Question about Microwave Ovens
Removing microwave surround
This has stopped working and as it is built-in I can't see how to remove the stainless steel surround to get the microwave out to replace it. How do we go about removing the surround so we can remove the microwave?
  • 1 more comment
  • doctone50 Mar 26, 2008
    microwave is a Neff model number H5632NOGB/01
    Thank you doctone50
  • doctone50 Mar 28, 2008
    This doesn't actually tell me how to remove the trim/surround around the microwave. It is built into a cabinet. Thanks for trying.
  • William Miller
    William Miller May 11, 2010
    What is your brand and model number?
  • Microwave Ovens Master
  • 9,098 Answers
Ahh, that's one of those British brands I can't get any information about.
If you have the installation instructions, they would tell you how to install it, and it's as simple as reversing the procedure.
BUT maybe it's not too different from US models in the sense that many of its components can be accessed without pulling it from the wall, assuming it's the over the range type.
I would first refer you here:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
In most cases, you unplug the oven, then remove the vent grille across the top, then you'll see a screw holding the top of the control panel frame in place.
Once that screw is out, you probably lift up and either swing forward or twist to loosen the control panel.
You should be able to access the fuse, etc. at this point.
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If it's built into a cabinet, then you would have to remove the metal frame covering the area in which the microwave rests.
Be safe.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 26, 2008
  • William Miller
    William Miller Mar 28, 2008
    Usually there are visible screws in the trim pieces. If not, they may be held in place with hidden clips. Sorry if I missed the mark.
How do I remove the front control panel on a ge profile je2160sf01?
On most over the range ovens, the screws for the control panel are on the top of the control panel. You usually have to remove the air deflector above it to acccess the screws.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Dec 24, 2016 | GE Microwave Ovens
Fan will not stop
fan is normally controlled by a microswitch which can be accessed by removing top cover, you may have to replace the microswitch but this should only be carried out by a licenced electrician as high voltage is involved
Apr 21, 2014 | GOLD STAR LLC MV1611ST 1.6 cu. ft. 1000...
Bosch hmt 845k microwave oven
If for some reason you don't still have the installation instructions, their support site should allow you to either download or order a set.
If you can't find their site, try the dealer from whom you purchased the oven.
Jun 09, 2013 | Microwave Ovens
I want to change the handle to stainless steel to match my new Whirlpool Black Ice range that has stainless steel handles so everything will match, please HELP!!!
A suggestion---call or contact LG to see if what you want is even available---only other (a little crazy) is consider if metal having the handle removed and chromed.
Nov 08, 2012 | LG LMV1630ST Microwave Oven
I seasoned my new stainless steel skillet in the oven now I have built up oil stuck to the sides inside the skillet. How can I remove this without damaging the stainless steel finish? HELP!
You only need to season a cast iron skillet, not stainless steel. Soak it in hot soapy water and use something like a mister clean pad to clean it.
Dec 07, 2010 | Microwave Ovens
Have a 12 year old kitchenaid Superba stainless steel built in microwave. I suddenly stopped and "door' lights up on display. Door is shut hear clicking by left side may be a latch issue. How do you fix?
Hi - it is 12 yrs old so parts may not be available for it.
If its a door problem, then its really a door latch switch or switches that has failed. Time involved in removing case, then switches then checking them all then finding replacements at ?? cost is uneconomic.
Please consider getting a new machine - probably use less power, have more features and work a darn sight better than this old one.
Jun 08, 2010 | Microwave Ovens
GE PEB1590 microwave oven. Interior light burned
Remove the screws from around the rear of the oven and slide the cabnet off to the rear. You should be able to access the bulb from here.
WARNING: any time you work on a microwave you have to be careful of the capacitor. Unpluge the microwave and discharge the capacitor with a large screwdriver with a plastic handle.
Be careful.
Dec 31, 2009 | General Electric PEB1590SMSS Stainless...
How to clean GE Advantium???
Get a stainless steel "brillo pad" at the grocery store.
When you get home ... put a microwave safe container with water inside it ... in the oven. do not heat for more than 2 minutes!!!!! The resultant steam will soften the gunk. Use the stainless steel cleaner pad gently to remove the goop.
I hope this helps you
a
Sep 23, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
558 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
