Screen problem with HP DV 9000
The screen on my HP DV9000 goes blank after about 30 seconds from boot up. The screen flashes and goes blank. If you look closely, you can see the screen faintly in the background. When i run the computer on battery power and connect to an external monitor, it works fine. As soon as i plug the power supply in, the external monitor pops up a messege saying no signal found. What do you think?
  • paulamelhem Mar 19, 2008
    i have tried a different power supply and this hasnt fixed the problem. ive been told i have to change the screen and as you can imagine, this is costly. Do you think i can get around it without having to change the screen?
    Problem Solver:
  • 18 Answers
I think Your computer C.P.U. power supply unit is not working properly. because these type of problem occur when Power Supply Unit is not working properly.........
So Don't afraid at all just change your c.p.u. power supply unit with new one (it is not costly at all).
Posted on Mar 19, 2008
Hp dv9800 service manual
1) http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Scroll down to the subheading - HP Pavilion dm1. (dm1 in blue)
Go down to the second line in this 'paragraph', and scroll across.
Click on the blue dv9000.
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (9000) it may take up to 30 seconds, before the first page comes up.
2) http://www.insidemylaptop.com/remove-lcd-screen-inverter-board-hp-pavilion-dv9000-laptop/
3) http://www.cesgeekbook.com/2010/01/dv9000-disassembly-tear-down-part-1.html
4) http://www.youtube.com/watch?v=bnkQNmKauEc
Not advertising, using for reference material.
Regards,
joecoolvette
Aug 22, 2012 | HP dv9819wm Notebook, 17.0 WXGA+...
Hp dv9000 will not turn on the blue lights come on and goes off right away. I bought a new cord and adapter and it does the same thing. I did try taking the battery out and holding power button for 30 sec...
vast posts here on black screens of deathh
the screen is 100% black and never once shows text or that HP logo. 100% dead black, then that is the screen back lamps dead
as most long ago did, go dead , just not yours.
called the CCFL lamps dead.
ok the battery out test1
the other check is the fan is the fan blowing, it must or the CPU overheats fast and (it shuts itself off, like magic (intel inside)
see slide show here for Laptop link packup causes.overheated
http://www.pcdied.com/overheated.html
my guess is it is there, below... as all do every one at 20k hours.
see flash light test. there. on test one, do that.?
see test #1 (battery out, ac pack connected and working)
http://pcdied.com/black-screen.html#Basic-basics-101
if the flash sight trick passes, (see data) ask how to fix that
or read the service manual at HP.
see the list of HP , with CCFL here. dv9000 is it.
http://pcdied.com/monitors.html
if yes, ccfl dead
see here
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.Xdv-9000+ccfl.TRS0&_nkw=dv-9000+ccfl&_sacat=0
1% fail this way for inverter bad, 1 in 100.
see same page above for inverters sold the lamps run of it and it makes 500 to 1000vdc to do that,, HV inverter.
Oct 30, 2017 | HP Pavilion dv9000z Notebook
I have HP DV9000 laptop when i switch on it powers but the display is like in safe mood i cant see anything
i am mr john uche aaron
in Nigeria ,
my hp pavilion dv 9000
cannot bootup
but display only light on the quick bar
and blank screen
what is the solution
Dec 12, 2010 | HP Pavilion dv9000 Motherboard
Dv 9000 what lcd fits it
1) 17 inch WXGA (1440 X 900 Pixels)
Here's an example;
http://www.screentekinc.com/HP_Pavilion_DV9000_Series_DV9009NR--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Another one;
http://www.pcpartsltd.com/hp-pavilion-dv9000-screen-170inch-lcd-screen-p-1791.html?zenid=ihi8on44ad0gdnuab8ipt2ujb5
MAIN THING > Match the Part Number on the back of the LCD screen to the one you are going to purchase.
It isn't just whether the screen is the correct size, and dimensions. Whether it is a glossy finish, or matte.
It is that the cabling on the back of the LCD screen is correct, and the LCD screen matches the Inverter that is installed.
2) Just to add;
Nov 04, 2010 | HP Computers & Internet
Hello i have an hp Pavilion dv9000 laptop. I use
Have you tried removing the memory 1 stick at a time?
Jul 06, 2010 | HP Pavilion dv9000z Notebook
Blank Screen - hard drives work and keyboard lights up
Try holding F11 while booting, sometimes this triggers the recovery partition.
Sep 21, 2009 | Compaq Laptop Keyboard for HP Pavilion...
BLANK SCREEN HP DV 9000
Run system restore to factory default.
Start the system and hold down the f11 key till you hear a beep. Then follow the onscreen instructions.
Good luck.
Aug 23, 2009 | HP Pavilion dv9000z Notebook
Everyb time I turn on my hp dv 9000 loptop the blue keys turn on but the monitor does not?
I have seen alot of dv9000 inverter or screen problems. Nice laptop but it does have its problems. I would check the inverter first, they are relatively inexepensive.
Aug 02, 2009 | Computers & Internet
Hp dv9000 will not start up. blue lights are go
you get a black screen right, nothing at all then no bios, no logo, nothing at all?
Do you get any beep codes and if so in what order?
did you try different ram?
First try to plug your laptop to an external monitor. If it works, you screen is bad, if it doesn't you probably need a new motherboard.
Dec 23, 2008 | HP Pavilion dv9000z Notebook
HP dv9000
 Hello jarkk, I believe your problem is with your backlight inverter. the hard drive should be installed for this process of checking it on an external monitor. with the hard drive removed it will not boot to the operating system. with the drive in, use the external monitor. if the monitor works when plugged into the external monitor plug, this will eliminate a bad video card. if the screen is still black on the laptop screen, replace your backlight inverter. the last case cenario is to make sure your backlights are not burnt out.
Sep 11, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
255 people viewed this question
Alun Cox
David Payne
David Payne
