Question about Panasonic DMRES15 DVD Recorder
Panasonic dmr-es15 no read
G'day im having a problem with my dvd player wen i put in any dvd it keeps on saying READING........ for a bit.. then says NO READ. i lifted the top of and it looks like the laser cant find wear it wont's to stop and read it just ceaps on going back and forth close to the center and it has a noise wen it moves not a laud noise but it wasn't thare before the noise is a dull grind. if you could tell me wat it is and wat part i have to replace this wold be great have a good one jamie
  • cndhardy Jun 30, 2008
    Worked one day, the next NO READ on all discs. Noticed unit seemed warmer than usual. Removed cover and noticed that disc wasn't spinning up, although the laser head was moving back and forth. I also cleaned the laser lense, but made no difference. I'm not sure but I think this may be related to lead free solder. The main control board in the center has a label "PbF" and a BGA (Ball Grid Array) microprocessor in the middle (under heatsink). The Microsoft Xbox 360 used the same configuration (BGA and lead free solder) that caused the "Red ring of death". I may be wrong, but the pattern of failures 6 to 12+ months seems simular to the xbox. I'm told it's next to impossible to repair, but I'm going to try having the main control board run through a reflow oven to hopefully reflow the cracked solder connections.
  • rmesavage Jan 20, 2009
    My "15" worked well for a bit longer than one year then - for no known reason, "no read" status when inserting a blank R- disk. Seems the machine cycles 3 to 4 times trying to find it.
    Plays purchaced dvd's, music cd's but problems playing some disks previous recorded on this machine. will not accept R-, R+ or RAM for recording.
    I expect more from panasonic. Now made in china
I haven't tried this yet, but based on the description, it looks to be the spindle motor not functioning properly. Read below:
By panasonic dmr-es15 no read - guru_s.gif BobbyR1234
Rank: Guru
Rating: 86%, 86 votes
The most common mechanical problems that can prevent a dvd player from playing or reading the discs are the following:
1. The spindle motor not functioning properly (this is by far the most common, if the spindle motor is not spinning the discs then the optical lens can not read them). For the most part it is an cheap part to replace averaging around 25-25 dollars if you can replace it yourself. If you do not know how and have to take it to a repair shop expect to pay 50-75 dollars in labor. The key is to listen closely when you insert the disk into the player, you should be able to hear it spin up. If you hear nothing then that is most likely the problem.
Posted on Jan 26, 2009
The unit has a defective optical pickup. This is the laser diode inside the DVD drive unit. It is a common problem which requires a service technician to replace the pickup. It is expensive to replace. The pickup is $62. Panasonic part #RAF3331A. Good luck finding one cheaper, but if you do please let me know. Joe
Posted on Jan 03, 2009
Hi there
I had the same promlem
I use panasonic dvd rewrite discs and after a while if you keep on using the same disc you will the same symtoms yon discribe
All i did was change the disc a new one
best of luck John
Posted on Dec 15, 2008
Just had exactly this happen to me tonight. Was working fine last night, today I put in a CD and yep, sure enough, the laser head is running up against the spindle about 4~5 times, a quick 'spin' and another 3~4 attempts with one more spin and then it's shutdown with a "NoRead" error.
Not really happy about this, prior to this event it was the best DVD player in the house with it having no skips/jumps/lagging like the other cheaper players.
Interesting theory about the Pb-free issue, could well be a tin-whisker issue but it's going to be really difficult to prove either way. Don't have a reflow oven handy alas :(
Posted on Jun 30, 2008
  • Anonymous Jul 04, 2008
    I tried a localised reflow with the hotair to no avail.
    I am wondering if perhaps there's a firmware logic fault?
    The only thing I did differently (that I hadn't done in a while) was to plug my DV cam directly into the ES15 via the firewire port.
    Things -initially- seemed okay and the DVD-RAM was initially accepted, but when I went to record that's when things died on me.
