Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
Middle Picture has 2 inch section in total fuzz
I have a LC-37G4U. When I turned it on this AM a section of the screen-almost middle is blurred. The section is approximately 2 inches wide and goes from top to bottom. I've trouble shooted as best I can. Has anyone seen this issue. Any help is greatly appreciated! Thanks-Jim
  • JFWRC Mar 19, 2008
    Thanks ginko,
    When you say inside your TV, are you saying the actual cable connections or something within the TV box itself? This TV is mounted on a wall.
    When you say ribbon cable, what does it look like?
    I'm headed to work in a flash. I may not get back to this until this evening.
    Jim
  • Sharp Master
  • 19,396 Answers
May be an issue with LCD ribbon cable
Posted on Mar 19, 2008
  • 2 more comments
  • Ginko
    Ginko Mar 19, 2008
    Check the lcd cable and cable connectors inside your tv, if ribbon cable is out of place you have similar problems
  • Ginko
    Ginko Mar 19, 2008
    I had the following post from a sharp rep. regarding your model on sharp avs forum. I do not know if it can be related to your problem:
    A capacitor was miss-marked from the factory. The stamp on the
    component said 100uf and it was actually 10uf. Caused all kinds of
    power issues. They come in 5,000 unit rolls for the auto insertion
    machines.
    If you own a Sharp Aquos *D4/6U Model and have been having any of the following problems:
    1. Unit turning itself on/off at random times
    2.
    Unit locking up and fails to respond to remote or set-top butons, unit
    must be unpluged and plug in again to get set to respond.
    Please
    contact Sharp at 1-800-BE-SHARP (237-4277) and report the problem,
    Sharp will give you a Case # that you will need if any service is to be
    needed or done.
    Sharp has released a firmware fix/upgrade as
    of 2/27/05 to try and correct these issues. I have already received
    this firmware upgrade as of 2/28/06, from my local Official Sharp
    Repair Center but have yet had time to really monitor my set for any
    improvement. Below is a link to the AVSfourms where you can post on any
    of these issues you may be having with your Unit. The thread is
    monitored by a Sharp Rep (Mike53 The Sharp Guy) and he will be glad to
    help anyone as much as he can.
    http://www.avsforum.com/avs-vb/showthrea...
    Check first the lcd display connectors as well, if they are ok you may need tou upgrade tv firmware.
    regards
  • Ginko
    Ginko Mar 19, 2008
    You need to disassemble your TV (not the box) and the cable is a flat ribbon connected on one side to the lcd display. You need some electronic DIY skills, if you are not experienced in DIY electronics, I suggest contacting first Sharp, to check if you are affected from bug descripted above, and eventually ask them how to do a firmware upgrade, that should not be too difficult.
    Do also a hard-reset using a paper clip on the bottom hole next to the three coax inputs.
    If you have to work inside your TV ensure that you have proper skills and experience, it is a delicate, fragile (and expensive) device, consider calling in a repairman if you do not feel safe working inside your tv.
  • Ginko
    Ginko Mar 19, 2008
    Last thing sharp customer number above is for USA. If you leave in a different region you can find the right contact number from this link here.
    regards.
SOURCE:
Which part of my sharp 42 inch hdtv would most likely cause my screen to have a 2 inch line right down the middle
If the line is black the display panel may be the issue. This is the entire screen unit and fatal from a cost point of view.
Apr 24, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Picture has a sag in the middle, blurring the sides of the screen.
okay that sounds like a problem in the horizontal circuit and vertical circuit.the module of those section wants to be replaced.only a tech can do the repair.look for a tech to repair your tv
Sep 25, 2011 | Samsung HCN653W 65" Rear Projection...
My Sony Bravia tv has a problem with the screen getting dark on the right side. Sometimes the screen is normal, and then sometimes it goes dark and/or red. There is a small square (2 inches) that has a...
This tv have a problems with a board that call T-CON decodering board.This T-CON decodering board sit at the bottom in the middle of the LCD screen panel.This T-CON decodering board,decodering the tv incomming broadcasting tv signal before it go into the tv LCD screen panel to produce pictures.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
Apr 23, 2011 | Televison & Video
My panasonic PT-51SX60A has a 2 inch picture loss
tv looks fine then I get just a line in middle and nothing else
Jul 24, 2010 | Panasonic PT-51SX60 51" Rear Projection...
Screen went black with a vertical rainbow line down the middle
Failue of the vertical section, could be the drive, the power to the section or even some discrete componets. Unless you are familiar with electronics , get some help to ceck out on these circuits, could not be major but to get themain culprit will require good probing.
Jun 29, 2010 | Panasonic PT-56TW53 56" Rear Projection...
LCD screen is extremely blurred
It is probably not the LCD itself, but an element that is protecting the LCD is bent out of shape.
Jan 16, 2009 | Vivitar ViviCam 5386 Digital Camera
Out of sync message
When you first turn on the unit very quickly push the imput button to switch sources.It is stuck on the computer imput.
Feb 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
2-inch picture stripe in middle of screen.
deight, your set is going into total vertical collapse, either the vertical IC is failing or some support component to the vertical circuit is failing, should not be an expensive repair, hope this helps, BMW Rider
Dec 12, 2007 | Sylvania 6419TA 19" TV
Black screen, high pitched squeal
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
Aug 29, 2007 | Philips Magnavox 20MT4405 20" TV
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
61 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
