or by browsing to the Command Prompt (Start menu > All Programs > Accessories > Command Prompt). In Vista or 7, you can also type "cmd" into the Search bar.
The syntax for using Attrib to hide a file is as follows:
attrib <path><filename> +h
If you are currently in the directory where the file is located, you can omit typing the path. And since DOS is not case sensitive, you can use either upper or lowercase letters, or both.
If you later want to make that same file visible again, just type:
attrib <path><filename> -h
To view the attributes of all of the files in the current directory (even hidden files), type "attrib" by itself. Keep in mind that hiding a file will make it harder to find, but it does not by any means make it impossible. If you have sensitive or confidential data that should not be viewed by other users, protect it using encryption, permissions, and a strong user account password.
on May 30, 2010 | Computers & Internet
I have a WD my book drive. When I try to see the files on the drive they are Not there, But when I click the properties the drive shows half the drive space is used. how do I get the files to show be...
It is due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files. This can be fixed and data would be available to you. However, there are number of steps involved.
It is suggested that go to FOLDER OPTIONS - and select 'SHOW HIDDEN FILES & FOLDERS' and uncheck/ Deselect 'HIDE PROTECTED SYSTEM FILES'.
It would show the hidden files/ folders, if the system not infected Otherwise, from the clean/ virus free system you can see your data and copy all the required files/data. Select the required files and right-click and change the properties of the file by un-checking the hidden attribute. Please note that you can not change the properties (hidden attribute of the files) if the files are marked as system files. To change the attribute of such folders you can download and use iReset.
Also, make sure that you have a good antivirus installed and its updated. Scan your system and clean it.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 04, 2011 | Western Digital My Book Essential Edition...
Cannot find directory in commamd prompt
you want to open commamd prompt? press start+R and type cmd
Oct 26, 2010 | Computers & Internet
Hi I have 500gb Roco Hard disk, in which i hide some folder, which i couldnt able view now even after doing "show hidden file option". Thanks
Use the following command in command prompt and your problem will be gone for sure (it will not delete any content) :-
attrib -r -s -h g:\* /s /d
Note:- (replace "g" letter in the above command by your
500gb Roco Hard disk drive letter)
To open command prompt press WindowKey+R and write cmd in the box and press enter. Then write the above command on the command prompt window and press enter.
Some files are also system hidden and they can only be seen using this command.
---->Attrib command is use to change the Attributes of file/folder to showup(unhide) in windows. use attrib/? at command prompt for help.
Hope this will help....cheers:)
Sep 27, 2010 | Office Equipment & Supplies
Dos commands in linux
go to http://www.pctechguide.com/articles/gettingDedicated12.htm you will find all the commands you need in there.
Jun 01, 2009 | Microsoft Computers & Internet
Surabaya in my birthday
If you are getting message like" Surabaya in my birthday, Don't kill me, I'm just send message from your computer", then it obvious that your computer is infected with Surabaya Virus
Symptoms of Virus
1) All folders get disappear.
2) Folder options not work.
3) Machine Restarts on running command like msconfig , regedit.
4) You are unable to install many antivirus.
5) Folders name appear with scr extension ( Actually not folders)
Reasons of infection
1) Infection from removable drives e.g. pendrive, hard disk,
2) Reading cards using card reader
3) From CD or DVD
4) From others computer
5) From internet
Remedies:
1) Using free software:
Download the "Autorun Eater" from internet ( 1.5mb)
Download from:
http://oldmcdonald.wordpress.com/
http://www.softpedia.com/get/Security/Secure-cleaning/Autorun-Eater.shtml
a) Install "Autorun eater" ( some Antivirus detect it as a virus but it is safe) and run it. It appears at taskbar ( lower right corner)
b) Right click on it and follow following path
Registry fix>>fix folder option.
(This will repair folder option and it will appear in tool menu)
Now you can see hidden folders
But Surabaya virus change your folder attribute to system folder. So to see your folders you have to untcheck option " hide protected system files and folder" which appears
Right "below the show hidden files and folder" option
Path:
Open my computer>>tools>>folder option>>view>>uncheck show hidden files.. and hide protected system files and folder
How to change folder attributes to normal
You can use command prompt to change the folder attributes
A) Start MS-DOS command prompt (start>>program files>>accessories>>command prompt
B) Type drive letter and attrib command
D:\Attrib *. * -S -H -R /D /S ( Put space between /D and /S switches.)
This will change your all folder option to normal
1)Manual:
a) type "regedit" at command prompt..STRAT>>run>>regedit
b) Search word 'surabaya' in registry...Edit>>find>>Surabaya
c) Delete two entries appeared in search as " LegalNotice Caption and LegalNoticeText"
d) Now using left option tree navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\showfile
check value 0 to 1
Autorun Eater software:
Autorun Eater software helps to protect and remove autorun virus which generally infects from external storage device and internet. This small software is very helpful in conjunction with any antivirus software even it alone can protect your computer from autorun virus(but not complete solution).
(C)infoall , legal: Use above information on your own risk
Mar 21, 2009 | Microsoft Computers & Internet
Asking
Hi Mykk
If you are using Microsoft windows then follow the following steps to hide any files and folder:
1. Right click the file or folder that you want to hide
2. Go to Properties
3. Now in the Attribute Section (Below the size of files or folder)
4. Now You'll be able to see two check box option i.e. "Read-only" & "Hidden".
5. Now check mark the Hidden Option in Attribute Section.
6. Click Apply Button.
7. Confirm the option to apply settings to Subfolder & files(This confirmattion is asked only if you are hiding any folder).
8. Click OK.
9Now you'll be seeing that the folder or file's color has been changed that means you have hidden file or folder Successfully.
10. Now Go to "Tools" in menu bar
11. Click "Folder options"
12. Go to "View" Tab
13. Now in Hidden files and folder optin below Select the redio box i.e. "Do not show hidden files and folders"
14. Click Apply button
15. Click Ok
To Unhide your files or folder follow the steps from 10-15, by just making changes in step 13.
You just have to select the radio box i.e. "Show hidden files and folders.
(Rate me after you have got ur solution)
-Thanx
-Romy
Aug 03, 2008 | Microsoft Windows Vista Ultimate Edition
Run dos command through vb 6.0 without showing it
visual basic, on windows, right? jumping to dos, implies a command line, no? how else would you access a command line interface, if not through cmd?
Mar 20, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
89 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
