Question about Epson Stylus CX4200 All-In-One InkJet Printer
Epson stylus cx4200 all-in-one?
How do i test which cartridge needs replacing on my epson stylus cx4200 all-in-one? i lost the manual.
You don't need to replace all the cartridges if only one is empty. BUT if you're trying to print in black, and another color is out, then you need to replace the empty color even if your blank ink is full.
Posted on Apr 23, 2009
The answer is simple: ALL your inks need replacing if only ONE is empty. Class action lawsuits have been fought and won against Epson because of this "design flaw". Throw out your printer, that's the only real solution.
Posted on Dec 12, 2008
  • jaime battye Jun 28, 2011
    I think that this is stupid. I would never had purchased this printer if that was told to me when I bought this item. It makes me mad, I have been trying to get my printer to work for 3 hrs now, because I would never had thought that a printer couldn't just use black ink. But I guess I was wrong thanks for posting this..
    Scholar:
  • 91 Answers
1. Make sure the printer is turned on.
2. Make sure the document cover is closed, then closed, then open the scanner.
(Do not open the scanner when the document cover is open).
3. Press and release the ink button. The 'On' and 'Ink' lights flash.
If one of the cartridges is low or empty the printer moves that cartridge to the 'ink out' mark. Go to step 4.
If no cartridges are low or empty the ink cartridge holder moves to the ink replacement position. Go to step 5.
4. Pree the 'ink' button again.
If more than one cartridge is empty or low the next cartridge moves to the 'ink out' mark.
Once the printer identifies all the empty or low ink cartridges the print head moves to the ink cartridge replacement position.
5. Open the cartridge cover, squeeze the tab at the back of the empty cartridge and lift it out.
6. Before you open the new cartridge package shake it four or five times and remove it from the package .
(Don't remove or tear the label on the cartridge otherwise ink will leak out) .
(Don't touch the green chip on the front of the ink cartridge - you could damage the cartridge).
7. Place the new ink cartridge into the cartridge holder and push it down till it clicks into place.
8. Replace any other cartridges that need replacing.
9. Close the ink cartridge cover and press it until it clicks into place.
10. Close the scanner.
11. Press the 'ink' button. The printer starts charging ink and the 'on' light starts flashing . This takes about a minute . When it's finished the 'on' light stops flashing and remains on and the 'ink' light goes out.
You'll see all the above, with helpful pictures, at
this Epson support page
Posted on Mar 19, 2008
I have windows vista. epson stylus cx4200 will print but does not scan. installed windows 7 64 bit drivers but not successful. need help. thanks
Download & install the "Epson Stylus CX4200 All-in-One Printer" @ Drivers and Utilities Combo Package
Windows 7 64-bit compatible, Windows Vista 64-bit
epson13071.exe - 20.9MB
- posted on 07/07/09
This file contains everything you need to use your Epson Stylus CX4200 with Windows Vista 64-bit.
This package consists of the following items:
•Printer Driver v6.5
•Scanner Driver v3.04
•Epson Status Monitor 3
•Epson EasyPrint v3.10
Uninstall your previously installed AIO drivers before installing the downloaded installer.
Hope it helps.
Jun 02, 2011 | Epson Stylus CX4200 All-In-One InkJet...
How to change ink in a canon cx4200
Just follow this link to view the user guide available from epson. Then click on 'removing and installing ink cartridges' link.
http://files.support.epson.com/htmldocs/cx42__/cx42__00ug/wwhelp/wwhimpl/common/html/wwhelp.htm?context=Epson&file=maint2.htm#wp1020194
If you have any issues let me know.
Thank you,
Lee
Jul 16, 2010 | Epson Stylus CX4200 All-In-One InkJet...
We have lost the manual and don't know how to change the cartridges. We have put them in correctly but the red light stays on and the green light keeps flashing
Here is a link to your manual. I couldn't locate a Stylus DX4200 only a CX4200.
Hope this helps.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=58605&prodoid=56291068
Nov 08, 2009 | Epson Stylus DX4200 All-In-One InkJet...
I need a cx4200 printer owner's manual. I cant find where it is on the net..I need to know the steps to replace ink cartridges. Bob C.
Have you tried " Epson Stylus CX4200 manual" on Google?...
Go to:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58605&infoType=Doc
You have all the documents there, including a User's Guide.
Oct 25, 2009 | Epson Stylus CX4200 All-In-One InkJet...
I bought new cartridges for my Epson Stylus CX4200 All-in-One, but the yellow and Magenta barely print. I have run the head-cleaning program on the computer, the one with the colored lines, and it...
Use "spet" (tube only). Add flexible pipe (cut from oultet pipe of head cleaning mechanic). Connect to nozzle. Fill tube with cleaner. Move head to parking position. Do suction from outlet pipe of head cleaning. It's the safely way to clean print head manually.
Jun 21, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Epson stylus cx4200
need to download cd forthe epson cx4200
Aug 12, 2008 | Epson CX4200 All-In-One PSC Printer
Epson Stylus CX4200 All-In-One InkJet Printer Logo
408 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
