Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Dishlex Global 300 - stopping mid cycle
By fredmcmurray on Mar 19, 2008
We have recently moved into a house with a Dishlex Global 300 (without an instruction manual). When we use the dishwasher and push start it only runs for about one minute and then it stops and the 'fast' button flashes. Doesn't seem to matter what we try - we can never progress any further.
Same Problem
May 25, 2009
-   Almost the same prob. Only our "eco" button is what is flashing. Noticed the instruction manual says to call service centre.... s'pose it depends how much money you want to spend on it!!!!-   Guest
Dec 26, 2008
-   same deal. If you hold both start and program buttons in until it goes into service mode, and then hold down program until all of the wash selection lights have lit up in turn it goes away for a while. Also clean the filters and this sometimes helps but the problem always comes back. -   Guest
Aug 04, 2008
-   I have the same problem with my Global 300, the machine starts ok, fills then stops with the "fast" light flashing. I had a repairman come in who said the tap wasn't fully turned on which he did, he left and next day it was the same problem with the dishwasher. -   Guest
Jun 29, 2008
-   I was getting the same problem. It would stop after a short time and the the "fast" would flash.
Checked that the inlet filter was not blocked and that the tap was turned fully on.
Disconnected the power lead, inlet hose and drain hose and removed the dishwasher. Removed the bottom metal cover and noticed a clear plastic box that was full of sludge. Un clipped it and the flexible hose attached to it. Cleaned out the sludge and reassembled. Dishwasher is now working O.K. -   Guest
Jun 12, 2008
-   exaca few minutes stops and the fast lights uptly the same happend goes for -   Guest
Best Solution
posted on Apr 26, 2008
Helpful)
AnthonyM
Rank: Apprentice
Rating: 85%, 10 votes
I was getting the same problem, I turned my tap on faster and the problem resolved. I assume it wasn't getting enough water.
If you need the manual I found it online at:
http://www.electrolux.com.au/node132.aspx?cat=Dishwashers&subcat=Semi+Integrated%2c+Electronic+%26+Rotary+Controls&id=224
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jan 14, 2009
Helpful)
wazza c
Rank: Apprentice
Rating: 85%, 1 votes
This is just a suggestion....  so please try and please post any corrections.
Anthony M is on the right track.  Refer to his entry and download the manuals. Tks Anthony.  When the Dishlex 300 starts for the first time, there is a service mode set up. The service mode allows you to set a 'fill-time' for the water to reach the right level, dependent on the water pressure and flow... which is described in the manual.  So resetting the Dishlex is the first step. Then set the water level.  If the water is too low, it will not wash, it will flash. When the water is too high, it will leak out of the rubber seal.
I hope this helps you all. Waz
Was this helpful?
Yes
No
Solution #3
posted on Apr 04, 2008
Helpful)
adambr
Rank: Apprentice
Rating: 85%, 3 votes
Any luck with what the problem was as i am having the same issue
Was this helpful?
Yes
No
Solution #4
posted on Jul 28, 2009
Very Helpful)
gabriel144
Rank: Apprentice
Rating: 100%, 4 votes
This problem is common to both the 300 & 310 models. The flashing Fast light indicates a blockage in the water supply. I fixed this by:
- disconnecting the dishwasher
- checking for blockages in the input hose filter (there were none)
- removing the bottom of the dishwasher (two screws at the front)
- looking for the translucent plastic bucket thing attached to the side of the main assembly
- unclipping it from the main assembly and removing the white hose attached to it
- flushing 5 years worth of evil gunk down the sink (you need a small brush or piece of wire to get it out
Gabriel
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #5
posted on Jun 10, 2009
Somewhat Helpful)
haywooddave
Rank: Apprentice
Rating: 75%, 1 votes
The fast light will flash if the water pressure is too low or the water inlet is restricted.
If you have the basic Global 300 without the digital readout the factory setting for fill time is:
75 seconds pre wash.
80 seconds wash.
90 seconds rinse.
I dont think this can be changed. We had the same issue, so I will run through what I did and see if it fixes yours or others with the flashing fast wash light.
(1) While filling (Pre wash) open the door and poor in about 2ltrs of water, let it continue to fill.
If it fills and goes into the pre wash stage the water level is too low due to lack of pressure or a blockage.
(2) Switch off machine and disconnect power cord. Pull machine out enough to get to water hose.
Turn off tap if fitted or water supply, unscrew hose and check filter in hose for any dirt ect. If possible connect a garden hose to pipe or tap and turn water on to make sure there is good water flow.
(sometimes when pipes are repaired a small amount of dirt or rocks can get into pipes and they have to come out somewhere)
If you have done this and the filter is clear and you have good water flow reconnect hose to machine.
Standing at the front of the machine tip it on its left hand side about 45 degrees and lean it on a cupboard or something for around 15 minutes. This will help shift the float and/or muck that might be in the machines sump.
(3) After 15 minutes stand machine back up push back into place plug cord back in and switch on.
Selcect wash program and see how it goes... I have done this twice in 6 months and has fixed it both times..
Cheers
Mark
Was this helpful?
Yes
No
Solution #6
posted on Nov 03, 2009
Not Rated)
sealrock
Rank: Apprentice
Rating: 0%, 0 votes
Cleaning the sludge sump in the bottom worked first time, thanks
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
experiencing water in the dishwasher after a wash. This did not happen before. How do i fix this?
Answer
no hot water / water not heating ?
Answer
started to emit loud whistling or beeping noise after programme finished. Now although controls... (More)
9 Other Users Have The Same Problem - Continued
Comment by Guest, posted on May 30, 2008
exactly the same thing...moved to new house, with no manual used dishwasher it would run then flash to fast.  After turning dishwasher off and then on again, I cleared all programs and pressed start for fast cycle, dishwasher worked.
Comment by Guest, posted on May 11, 2008
Same problem - flashing fast light etc... I have been told to replace the electronic valve (the thing the hose goes into).
Also, my tap doesn't turn on any further :(
Comment by Guest, posted on Apr 06, 2008
I have the same problem with my Global Dishlex 300. I have replaced the main cct board and the pump as they were causing other issues and now I have this flashing fast light at the end of the first fill sequence. The water level appears fine and it drains OK if I re-start the cycle. I have double checked all wiring to the main board and checked all visible wiring and plumbing; nothing appears loose or disconnected.
Comment by nicolledo, posted on Mar 29, 2008
I'm having exactly the same issue. Doesn't matter which preset programm you choose, it stops after a minute or so then the "fast" menu flashes.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
