Question about Sony 32 in. LCD TV
Fluctuation and Grounding issues
My problem is voltage fluctuations and grounding problems. What Do I do?
    Brigadier General:
  • 6,966 Answers
Based on your post/description, I would suggest the use of a voltage regulator identical to those used by desktop computer systems. They normally are rated at 500 watts and should be sufficient for your Sony 32 in. LCD which would consuming something like ~130 watts. Additionally, try to get those models that have polarized AC plugs to match your house wiring and that of the Sony. This would also take care of the grounding problems.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 19, 2008
Need a powertrain control diagnostic repair service manual pdf
No year make or model? Good luck on that PDF. I tried for years to find them. You may want to check the cam sensor. Cam and crank have the same power wires. And if you only have .5 volts, this is a problem. Voltage for these are 5, 8, or 12, again depending on year.
Sep 05, 2015 | Cars & Trucks
My voltage stabilizer that I have been using for about 6years now with my refrigerator suddenly started going off and on by itself thereby affecting the effectiveness of my fridge.
Voltage stabilizer that you are using is older. Voltage stabilizer that you are using is older. This problem is occurs cause of power fluctuation. Check the connections, Looking at the regulator from the face, the three terminals are V+ in, Ground (which is V- in and out) and the last one is V+ out. If it's backwards, it can indeed get hot. http://www.batterybhai.com/category/voltage-stabilizers/5
Jan 05, 2015 | Refrigerators
Find smps problem solution
What kind of hardware do you have in the computer and what size power supply. If you are at the bare minimum Wattage you can have strange start up issues.
Jun 22, 2013 | Computers & Internet
Suzuki 2007 gsxr 750 blowing head lights and the two little "park lights" stay on after switching out battery this year. I had baught the voltage regulator that the daler said would fix the issue but
lights fail from a fluctuation power supply
when a ground wire is loose or the bulbs are loose in the holders
the resultant problem is arcing which burns out bulbs as the current increases as the resistance drops the voltage
Jun 24, 2017 | 2007 Suzuki GSX-R 750
Haier 21 inch CRT TV picture getting distorted due to voltage fluctuation which component has to replace?
The picture tube is affected by the focus voltage from the flyback, if the voltage is fluctuating, it can be caused by the picture tube or the flyback transformer, the most likely is the high voltage transformer.
Mar 10, 2012 | Computers & Internet
Does a laptop charger need a voltage regulator?
No. Your charger is designed to correct for input fluctuations and has a certain tolerances to meet for output voltage and current ripple.
Jun 17, 2009 | Compaq Computers & Internet
Horizontal line in My SHARP AQUOS LCD 32'' TV screen
Try to conect with DVD signal in A/V input if good picture, cable line are no good
Feb 16, 2009 | Sony 32 in. LCD TV
Sony 32 in. LCD TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
