Question about Bissell 1631 PowerSteamer ProHeat Canister Vacuum
Not working I know it is pulling in , but when i turn it own it will not let the solution out. I cannot use it. one part is not in somewhere
  • Anonymous Feb 07, 2009
    my steamer will not spray solution or water
    Problem Solver:
  • 8 Answers
I found resources for getting parts, at Ebay and here- http://www.buckeyevac.com/site/. Haven't used them but it looks promising.
Posted on Feb 21, 2009
    President:
  • 1,673 Answers
This hooks direct to the faucet for the water. The spray handle maybe isn't working. But sorry to say Bissell has obsoleted all parts for this model. Time to buy new.
Posted on Mar 20, 2008
SOURCE:
The power that pulls my Dyson vacuum is not working
I don't know of any Dyson models that are self-propelled. What is your model number?
Sep 01, 2017 | Dyson Vacuums
No suction
hey, how are you ?
here are a ew things that could be causing you sorrow
1.) Check your vacume to ensure that it isnt clogged anywhere
2.) before your compressor and after the filer, this part is where the suction takes place, check to see that it isnt clogged or that it isnt broken...
3.) check your packing (diapharam) in the vacume oto see if it ruptured(has a hole or broken)
4.) Check for lears on the vacume, basically run a pice of paper all over it and see if it is pulled to the vacume.
Once air is coming out the back, it means the compressor is working, but it alos means that the vacume is clogged, or a compartment that is u\supposed to be sealed is broken, or it has a leak somewhere..
My bet is that it is clogged somewhere, take it apart you will find it..
Jan 09, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
What is the right bag for sebo x4
  1. First, pull out the hose, turn the unit on, check for an obstruction in the hose. (unclog and obstruction)
  2. Separate the body from power nozzle. Check for obstruction in the air hole passage.
  3. Pull and clean both filters in the unit. The inside white long carriage and the exhaust filter located above indicator panel. (nozzle body)
  4. If this is not working. think about where and how dirt is carried or passes from the front floor nozzle or through the hose.Somewhere in the unit the it is clogged. The red light censers a full bag (we know that's not the issue) or an obstruction to the normal air flow.
  5. Last Resort contact http://www.sebo.us/contact_us.aspx
  6. In closing: I've been selling and repairing vacuums for over 30 years. Of all the 5 major brands that I sell. Sebo is by far the, best product on the market.
Aug 23, 2014 | Sebo X4 Bagged Upright Vacuum
NuTone Central vac won't turn off
If the central vacuum tank will not turn OFF even with the switch in the “OFF” position, then the low-voltage wires should be disconnected from the tank. If the tank continues to run and still will not turn off, then most likely the relay inside is defective (but it could be a defective and/or shorted ON/OFF switch). If with the low-voltage wires disconnected the tank is able to then be turned off with the switch, then there is a short in the low-voltage wires or a hose is plugged into an inlet somewhere. ~ TTURAMBAR
Mar 11, 2009 | Broan-NuTone VX475 Bagged Central System...
Series 6500 SR won't start
Look for a restriction somewhere in the suction system. Inspect every last inch of it so you know it is clear.
Jan 24, 2009 | Electrolux Epic 6500 Vacuum
Beater bar works intermittently
When you push the hose into the tube, there is an acuator that will push the switch so the beater bar will turn. That switch could be just dirty, dust gets in them and they won't always work, the acuator may need to be replaced. Either that or you have a bad wire connection somewhere in the noozle or where the wires just go into the noozle asm.
Apr 13, 2008 | Kenmore 31913 Progressive Direct Drive...
Brushes not turning
Check the belts, there ia cogged belt that drives the brush roll. Turn the unit over, take out the one screw holding the red lock, pull that off then the cap for the brush roll will pull out, remove the cap and check the belt, also check the pulley on the end of the pump to make sure that it still has cogs on. If there are no cogs, then you will have to replace the pump. While you have the brush roll out, make sure the it looks ok on the end and not melted. This would also be a good time to replace the **** belt if it needs it.
Jan 07, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuum bar not rolling
Belt is busted . Need new belt . Vac comes with three additional belts. Ask your roomate belts he should have them somewhere.
Oct 16, 2007 | Eureka 5892AVZ Bagless Upright Cyclonic...
Bissell 1631 PowerSteamer ProHeat Canister Vacuum Logo
173 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
