Samsung LCD television
My LN_S4041D was repaired yesterday by replacing BM94-00963E Main board and BN44-00134A IP board. I am now able to turn the tv on and see shows. My DVD player was hooked up to the "Component In section" as it was before my problem . I checked all connections and they are proper but I keep getting the message that there isn't any signal for the DVD Player. Any help would be appreciated. Thank you in advance for any help you give me.
  • 4,234 Answers
There are a number of cbles that must be attached correctly inside the set. Since this worked prior to the repair, I would call the repair shop and indicate that the repair is incomplete. no additional charge should be seen by you.
Keep us posted.
Dan
Posted on Mar 19, 2008
My samsung lcd tv is lock on tv channels only
Check function buttons. One may be stuck. Disconnect the function switches from the switch board. If you can change inputs with the remote then replace switch board or switches. if not then replace the main board.
Mar 25, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung 40in tv
either the control panel board or the main board has a problem.probably channel change botton on control panel is stuck or shorted.
Dec 28, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung lcd 40" Ln-s4041D HDTV won't turn on
Replace any swolen capacitors on power board would be first step. Check fuse on power board. Is the standby led lit.
Aug 31, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
My samsung tv turns on and off repeatedly at
Mine was doing that then it quit even turning on so I replaced the 4 Capacitors today on the power supply board that had bulged up on the top 3 had split open they where on the top right corner of the board where the ribbon jumps from the power board to the main board with ones from Jameco Part Number 606521 they worked perfect but make sure you put them in with the correct polarity easy to do just keep an eye on it. Very simple repair and took me about 30 min to take itapart solder on the new ones and put it back together all for under $10.
Jun 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Tv wont turn on
Mine was doing that then it quit even turning on too so I replaced the 4 Capacitors today on the power supply board that had bulged up on the top 3 had split open they where on the top right corner of the board where the ribbon jumps from the power board to the main board with ones from Jameco Part Number 606521 they worked perfect but make sure you put them in with the correct polarity easy to do just keep an eye on it. Very simple repair and took me about 30 min to take itapart solder on the new ones and put it back together all for under $10.
Jun 21, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
My samsung 40" lcd LN-S4041D TELEVISION WONT TURN ON JUST CLICKN AND TURNS ITSELF ON AND OFF AUTOMATICALLY. I GET NO PICTURE OR SOUND.
This tv has issues with 4 capacitors. These caps can be replaced for about $10. They are located at the top right corner of the power supply. They will read 10v,1000uF. I had the same problem, then I replaced them wit 16v,1000uF capacitors. And presto tv!
Jun 09, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Automatically turns off
I have the same problem and had a samsung technician come to the house. It was the Power Board and the main board. He gave me an estimate to fix and it was $529. I'm trashing the TV. Samsung sucks.
May 17, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Television won't turn on at all
if you can look on the boards at capacitors ( do a Google of "blown capacitors" ) and then you will be able to see if there are any blown one's on the boards inside, if so some soldering will be needed to replacce the blown one if you can then the issue should go away. if you can not do this a service center can help complete the repair.
May 27, 2008 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
202 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
