Question about Espresso RMI La Cimbali Espresso Machine
La Cimbali M29 Select - No power
Help, I purchased the above model 2nd hand & it simply does'nt work !
I am competent electrically & I have checked that power is getting to the main switch but there is absolutely no sign of it getting anywhere else.
No pump runs or water heating or any indications of activity.
I couldn't find any theremostatic reset which may require resetting although its mentioned on one of the panels.
Could it be that no water is getting to the heater ?
Could it be the theremostat ?
Any clues gratefully requested
  • 1 more comment
  • Anonymous Oct 14, 2008
    it's same. I turned on. but no heating. I guess it's power problem
  • Ernest R
    Ernest R May 11, 2010
    Is the machine wired for single phase or three phase, check on the side panel closest to the element there is a wiring schematic.
  • Ernest R
    Does the groupheads work but the machine not heat up.
    Novelist:
  • 137 Answers
Sometimes italians use brown colour for neutral, please check it. if it is so than the problem is solved
Posted on Mar 26, 2009
M29 wiring diagram
M29 is a semi automatic machine. Wiring is straight forward with the normal variance for single phase and 3 phase. Sorry i don't have a digitized diagram on hand. Maybe later. Dosing, is done with the control board which will need replacement if its not working.
youtube; ukeboy57
Mar 14, 2014 | Espresso RMI La Cimbali Espresso Machine
Hi all. In desperate need of help. I have a La Cimbali M29 Select. I am unable to get hot water from the hot water tap and when the machine dispenses a shot of coffee, I have to turn the machine of...
From your description it sound that the button strip need to be replaced. All the buttons of the coffees and also for hot water are all set in one unit the button strip. This like a membrane and is located under the buttons. This is frequent problem with m29 select since the connector of the button strip it is exposed under the cup warmer area and is very easy to absorb the humidity from steam escape inside the machine and when one short circuit it happens then since the whole strip is one unit it will mull faction as you described.
Jun 14, 2011 | Espresso RMI La Cimbali Espresso Machine
La Cimbali Espresso Machine: How do you calibrate the dosing for a Cimbali M29 ...
Press and hold any Group stop button until beeping, then all the button will copy what you press. Hit any stop button to leave program.
May 18, 2010 | Espresso RMI La Cimbali Espresso Machine
How do you calibrate the dosing of the La Cimbali M29 Select?
should be the same method unless the stop button needs replacement. The stop button is one of the most often used (abused) buttons and frequently needs replacement.
ukeboy57
Mar 26, 2010 | Espresso RMI La Cimbali Espresso Machine
WANT TO BUY A SECOND HAND M29 SELECTRON 2 GROUP- LA CIMBALI
The price for the m29 select new is about 5500 to 6000. So for one of 4-5 years you can give about 2500-3000. However I sugest to open the machine and check if their are rusting points or any leaking points which propably be white points from calcium color. Also ask if their were any water filter like everpure or and a water softener conected to water supply of machine during the operation of the machines.
If you see minor points as above and the water was treated before entering the machine then your machine can work for minimum another 10 years.
Water calcium (scale) is the biger enemy of the machine.
Good Luck
Mar 10, 2010 | Espresso RMI La Cimbali Espresso Machine
Cimbali M27
First, the switch is a 3 position(off-on-on). Second, I am assuming you have a 2 group machine, check the element wires use the schematic below.
Sep 29, 2009 | Espresso RMI La Cimbali Espresso Machine
La cimbali m28 selectron manual could anyone tell me where to buy or down load one
This is for you....I hope this M29 will do what you need...I called he Cimbali 1-800 number and this is all they had...I tried...been working on this one for about an hour...found one in Russian....Italian...Spanish....but when I translated them and tried to paste them they came in both languages and intermingled somehow....wierd....but here you go ....I hope this helps...good luck and thanks for rating my effort....The Fang
P.S. any probs...call 1-800-724-6225 and speak to Trish. Thats 1-800-Cimbali. Take Care
May 19, 2009 | Espresso RMI La Cimbali Espresso Machine
Cimbali M29 Select
Remove the 3 screws on the side of the bell they might be bolts or allen wrench screws. That will give you easier access to the screen and screw(make sure you have extra screen and screws).
Aug 18, 2008 | Espresso RMI La Cimbali Espresso Machine
Used parts for la cambali M29 select
Sounds like the relay for the pump is gone. Replace relay.
Oct 28, 2007 | Espresso RMI La Cimbali Espresso Machine
Espresso RMI La Cimbali Espresso Machine Logo
832 people viewed this question
Top Espresso RMI Coffee Makers & Espresso Machines Experts
Mohamed Ismail
Mohamed Ismail
John
Mark Cheong
Mark Cheong
Are you an Espresso RMI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
