Question about Sony PlayStation Portable (PSP) Console
Tv fault I am TV Repairing Tech. I have a sony tv set, kv-14q2, When I turn the power on, the set go back into standby quickly.
  • tpsa_ong Jul 21, 2008
    I have a Philips 29" TV with a similar problem. When I switch on after
    a few seconds it goes off but not sure if it goes to standby. The
    standby light is off but when I press the standby button on remote the
    standby light comes on. On pressing the button again the light goes off
    and the tv comes on. Is this a standby problem?
    Ong1057
  • 31 Answers
Your tv switch might not be contacting the switch on the actual tv itself
Posted on Mar 28, 2008
SOURCE:
Sony kv j14l1
If there is any blinks occurs to standby power LED during switch On, and the set switches off automatically?
Jun 01, 2013 | Televison & Video
KV-24FS100 TV shutting off
How many times the standby light flashes in between switch ON and going OFF?
For more details about this fault, visit this site, and call older posts.
Type in this link address, [without brackets] either to Google Search Box or into the Address Bar to your browser and press Enter. It has all the details about blinking codes of Sony Sets.
electronicshelponline(.)blogspot(.)com
In name [Electro-Help]
Apr 16, 2012 | Sony FD Trinitron KV-32HV600 32" TV
Red LED Standby light blinks 5 times. TV will not turn on
This should be a scan failure indication. Usually its the flyback assembly, horizontal output transistor and a failure in the driver circuit, and or the power supply. It is possible the vertical amp could cause problems.
Your set will require shop service. The tech could troubleshoot for the fault and replace the defective parts. It may be of better value to replace the set.
Jerry G.
May 12, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KV-27FS210 won't turn on: 5 blinks
If you have little experience of TV repair then take off back cover of Sony Kv-27FS210 and find Screen Control Knob on flyback transformer, turn that knob slightly CW or CCW and turn on TV to get picture. I think you need to turn ON TV few times to get proper adjustement of screen volts.
Above said procedure is for non-tech person.
(Tech person will adjust screen volts (G2) as per procedure mentioned in service manual with proper tools.)
Jul 28, 2009 | Sony FD Trinitron WEGA KV-27FS210 27" TV
Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
The relay is in the power supply area. I am sure that the fault is not the relay.
It is very common that there are various components starting to go off spec from age. Most of the failures are in the scan amplifiers and power supply areas.
It is also possible that the CRT emission is too low from age. What happens is that it is on the minimum edge and this explains why the set may turn on some of the time.
When the main uPC in the set sees any potential fault conditions it will go in to a protection mode to prevent damage and to be safe. Your set is probably borderline to operate.
Considering the age of your set, I would be shopping for a new TV set.
Jerry G.
Jul 12, 2008 | Sony KV-36FS100 36" TV
Sony kv-32fs100 won't power up
Problem inside the tv, maybe leak parts inside you need repairman tech.
Apr 16, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KV 20S40 20" tv flutters, reduces in size and then shuts off
The set most probably has cracked solder joints in one of the deflection circuits, which is pretty common. The picture tube and major components are fine. A good tech can quickly resolder the main board and that should not cost too much. If your set came into my shop I would charge about $50 but ask around, the shops in your area will vary.
Jul 31, 2007 | Sony KV-20S40 20" TV
Sony trinitron kv-27fv17
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby, this means there is a component inside your TV set, in the main power supply or the sweep power supply that is not letting the TV set's power supply regulate properly. I'm sorry to say, there is no quick fix for this and is going to need to be diagnoised by a trained tech. Good Luck
Mar 19, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv stuck in standby
If you can not turn on TV set with the power button on the TV its not a standby problem as this would by pass the standby. Theres most likly, on a set of this age, top have a poiwer regulator problem and is going to need a trained tech to assist you in this repair.
Sep 10, 2006 | Sony KV-32S42 32" TV
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
