Question about LG Flatron L1951S 19" LCD Flat Panel Monitor
Power saving mode
When i hook my laptop up to my tv it just says power saving mode
  • Anonymous Sep 30, 2008
    Cant turn on monitor it displays "power Saving Mode"
    sad..
    Problem Solver:
  • 4 Answers
What brand is your laptop? Sometimes you have to manually switch between your laptop and an external monitor. Usually pressing the "CTRL" button and "F5" might work to switch the signal from laptop external.
Posted on Mar 19, 2008
2 Suggested Answers
  • 47 Answers
SOURCE: lp w1952tq goes into power saving mode
one some laptops you need to enable the video/vga port (where you plug the monitor in). On a Dell, you'd press function (Fn key) and F8 - this will activate the additional video out port. If you keep pressing that combination, you'll get one, the other, or both working in sequence.
Posted on Jun 06, 2009
I have an RCA STB7766G1 CONVERTER FOR my 30 year old TV SET
I would suspect the power supply on the converter is failing. You should see the power light on the converter go out if this is the case. If the light is going from green to red, it may be going to power save mode. (Menu->Option->Power Save Mode -> Off)
You may be able to find a replacement 9 Volt power supply for low cost.
Here is a link to the manual:
http://www.voxxintl.com/docs/common/STB7766G1/STB7766G1_OM.pdf
Feb 04, 2016 | RCA Televison & Video
HDMI cable hooking up and using
use hdmi cable with right connect for tv and PC ends
using tv remote press source button
If PC is in power save mode , press the ESC key
Mar 24, 2014 | TCL 39" LED LCD 1080p HDTV - TVs & Home...
LG TV Goes Into Hibernation (I Think)
This could be two things 1- a power saving mode in the TV... go into settings on the TV, look for either "power save settings" or "energy star settings" go in and turn that off. 2- it could be a screen saving mode because the TV has lost signal...some HDDVR receivers such as Direct TV DVR etc...have their own power saving mode, after a couple our of inactivity, they turn off, which kills the signal to the TV...so the TV shuts down because it has no signal coming to it.... if that is the case, you need to go into the settings on your cable/satellite settings and also look for a "power save mode" or "energy star saving", and turn that off.
Mar 21, 2014 | Televison & Video
Connection to PC
I have had the same problem. If you have a VGA cable shown at the bottom. You can hook that into your laptop into the TV. The slots look like a blue incovering. You can also look at the image below that one for more additional help....
images?q=tbn:and9gcsiv-gyi4jh5l6apvblrydzbiwzndoskvj3ytpifllclwa1qmks
images?q=tbn:and9gctjzjmvlnbu_yfg04yh87cl2mau36aexgpvkl7rwz0yczn0azmwaq
Jan 29, 2014 | LG RZ23LZ55 23 in. LCD Television
LAMP KEEP BLOWING OUT. TOSHIBA 65 HM167
I had this same problem with my Mitsubishi it is when you have fast on mode set it pre warms the bulb to much. I turneed it off and now the bulb has lasted much longer Setting the Power-On Mode feature You can select either Power-Saving or Fast mode. If you select Power-Saving mode and you turn off the TV, it can take several seconds for the picture to appear when you turn on the TV again. Power-Saving mode saves more power than Fast mode. See "Specifications" on page 66 for details. If you select Fast mode and the TV is turned off, the TV will stay in Standby mode for several minutes (see Note below). If the TV is turned on from Standby mode, the full picture appears immediately. To set the Power-On Mode feature: 1 Press Y and open the Setup menu. 2 Highlight Power-On Mode and press c. 3 Press b or B to select either Fast or Power-Saving and press T. Note: If Power-On Mode is set to Fast and you turn off the TV, the following will occur for a few minutes: • The screen (lamp) lights dimly; and • The fans continue to run. This is a function of the Power-On Fast Shutdown mode and is not a TV malfunction. If you do not prefer this, set the PowerOn Mode feature to Power-Saving. When the Power-On Mode feature is set to Power-Saving, if you repeatedly turn the TV on and off in a short period of time, the useful service life of the lamp may be shorter than the average useful service life (- page 63).
this is from your manual not my Mitsubishi please rate this answer if you felt it was useful.
Feb 03, 2011 | Toshiba Televison & Video
My LG flatiron W1943TB turns on, says analog power saving mode, goes black and then the power button flashes.. but the monitor is hooked up to my dell notebook bc my LCD died
Hi erin mckinle,
That is probably it's, uh, analog power saving mode. When the screen goes black and the power button flashes, make some mouse gestures or hit some keys that would not affect anything (try spacebar). That should bring up the screen. If you think it goes into power saving mode too fast, go to Control Panel --> Power Options, and change the values. Hope this helps.
Jan 02, 2010 | LG W1934S-BN 19" Monitor
Lp w1952tq goes into power saving mode
Jun 06, 2009 | Computers & Internet
External monitor says laptop is in power save mode and goes blank
hey jkep
this has nothing to do with power, here is what to do
right click your desktop->
properties->
click the settings tab->
click the advance button->
click the display tab->
depending on your graphic card there should be 2 or 3 different monitors being displayed switch them on and automatically your TV will turn on then you can change the settings to your likings
Feb 13, 2009 | Acer Aspire 5610 Notebook
Windows XP in Power Save Mode with blank screen
PC DESTOP ?
PC LAPTOP???
WITCH ONE DO U HAVE???
Nov 18, 2007 | Microsoft Windows XP Home Edition
LG Flatron L1951S 19" LCD Flat Panel Monitor Logo
132 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
