Question about Refrigerators
Water leaking from my refrigerator
I have a samsung rs253basb. On the fresh food side water pools up on the bottom shelf, turns to ice and then runs out the corner of the unit on to the floor. It seems to happen every few days. On this unit the water filter is on that side however it "appears" to be coming from the small vent that is also on the right behind the the bottom shelf.
Any suggestions?
  • Refrigerators Master
  • 19,396 Answers
Seems to be a condensation proble, is it possible to lower down fridge temperature a bit? This may solve the problem.
Posted on Mar 19, 2008
  • Ginko
    Ginko Mar 19, 2008
    The defrost drain hole may also be clogged, this combined with condensation near to the fan zone can create your problem. Check that the drain hole is not clogged.
    Also check if there is any water line running near the point where you noticed the water coming from, a broken water line will create same problem.
    regards
SOURCE:
I have a Samsung srs585hdis side by side fridge and there is quite a lot of water leaking from a cover behind the bottom veg baskets. What would cause this?
The evaporator condensate collection pan drain inside the fresh food section is clogged or blocked with ice. You will need to take the cover off to clean out the drain. Here is a link that shows the breakdown of parts for the fresh food section=> HERE
Here is a link to=> Leaking Refrigerators
This video only applies only because it shows examples of what is happening to your refrigerator
APPLIANCE 911
Dec 21, 2015 | Samsung Refrigerators
LEAKING WATER IN SIDE THE REFRIGERATOR
I assume you are talking about ice and water in the fresh food compartment. It is most likely that the defrost drain is blocked in the freezer causing the water to drain through the air vents into the fresh food area. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube. You may want to place a small tub in the top shelf to collect all the water that will pour through the vents and have some towels. it can get very wet.
Aug 17, 2014 | Refrigerators
Accumulates water on bottom floor below bins
I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators!
Thanks, Sea Breeze
Jul 19, 2012 | Sub-Zero 695/O Side by Side Refrigerator
Kfis25xvms2 kitchenaid leaking at bottom.
You need to unplug remove the contents of the freezer and then remove the rear panel on the back wall of the freezer. Once that has been removed you will see the evaporator and at base of evaporator you will then see a defrost drain. Melt any ice that may be blocking the drain and then use a turkey baster to force hot water through the drain to disloge any ice or gunk that may be blocking the drain further down the drain line that ends up at base of refrigerator in a condensate drain pan.
I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers. This is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more simple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> Magic Chef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Jul 19, 2012 | Refrigerators
Why is there water and ice on top of the vegetable bin in my refrigerator?
I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! Thanks Sea Breeze
Jul 14, 2012 | Refrigerators
Samsung model#rs253basb side by side/ water pooling under vegi drawer & leaking out onto floor. water dispenser works when it wants too-not very often these days.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 15, 2011 | Frigidaire FRT15G4B Top Freezer...
Water pooling on bottom of freezer and leaking into fridgerator
in the back of the fridge you have a hose going to the bottom , take everything from inside of the fresh food compartment and blow in the hose and after voila problem solved
Jun 17, 2009 | Refrigerators
Samsung RS253BASB leak at bottom veggie drawer
I had the same problem. I called tech support and they were no help. Being a handy man I dove into the problem myself and discovered the problem. If you want this solution, I have pictures and information. Simply email [email protected] and I will send you this infomation.
Jun 07, 2008 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
202 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
