Canon Laser Class 720i
Has always filthy print out even if with a new cartridge/toner. What could be the possible problem?
  • 15 Answers
First I would determine if it is the fax or printer that is causing the dirty prints.
First, print a report, any report, and see if it has dirty prints. If so it is the printer that is bad. If not, try making a copy. If you get a dirty print then, your scanner is dirty or bad. If the copy is good, have someone fax to you. If that is bad, then your phone line, their fax or the unit's modem is bad.
If the printer shows bad, do an interrupted print. Put a page in the front tray and do a report print. As the page just disappears into the machine pop open the cartridge lid and take out the cartridge. If the page is dirty at this point then the cartridge is bad or you have a serious problem with the electronics. (Remember, the toner is not fused on the paper when you stop it at this point.)
Posted on Mar 22, 2008
  • Oh, I forgot to tell you that if the page is printed good when you interrupt it while under the toner cartridge but is bad after that then your fuser is bad. The fuser can develop a torn fuser film and cause poor prints.
    New Friend:
  • 120 Answers
The drum is n/g or the optics are dirty. possible print roller.
I cannot re install the toner cartridge in my Canon Image Class mf 3240
Possible the toner is got damaged while removing it with the printer and replace it with the new one.
Jan 01, 2013 | Canon imageCLASS MF3240 All-In-One Laser...
How do you set the toner cartridge on a Canon Image class D1150
Try printing a test page first. 2) Shut down printer then re-start. 3) Printer on, re boot the PC. If nothing works, take cartridge out and start over when the printer is off. No help! Then you need real help because your memory is not working properly or an electrical glitch in the mother board or cord.
Aug 09, 2012 | Canon Image Class D1170 Laser...
Canon monochrome laser LBP3108b printer cartrige can be refill?
I would not advise on refilling a toner cartridge, the toner power is very fine and you do not want to breath in this toner powder.
You can purchase a new toner cartridge or a recharged toner cartridge these are cheaper than a new cartridge.
You can get a few more print pages out of a empty toner cartridge by shaking the toner cartridge in a horizontal position and inserting back into the printer.
Dec 04, 2010 | Canon LASER SHOT LBP-2900 Printer
Canon image class MF 4150: it is flashing, message says toner is not set insert toner. Toner has been inserted, it was working this morning, I printed documents fine, now this message. I have taken the...
spacer.gif If you removed and reinstalled toner correctly several times and this error code is flashing, you need to try another new toner cartridge, even though the other one may seem still good to you. If this doesn't remedy problem the Troubleshooting section of the Canonusa.com website says to call 1-800-OK-CANON.
Jul 16, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Printer wants toner cartridge replaced, though not empty
unfortunately the drum within the cartridge has reached end of life so changing to a new drum cartridge would resolve this issue.
Mar 25, 2010 | Panasonic KX-FLB801 All-In-One Laser...
My Canon Laser Class 710 fax machine is flashing a red error and the message states ''received in memory'' .. How do I clear it?
You could be out of toner = new toner cartridge.
You could be out of paper = reload paper
You could have a printer problem, paper jam, door open, etc
get the printer part working.
does it print a report if you press the 'report' key?
Nov 13, 2009 | Canon Office Equipment & Supplies
D880 printer won't put toner on the paper (prints blank)
make sure the replaced toner is in good condition and is placed properly in printer refilled toner often alarm about low ink but work properly
Jul 22, 2009 | Canon imageCLASS D880 All-In-One Laser...
Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Apr 10, 2009 | Samsung ML 2010 Laser Printer
Printing blank pages from word and now every time canon 6530
There is a service update from Canon, where a part needs to be change in the laser area. You can try to slam the toner door shut to see if it changes it temporarily, but a laser shutter arm needs to be changed.
Mar 25, 2009 | Canon MF-6530RF Factory Reconditioned...
122 people viewed this question
jasbo
jasbo
