Model 1532 pti television
The picture is not responding only some dotted lines come then after a while t.v got swith off and comes on stand by mode
    Sergeant:
    Champion:
  • 375 Answers
Are the dotted lines through the middle of the screen ,if so youhave a vertical collaspe fault,not a difficult fault.requires shop repair if possible to save you the service call to your home,i would use the service charge for labor on the repiar charges.
Posted on Mar 20, 2008
SOURCE:
Sony bravia tv kdl-32nl140 picture comes on and after 10 min i get dotted lines and stripes
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 11, 2014 | Televison & Video
SAMSUNG UN32EH4003F POWER LIGHT COMES ON BUT NO PICTURE OR SOUND
Your tv is in stand by mode and not responding to power on command. It may be a main board issue. Please consult someone qualified.
Dec 27, 2013 | Samsung UN32EH4003F
Sharp view area
This has something to do with the setting. Try resetting through remote and see.
Aug 21, 2012 | Televison & Video
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
Nov 19, 2010 | Televison & Video
When scanning dots show up in a vertical pattern
Printer DPI and PPI Ratings, General Dots per inch stands for the maximum number of tiny spots of ink that the printer can place in a straight line where the spots are theoretically small enough (i.e. ignoring spreading or smearing effects of ink on paper) that if placed in every other such dot position leaving white space between them, the spots can be individually distinguished. Pixels per inch stands for the maximum number of unique positions in a straight line that the printer can place an ink spot under control from the outside world, namely from a computer connected to the printer. Lines per inch stands for how close thin parallel lines can be printed and still be distinguished in the finished printout. The spaces between the lines count as "lines". Pixels per inch and dots per inch originally referred to the same thing. The printer mechanism was under the direct control of the computer and was physically positioned and placed dots as directed by the computer. Back then, most printer mechanisms were limited to placing dots only in positions suggested by a grid of dots X per inch horizontally and Y per inch vertically, for example 100x100 dpi Nowadays, many printers put dots "wherever they want" as opposed to in positions suggestive of a horizontal/vertical grid. Still there is a minimum dot size and a minimum dot spacing. A picture file (image file) represents pixels in a uniform horizontal/vertical grid pattern. And the printer needs to make a finished picture of the size, say 5x7 inches, that the user chose regardless of the number of pixels in the picture file. To simplify the process of relating the pixel count in the picture file to the possibly non-uniformly spaced dots on the paper, the printer or its supporting software may generate a temporary intermediate picture file with a set number of pixels per inch. The printer may have, internally, several choices of ratio of pixels to dots and the published rating can be the largest ratio except that the published rating may not exceed the dpi rating. Therefore there might be three "per inch" values involved at a given time, the pixels of the original picture file, the pixels per inch that the printer works with, and the dots per inch of the printer mechanism. Pixels per inch is usually not mentioned with printers. All printers come with their own software (including parts called drivers) to install on your computer. Usually the software does not let you exercise control over individual dots using your picture file. Rather the printer takes your picture file or data file and uses its own built in logic to lay down the dots and create the printed output. We are led to believe that a printer's ppi is usually a fraction such as a half or a third of its dpi rating. When a temporary picture file is created, there are at least two levels of software in use. High level software (which may run in your computer) takes your picture file and creates the temporary file. Low level software runs in the printer, takes the temporary file and controls the dot size and dot placement on the paper. Sometimes a printer is advertised using a phrase such as "300 dpi 1200 dpi quality". This means that the printer has some way of making dark edges on a light background appear smoother than the first number would otherwise suggest. A printer with 300 dpi 1200 dpi quality definitely cannot resolve alternating dark and light pixels less than 1/300'th inch each. But curved and diagonal lines and color boundaries should not have jagged edges suggesting individual dots rigidly positioned on a grid with a 1/300'th inch pitch.
Oct 24, 2010 | HP LaserJet 3050 All-In-One Printer
Ford Focus zx3 2002 audio question
CLOCK IS SET VIA RDS. PTY STANDS FOR PROGRAMME TYPE ITS LIKE A SEARCH ENGINE FOR RADIO STATIONS AND TA STANDS FOR TRAFFIC ANNOUNCEMENTS IF IT IS ON IT WILL TURN OVER TO LOCAL RADIO STATIONS AND GIVE YOU TRAFFIC REPORTS
Jan 13, 2009 | Car Audio & Video
Onida stand by problem
sir my onida tv 21'' ineed un lock
Nov 07, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Disabling Power Save mode
If you enter the config menu, you can turn off energy conserve. You enter the config menu by turning off the printer, holding the center and right arrow, and powering the printer on. Continue to hold the buttons until you see Performing self test. Then you will see config menu. If you scroll down to energy conserve and select it. You can change the option to off. This will disable power saver.
Jul 01, 2008 | IBM Infoprint 1532 Laser Printer
Lexmark 1532
If the Operator Panel is locked. (Menu's disabled) you need to enter Config Mode to enable the operator panel. Press and Hold the > right arrow and down arrow buttons while powering on the printer. Once in configuration mode scroll to Panel Menu where you can enable it. Exit Config Mode or just power the printer off and back on.
Mar 28, 2008 | IBM Infoprint 1532 Laser Printer
Can't adjust the value of the width in Service mode ' WID '
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 05, 2007 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Ekse
