Dots on print out
I have a Samsung ML 1520 laser printer, it has just started printing out sheets with a row of dots going down the page (from top to bottom). Can anyone suggest what might be causing this and how I can fix the problem, thank you.
  • textmum Mar 23, 2008
    Hi, installed the latest driver, and I am still getting the dots. Thank you for your help.
  • 40 Answers
it seems that there is some thing wrong with the print cartridge, check it after replacing the tonner cart. with a tested one.
coz i think there is problem with the drum of cart.
mail me ur respose @ [email protected]
Posted on Mar 27, 2008
    Scholar:
  • 45 Answers
Hi textmum,
Usually anomalies of this kind on the print output indicates that the printer is overdue for a maintenance cycle. This is due to the usual operating wear and tear the printer experiences during it's life cycle.
Seeing as how this could be an expensive operation, I suggest we first eliminate problem with the printer driver as the cause of the anomalous print output. To do this I need you to reinstall the printer on your PC using the latest drivers:
  1. Download the latest driver for your printer at
    http://www.samsung.com/za/support/download/supportDown.do?model_nm=ML-1520&mType=DR&vType=L&disp_nm=ML-1520
    (be sure to select the driver which corresponds to the operating system you are running on your PC)
  2. Delete the printer from your PC
  3. Install the printer using the newly downloaded driver
If reinstalling the printer using the latest print driver doesn't result in a solution to the print output problem, we can deduce that the problem is caused by a hardware component.
To solve the hardware related problem you will need to either perform the maintenance cycle yourself or take the printer to a computer repair shop so a IT technician can do it for you. This process involves buying a maintenance kit (which contain replacement components for the printer), and replacing the components according to the maintenance kit manual.
Hope you find this information helpful in solving your printer related problem
Posted on Mar 22, 2008
SOURCE:
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Jan 24, 2014 | Konica Minolta magicolor 2430 DL Laser...
Small dots on printed page
You most likely have to clean your toner drum, or clean your transfer sheet.
if you use a non Samsung cartridge that was "compatible" there is a chance that the cartridge was refurbished, and some refurbished toner cartridges to do leak.
your best bet is to clean what ever parts you can get your hands on, the manual should explain where those parts are.
http://www.samsung.com/levant/consumer/printers-multifunction/printers/mono-laser/ML-1630/XSG-support
May 26, 2012 | Samsung ML-1630 Laser Printer
There are 3 small dots that print across each page when I print. How do I get rid of those?
what type of printer, laser or inkjet. are the dots spaced down the page or across?
I suspect you have a laser and the dots are down the page in which case it is most likely the fuser unit or the cartridge.
To verify which, you can send a print to the printer and open the printer half way through. If the dots are present before the paper goes through the fuser (the hot bit that fixes the toner to the page) then its the catridge, otherwise it will be the fuser unit. you will need need to replace which ever part is the cause
Sep 02, 2011 | Brother Office Equipment & Supplies
Hello! My Samsung ML 2010 Laser Print has started to print pages with streaks of ink across them. This makes the pages more difficult to read, and certainly cannot be used for formal letters. It also...
there must be waste toner in your toner cartridge
the waste toner box is fitted above the drum in toner cartridge with 2 no screw open it and empty then try to print
Jan 26, 2011 | Samsung ML 2010 Laser Printer
I have an Samsung ML-2851ND printer and it is printing grey patches vertically down the pages behind the text. What is causing this and how can it be resolved?
Dots, Lines and smudges on the printouts are due to dirty/ deteriorating cartridge and cleaning the green drum of the cartridge may help temporarily. Open the front cover and take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines.
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside, which sometimes results in dots.
Try to rotate the drum to clean its whole face. You may have to repeat cleaning more than once.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Dont forget to appreciate the solution and to convey your feedback
CreativeTECH
Jan 24, 2011 | Samsung ML-2851ND Laser Printer
Printe have some line not printing corect
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Jan 19, 2011 | Samsung ML 1710 Laser Printer
Price of cartridge of samsung ML-1640 mono laser printer
Rs. 2800/- original carteige
Rs. 1200/- compitable cartridge
Nov 09, 2009 | Samsung Laser Multifunction Printer Toner...
Hp2600n printing black dots centre page
Could be a dirty fuser, try a laser printer cleaning sheet.
This is more of a problem if you use (some types of) remanufactured toner cartridges.
Feb 04, 2009 | HP Color LaserJet 2600n Printer
Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
Oct 17, 2008 | Samsung ML 1610 Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Computers & Internet Logo
67 people viewed this question
Ekse
Alun Cox