    Is there some sort of "universal reset" option on these boards? I tried the 'factory defaults' option from the on-screen menu to no avail.
  • Anonymous Jul 07, 2008
    Contacted Panasonic support - replacement main controller card is about $270 AUD - you can get new ES15's now for less than that *sigh*.
SOURCE:
Error reading any dvd disks
Have you tried a DVD+/-RW ?
The noises that you are hearing will be the spindle motor trying to spin the DVD as the lifting presentation tray for the read/write head has not located, if the media is not spinning this will never be able to read the lead in on any DVD as it has not presented the disc in the correct place.
If is is out of guarantee then I suggest that you check to see if the DVD is spinning by removing the top cover with the power OFF then eject the tray and try to load the media a small touch of the DVD in the clockwise motion should cause the media to start spinning, this is for diagnosis only if this is the case then the spindle motor will need changing
May 28, 2010 | Panasonic DMRES15 DVD Recorder
Dvd tray will not stay closed even with no dvd in tray
try wen u press the close button with a dvd inside just keep your finger pressed against it until the dvd starts to read then it will come on and your disk day will stay closed
Jan 25, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
DVD Player Not loading Movies
optical sensor is burned out or the spindle is not spinning the disk to read it.
Nov 06, 2009 | Coby DVD-224 DVD Player
Can't open the DVD door. Wen I turn on the DVD Player, it starts reading a DVD that's stuck inside, and after a while e turns off alone. The door doesn't open and it seems to have some process runing that...
you'll have to remove the top and remove the disk that way. there's a top bracket on the dvd drive to remove before you can get to the disk. and unplug the unit first!!
Aug 12, 2009 | Philips DVDR3330H DVD Player/HDD Recorder
RCA DRC 8052NB will not read discs
This sound like a problem with the laser read circuits and it may be solved with a simple cleaning and using compressed air to clear the unit of debris .To do this you must take off the top cover of your unit by taking out the screws and lifting the top off. To clean the laser head you should use cotton swabs and isopropyl alcohol. put a small amount on the cotton swab and rub the swab gently back and forth over the head, until it seems bright and shiny.Check the transport carriage for dust and debris and also the gears. all these must be clean for proper operation. You may want to put a little lithium grease on the gears and guide rails for smooth operation. All this should be done in minute amounts so you do not over do it and cause more problems. If all this fails to allow you to use you disc player, Then you probably have a worn out laser sensor and will have to have it replaced. If under warranty send it in and if not try to find the part number and order it and either take in to a service center for repairs or do it yourself. Hope this helps you with your problem.
May 15, 2009 | RCA DRC8052N DVD Recorder
Dvd and cd will not play
Mine done the same, suddenly froze in mid play and would no longer read any discs. Kept saying 'no disc'.
In a slight bit of frustration I gave it tap on the top front middle!
Strange to report that it has worked perfectly ever since! (fingers crossed).
Bit of a cowboy fix but it worked....
Aug 25, 2008 | RSQ NEO-E500 DVD Player
DVD just says reading.....
Too high speed when writing discs. Use no more than 8X. Try 4X. Also, read again the user manual and check the kind of MP3 files this device can read.
Sep 13, 2007 | JVC KD-AVX1 Car DVD Player
Dvd player not reading ANY disc
If you tryed to clean it and it didnt work you could have several things that went wrong and depending on what did go wrong will tell you if you wanna spend the money or buy a new one. If the laser assy went bad you probably will buy a new one. if you find a good authorized repair shop, then it may just need cleaning and a servo alighnment. or a bad spindle motor, or your missing a switched voltage on the power supply could be missing. Im sorry to tell ya that there are no user serviceable parts inside this unit unless your a tech. The only info i have for emerson is the help # Maybe they can show you where to take the unit to be servced/ 905-940-5089 Good Luck
Jun 30, 2006 | Emerson EWD2202 DVD Player/VCR
Panasonic DMRES15 DVD Recorder Logo
2,144 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
