Question about Nokia 3230
Memory card locked
I cannot have access to the memory card of my 3230. I am being asked for memory access code. I don't remember creating any code. Please help, I terribly want to use items in the memory card
    President:
  • 1,017 Answers
The Nokia default is 12345 if you didn't change it, but if you did change it and you've forgotten it.
You can recover the password. The best way is to download a file manager to your phone. I use 'Best Fileman' from http://www.smartphoneware.com/ It's for series 60, and 40. The trial version should be enough, it's only £5.60 anyway.
In the file manager you'll find under- C:\System\mmcstore -the file you're looking for, you have to rename the file- mmcstore.txt -then send it to another mobile (best way) or your PC via Bluetooth open it on the other phone and your password will be revealed.
Rename the file- mmcstore.txt -to just- mmcstore -there might be another file named- mmcstore.txt -to view your password rename one or the other- mmcstore1.txt -one is for your phone PIN number the other your MMC card.
Clear enough?
Posted on Mar 20, 2008
Formating code for phone memory
try this procedure.. password less procedure
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Thank you for using FixYa!
Do have a nice day and please remember to rate this solution.
Best regards,
Jul 09, 2009 | Nokia 3230
I have nokia 5610 xpress music , today i did restore factory settings of handset and fount out that my mmc card has been locked automatically, i did try the default 12345 as password but it did not work......
If you forget your memory card password, there is nothing either you or a service point can do. It is not possible to read the password from the memory card or from the device. Passwords cannot be disabled.
When you lock your memory card with a password, your device will remember it. Therefore, the device does not have to ask for the password every time you access the memory card. However, when you insert your memory card to another Nokia device, you are asked to re-enter the password. The password is asked because the memory card remembers the password protection settings, including the password.
Note: After you reflash your Nokia device and re-insert the memory card, you are asked to re-enter the password, as it has been erased from the device during the flashing process. You have to re-enter the password to get access to the memory card, and after that the device will remember the password again for future use.
If you have forgotten the password but you still want to try to use the memory card, try formatting it. If the formatting process is successful, the memory card is usable but all data on the memory card is erased.
To avoid unnecessary risks, write down your password somewhere and backup your memory card data regularly.
Jun 20, 2009 | Nokia Cell Phones
My phon software (nokia 3230) is down it shows me that my phone memori is to low but I try to delet massages and other things from phon memori but nothing hapends .Whwt can I do?
hi tharaj here , when i am here no fear , its very easy to solve ok , the thing is ur 3230 got 5 to 6 MB phone memory so u should use memory card memory instead of phone memory , whenever you recieve data from b tooth save that in to memory card or els transfer from phone to memery card by using file manager ,still if if u face problem just press *#7780# and it ask code press12345 then think ur problem has solved , ok take care bye
Mar 07, 2009 | Nokia 3230
How can format the phone memmory of NOKIA 3230
Download user guide from:
http://nds1.nokia.com/phones/files/guides/Nokia_3230_UG_en.pdf
Page 163
Formatting the memory card
When a memory card is formatted, all data on the card are permanently lost.
Some memory cards are supplied pre-formatted and others require formatting.
Consult your retailer to find out if you must format the memory card before you
can use it.
• Select Options→ Format mem. card.
Select Yes to confirm. When formatting is complete, enter a name for the
memory card (max. 11 letters or numbers).
Backing up and restoring information
To back up information from your phone’s memory to the memory card, select
Options→ Backup phone mem.
To restore information from the memory card to the phone’s memory, select
Options→ Restore from card.
You can only back up the phone memory and restore it to the same phone.
Locking the memory card
To set a password to lock your memory card to help prevent unauthorised use,
select Options→ Set password.
You are asked to enter and confirm your password. The password can be up to
eight characters long.
Your rating would be most appreciated.
Feb 20, 2009 | Nokia 3230
Corrupted memory card
3230 memory card corrupted
Nov 24, 2008 | Nokia 3230 Cellular Phone
How will i have a code on my n70?
well, you can choose to use a 'PIN code' or a 'Lock code' or 'Memory card lock'
1. PIN code actually locks up your SIM card, so anywhere you put your SIM card, the message on your SIM card will not be read by anybody without knowing your password. It'll ask you password each time you switch on your phone, but after switched on, it'll not be locked anymore, so anyone can read your phone after switched on.
2.while Lock code, locks your mobile phone like 'keypad lock', the different is, instead of just pressing , left softkey and * button, you need to put password on it (it lock after certain idle time - or you can choose to lock it anytime you want by pressing the on-off switch one time (don;t press too long) and choose the belowest which said lock phone ). this type of lock is commonly used.
3.Memory card lock, locks any application which access your memory card, such as images, text, songs, data that is stored on your memory card. but this type of lock, often bring troubles when the memory card get corrupted. so I suggest number 2 type of lock (lock code)
WARNING!!! all password should be remembered, as if you forgot those password, no body can help you unless technician.. see those articles which people post when they forget their password, so you know the risk and the consequences. But they're actually safe as long as you remember ^^
Good luck, all the best!!
Nov 16, 2008 | Nokia N70 Cellular Phone
I want break my memory card password
there is no way to break if the password is forgotten for the memory card, but u can attach the card to the memory card reader to the computer and format the card and u can use it
Nov 08, 2008 | Nokia 3230
After formatting my 3230
I asumme you have a Nokia Phone. Maybe changing: Configs > Phone > Security block
Or even try the generic code "1234" (without cuotes) or "12345"
Regards,
Oct 13, 2008 | Nokia 3230
Please Unlock my MicroSD password.
I forgot my MicroSd password.Please help me to remove it.I am unable to access my MicroSD card.I have Nokia 6300
Mar 18, 2008 | Nokia 3230 Cellular Phone
Memory card locked
The default security code for Nokia is 12345.
You can recover the password. Although if you reset your phone you probably won't be able to recover the old security code. Anyway this is how it's done.
The best way is to download a file manager to your phone. I use Best Fileman for my N70, from http://www.smartphoneware.com/ It's for series 60and 40. The trial version should be enough, it's only £5.60 anyway.
In the file manager (when installed on your phone) you'll find under- C:\System\mmcstore -the file you're looking for, you have to rename the file- mmcstore.txt -then send it to another mobile (best way) or your PC via bluetooth or USB, open it on the other phone and your password will be revealed.
Rename that file- mmcstore.txt -to just- mmcstore -there might be another file named- mmcstore.txt -to view your password rename one or the other- mmcstore1.txt -one is for your phone PIN number the other your MMC card.
Clear enough?
Nokia 3230 Logo
83 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
