Wireless wont stay on
Hello, I have an older Gateway Solo that I installed an early version of xp on. I bought a Netgear WG511t wireless adapter (refurbished with no call in tech support) and when I finished setup the display showed that I had an excellent connection and the lights on the adapter start out flashing togather which shows it is connected, then in about 5 seconds without touching or doing  anything, the connection drops out (no signal strength, and the lights on the adaper are flashing alternately and a dialog box pops up saying wireless connection unavailable). Thanks in advance for any assistance that you can give to solve this problem dittto1
    Guru:
  • 377 Answers
Hi dear
try this
  1. Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP key are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their web site or when you purchase access you will be provided the information.
  2. Ensure you have a firewall program installed and running. This will protect your data.
  3. Start up your laptop and once booted, look for the Wi-Fi network icon in the bottom right of the screen.
  4. Click on the Wifi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click on the Properties tab.
  6. The next window will show the type of networking card installed. Click on the Wireless Networks tab.
  8. Once the Wireless Network Connection Properties window is open you will have two options depending on how you set up your laptop.
    • If you do not see any networks listed in Preferred or Available networks, you will have to manually add the SSID. Click on Add. You will have to enter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available networks box.
    • If you see the correct SSID showing in the Available Networks, then you need to click on Configure in order to enter the WEP key if that is required.
    • In the next window, enter the SSID for the Wi-Fi network you want to access. Make sure you do not have CAPS lock or NUM lock while entering the information. If a network key is required, click on "Data Encryption and then enter the Network key you have been provided with. Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly a message will pop up and you will newireless wont stay on - fccfda9.jpgter the key.
    • Next go to Start - and where it says Connect To click on that and you should see choices like in the graphic below. Click on Wirelesswireless wont stay on - 34b0a7b.jpgonnection and it should work.
There are occasions when the connection doesn't work, in these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall program disabled, you change your settings. If your firewall program is not the problem check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
oke post in me back
i hope this usefull for you
thanks
cropp
Posted on Mar 19, 2008
Need driver for wgn111 for a desk top running me2000
what version is that? 1 , 2 or 3.
If version 1, click this link.
http://kb.netgear.com/app/answers/detail/a_id/711
Nov 08, 2010 | NetGear (IM-WG511T) Wireless Adapter
The pc said the setup needed to be reset. i uninstalled the etgear and now i dont know how to reinstall. i dont have the cd. product is netgear 108 pc card wg511t
Go to the web site below and download your driver, then simply run the setup installer by double clicking on the .exe, it will then install your software and driver.
Feb 16, 2010 | NetGear WG511T 108 Mbps Wireless 802.11g/b...
When I install it says Card unplugged when it is firmly plugged in
i have netgear wgr614v7 and a broadband connection working without security code, when i tried to configure to put a wep i reset the netgear and now it is not working . what should i do to have a connection via netgear and with security password
Dec 04, 2009 | NetGear WG511T 108 Mbps 802.11b/g Wireless...
Netgear wont work on windows 7
Windows 7 official release is in Oct. The Windows 7 version you have is probably the Release Candidate version, this is the last Beta version before its offical release. This version does not have drivers for a lot of devices and if you cannot download the driver from Netgear WEB site at this stage then you have to wait until it becomes available.
The release Candidate will shut down every hour early next year and will stop working completely in June. You will be forced to buy Windows 7 or go back to XP or Vista.
Sep 21, 2009 | Computers & Internet
Netgear usb adapter will not acquire ip address from router
Most laptops have a wireless card built in them and if you have one you should try using that instead and form past experiences USB adapters don't generally work on laptops in which case if you laptop has the slot for it you should buy a card like this http://www.netgear.com/Products/Adapters/SuperGWirelessAdapters/WG511T.aspx
Nov 27, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
My wireless adapter lights up steady, but won't connect to the internet
Check the adapter in device manager whether it is installed or not.
if it installed properly. then visit Netgear website for latest drivers
http://kb.netgear.com/app/products/list/p3/43
and download it and uninstall the older version and install the latest version.
thn try to connect it wireless with your wireless settings.
and after that if u'll have the same probl please reply..
Aug 27, 2008 | NetGear (IM-WG511T) Wireless Adapter
HP dv6000 and NetGear WG511T
try other PCMCIA slots...actually there 2 of them in every laptop.
Aug 10, 2008 | NetGear WG511T 108 Mbps Wireless 802.11g/b...
Wg511t on thinkpad 1400
Make sure that the router and the wireless computer has the same wireless settings. That is assuming that the wireless adapter has been correctly installed on the computer.
If you have questions just ask me and ill answer you as soon as I can.
Apr 13, 2008 | NetGear WG511T (ASKU23063) Wireless...
Netgear WG511T
You can download the software from here.
Dec 16, 2007 | Computers & Internet
Initial Startup
BECO'Z OF THE PROPERLY ISTALLATION OF THE DRIVER YOU DO ONE THING RE-INSTALLED THE DRIVER.
Nov 20, 2007 | NetGear (IM-WG511T) Wireless Adapter
Computers & Internet Logo
502 people viewed this question
David Payne
David Payne
